Pagina 15 di 30 primaprima ... 5131415161725 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 293
[RACCOLTA FIRMWARE] Firmware Meizu Pro 5
  1. #141
    Moderatore L'avatar di 97nik
    Collegno
    Meizu Mx5
    Ringraziato 519 volte in 350 Posts
    i
    Flyme OS 5.6.4.19G BETA
    Aggiunta al Download
    Samsung Galaxy S7 Edge (SM-G935F) / Android 6.0.1
    SAMSUNG Exynos 8 Octa 8890
    Quad-core 2.3 GHz + Quad-core 1.6 GHz
    SE TI SONO STATO D'AIUTO, LASCIA UN THANKS
  2. Il seguente Utente ha ringraziato 97nik per il post:
    ultras1911 (25-04-16)
    Sep 2015
    Flyme OS 5.1.5.0A stable (Pro 5)
    Changelog:
    Firmware Highlights
    Improve the system upgrade mode, system upgrades APP new “reception trial version firmware” switch.
    Optimize file sharing experience, increase “Free flow fast pass” to provide visual management page.
    Support VoLTE, HD voice calls, a call can access the same time, turning a shorter waiting time.
    Communication
    Optimization: Updating Baseband version.
    Optimization: calls in full-screen desktop display when a call interface.
    VoLTE: Added support for VoLTE of.
    Fix: Even now display a blank contact list.
    System Upgrade
    Improve the system upgrade mode: add “receiving trial version firmware” switch.
    Fixed: notification bar even now click “Download updates” no response.
    Free flow pass fast
    Free flow pass fast: optimized file sharing experience, increase visualization page.
    Desktop
    Desktop editing: Adding mobile support under Utility mode icons and widget.
    Prompt the desktop editing position adjustment: Optimization.
    WLAN
    Network speed: new network speed function, a key to view the current network speed.
    Network Diagnostics: new network diagnostic function, a key to detect the current network status.
    Entrance: Settings - Wi-Fi - Click hotspots currently connected into the details page.
    FIX: After connecting Wi-Fi switch to the data network will pop up authentication information.
    Install external applications
    Optimization: Depending on the installation source and application versions to distinguish between different installation scenarios, detailed display application permissions and chargeback risk.
    Optimization: Increase downgrade installations processing.
    Optimization: Tips why the installation failed.
    Voice assistant
    Optimization: Optimization Home Recommended to avoid screen flicker when loading data.
    Optimization: Optimization of alarm to remind user experience, allows you to view all the alarm and turn off all alarm.
    Optimization: Optimization of autodialer when using dual card language order.
    Optimization: Optimization of support for default card.
    Lock screen
    Optimization: lock screen camera is called the left slide to slide.
    Notification bar
    Optimization: Optimization screenshots notification logic, click on the share button automatically clear notification.
    Audio frequency
    FIX: listening to music with headphones, the notification bar appears murmur or break the sound mute switch.
    FIX: When headphones to listen to music, to micro-channel message or phone, listen to the micro-channel voice, the sound suddenly becomes large.
    Mobile butler
    Fixed: notification bar displays information flow switch failure problem.
    Application Encryption
    FIX: micro-channel phone book can be read encrypted messages.
    Camera
    FIX: third-party applications do not call the camera OK button and remake after shooting.
    Fix: under password lock screen shortcut to open the camera when using the camera flash back Burst.
    Music
    Music Comment: Add comment and reply comment function point Like.
    Local Scan: add a key scan local music, support audio filter.
    Folder Management: Add all folders management functions.
    FM Radio: New FM radio.
    Message Center: New Message Center, you can view comments and bulletins Reply.
    Push message: add “to receive messages push” switch.
    Manual adjustment sequence: playlist support manually adjust the playback sequence.
    Version Upgrade: New version upgrade inlet.
    Optimization: Optimization of musical support for Talkback.
    Optimization: Adjustment Home template sort, “guess you like” to the fold.
    Clock
    Online ringtone: set alarm tone increase “online ringtone” entrance.
    World Clock: World clock when adding new cities by nationality search function.
    Optimization: Merge Ringtones and Flyme music as “local music”.
    Timer: timer increases the volume control function.
    Browser
    Guide Page: increased for the first time to start a new page guide features.
    Ad blocking: browser settings increase the “ad blocking” switch.
    Flash: Support Flash Player mainstream video site.
    Calculator
    Optimization: support slide switch mode calculation.
    Input
    Symbol: Increase math, special, number three categories of symbols keyboard.
    Landscaping theme
    Cheap Font: Font support special events.
    Search
    Optimization: Click Search plug into the search page, hot words card pre-show.
    Toolbox
    Optimization: Optimization compass calibration experience.
    Optimization: Adjust measurement scale of initialize.
    Scanner
    Adjustment: Remove “sweep card” feature.
    Uninstall: sweep the APP support is unloaded.
    Set up
    Optimization: Optimization of power consumption management statistics.
    Optimization: Application Management “downloaded” entry into “installed”.
    Download Manager
    Optimization: Reconstruction download interface, remove MD5 calculation function.
  5. #143
    Installata la 5.1.5.0 G, poco fa. Stasera qualche commento.
    Provengo dalla 5.1.3.0G, un pò "impastata". Nello scrolling, mi pare che non avesse grossa fluidità, sia nei menu, sia nel browser, forse è una cosa voluta, non so (smartphone precedente Samsung S5, sembrava meglio).
    Ho provato ieri la 5.6.4.19A, un pochino meglio in termini di scorrevolezza. Tolta solo perchè ho voluto rimettere la lingua italiana.
  6. #144
    Androidiano L'avatar di Pycon
    Sep 2010
    Ringraziato 40 volte in 29 Posts
    Quote Originariamente inviato da famiddi Visualizza il messaggio
    Installata la 5.1.5.0 G poco fa.
    Non sapevo esistesse...
    Ultima modifica di Pycon; 28-04-16 alle 13:36
    GRUPPO FACEBOOK DEL MEIZU PRO 5 : CLIKKA QUI
    GRUPPO FACEBOOK DEL VERNEE X PRO : CLIKKA QUI
    IL MIO SITO : CLIKKA QUI
  7. #145
    Ma il link? Consigliate di installare la beta?
    Inviato dal mio PRO 5 usando Androidiani App
  8. #146
    Sep 2010
    Quote Originariamente inviato da neaples87 Visualizza il messaggio
    Guarda che la 'G' non esiste ancora per la 5.1.5. X mettere questa versione devi passare alla 'A' ( asiatica ). Io non lo faccio...
  9. #147
    Quote Originariamente inviato da Pycon Visualizza il messaggio
    A me non spaventano i menu un inglese. Per il resto, basta cancellare le app cinesi e sei a posto.
  10. #148
    Sep 2010
    Certo, anche a me non da noia l'inglese, non è questo il punto.
    Il nocciolo della questione è che 'G' NON ESISTE ANCORA mentre la 'A' ha il bootloader diverso volendo passare agevolmente da un nandroid Flyme a un nandroid Cyanogen ci sarebbero casini grossi... X questo che la 'A' non la voglio provare
  11. #149
    Ho su la .5.0A da martedi..la trovo ottima..scrolling molto "burroso" come piace a me..cosumi eccellenti..meglio della 3.0G..
  12. #150
    Sep 2010
    Quote Originariamente inviato da morrrison Visualizza il messaggio
    Io invece continuo a testare la cyanogen
  13. Il seguente Utente ha ringraziato Pycon per il post:
    morrrison (29-04-16)
