Pagina 1 di 32 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 318
[ROM] LCR-F 1.0 + Patch 1.1.2 cumulativa
    Androidiano VIP L'avatar di seb86
    Nov 2009
    Reggio Calabria
    Ringraziato 113 volte in 90 Posts
    Finalmente è arrivata una delle custom rom più attese la prima LCR-F basata su Froyo.
    Il download è disponibile QUI
    Di seguito il changelog :
    codice:
        * Root
        * Optimized Applications
        * Optmized memory management
        * Optimized Framework
        * Apps2sd compliant (froyo apps2sd and old apps2sd method on sdcard)
        * Custom Black Theme
        * Custom Bootanim
        * Battery %
        * Full Android UI
        * Removed mostly Acer apps
        * Updated applications
        * Preconfigured launcher (LauncherPro/ADW.Lancher)
        * Preconfigured Settings for better perf
        * High Sensibility
        * Optimized GPS
        * AOSP Dialer/Contacts
        * Many Live wallpapers (easilly uninstallable)
    QUI potete trovare anche alcune screen e altri dettagli.
    Aggiornamento: è disponibile anche la patch 1.1.2 cumulativa, ecco il changelog:
    codice:
    • fully rebased on Acer_LiquidE_4.504b.00_EMEA-GEN1
    • Memory enhancements (should fix tweak acces in LcrSettings)
    • New option in tweak menu to switch to next playing song when pressing camera button
    • New calculator
    • Updated themes with stock + sherps blue theme
    • fixed powertop + powertop.sh to run it
    • some internal fixes
    • FULLY CUSTOMISABLE USER INTERFACE (you can choose wich part to use via Lcr Settings) For better battery life and performance, disable customisation.
    • Lcr settings was translated (only some UI parts for the moment). Use more locale2 if your local is not directly in system settings
    • Fixed low volume on Navigator (TTS) (disable new audio codec in LcrSettings)
    • Enhanced audio playing (aac+ / m4a) (disable new audio codec in LcrSettings)
    • Mp3 vbr can be played again (enable new audio codec in LcrSettings)
    • Transparency in notification bar + Desire theme by simoneser (thanks to him)
    • Updated Lcr Settings with some UI translation + check wether Usb debugging is enabled at startup (required)
    • Global performance boost
    il download è disponibile sempre sul sito ufficiale del team LCR precisamente QUI
    Ultima modifica di andrew2511; 10-11-10 alle 19:34
    Senior Droid L'avatar di Ciocca86
    Jul 2009
    Ceprano
    Ringraziato 27 volte in 24 Posts
    su che rom è basata?
    Nov 2009
    Reggio Calabria
    credo vadano bene tutte le baseband di froyo
    Sep 2010
    la sto scaricando...proviamo subito!
    Androidiano L'avatar di antodemeter
    Jan 2010
    Posso flasharla sulla 4.504b.00 ?
    ps: non c'è bisogno di alcuna registrazione, almeno io ho scaricato tranquillamente
    Ultima modifica di antodemeter; 08-10-10 alle 15:47
    Sep 2010
    qualche domanda:
    - è noto qualche bug?
    - la installo tramite recovery rinominandola in update.zip?
    Jul 2010
    installala tramite recovery senza rinominarla
  9. #8
    Nov 2009
    Reggio Calabria
    Quote Originariamente inviato da antodemeter Visualizza il messaggio
    ieri sera (infatti l'articolo l'ho messo a mezzanotte circa) era necessaria la registrazione per il download e tra l'altro su richiesta dello stesso malez non metteremo altri link per il download ma solo quello ufficiale di lcr team
  10. #9
    Mar 2010
    Ringraziato 94 volte in 76 Posts
    caspita, la provo, però ormai penso che le varie bin sfornate siano meglio di questa o no?
    almeno he abbia qualcosa di davvero speciale preferisco tenere la bin
  11. #10
    Nov 2009
    Reggio Calabria
    dai un occhiata al link che ho messo nel primo post quello in basso dove parlo delle screen se vedi le screen del lcrsetting ti farai un idea della potenza di questa rom
