Visualizzazione dei risultati da 11 a 20 su 21
[GUIDA]Come aggiornare Lenovo K3 Note K50a40 ad Android 6.0 by Cuoco92 con Ita e root
  1. #11
    Sardegna
    Lenovo K3 Note
    Ringraziato 39 volte in 31 Posts
    mi rispondo da solo. Ho trovato questo su xda:
    "For TB, there is a solution. You need to go the the Backup Folder Location choice in Preferences. Look for the "Storage Provider" option at the top of the dialogue box. Tap it and choose "DocumentProvider Storage."
    Storage Provider should now show "External Storage."
    Navigate to the parent directory of your TB backups and choose it.
    You should now be able to select your TB backup directory. (The "Use the Current Folder" choice should be active.)
    There is another solution that TB offers, copied and pasted below from Item #31 on TB's troubleshooting page:
    "There is an elegant way of giving TitaniumBackup write access to the external sdcard, without having to forfeit security .... Since the time of Android 4.3, Google uses a very clean security-solution by giving apps that request write access to external SD, permission only to their own folder – not to the entire card! In order to get TitaniumBackup to work without compromising security, you can simply create a folder on the external sdcard, using the following folder-structure: /storage/extSdCard/Android/data/com.keramidas.TitaniumBackup/
    If you already have existing backups, move them with a file-explorer from their current place to: /storage/extSdCard/Android/data/com.keramidas.TitaniumBackup/ Lastly, go to the preferences of TitaniumBackup, choose “Backup folder location” and choose the above specified folder."
    Ho provato il primo metodo, ora funziona.
    Jan 2016
    Ciao, complimenti per il lavoro che hai fatto, ho provato a seguire le tue istruzioni, ma il risultato è stato negativo.
    Il telefono non entra in recovery mode, e dopo aver selezionato la lingua inglese (oppure cinese) si riavvia alla schermata iniziale.
    Dopo aver selezionato 11 in Setup-TWRP nella videata blu c'è un errore FAILED (remote:download for partition "recovery" is not allowed)
    Grazie per un aiuto !
  4. #13
    Androidiano VIP L'avatar di DanieleGS
    Mar 2015
    SHENZEN
    Xiaomi Mi Note 3 Black 6/128
    Ringraziato 1,981 volte in 1,060 Posts
    Quote Originariamente inviato da franksci Visualizza il messaggio
    credo dipenda dal firmware di partenza installato nel tuo telefono,
    che firmware hai?
    per far si che tutto funzione il fw di partenza deve essere questo:
    Ultima modifica di DanieleGS; 06-07-16 alle 09:24
  5. Il seguente Utente ha ringraziato DanieleGS per il post:
    franksci (06-07-16)
  6. #14
    Jan 2016
    Quote Originariamente inviato da DanieleGS Visualizza il messaggio
    che firmware hai?
    Ah, me ne sono perso un pezzo allora... Il mio firm. Vibeui_v.2.8_1535_5,128.1_ST_K50_t36. Puoi aiutarmi per favore?
  7. #15
    Jan 2016
    C'è qualcuno così gentile che può spiegarmi come procedere per l'aggiornamento !!!
    Daniele GS mi dice che questa procedura non va bene per il mio firmware ( Vibeui_v.2.8_1535_5,128.1_ST_K50_t36).
    Vi ringrazio in anticipo !!
  8. #16
    Jan 2016
    Uff...Nessuno sa rispondermi ?
  9. #17
    Jun 2015
    Ciao Daniele nella tua [GUIDA]Come aggiornare Lenovo K3 Note K50a40 ad Android 6.0 by Cuoco92 con Ita e root non riesco ad istallare sul tel. la recovery TWRP. Ho fatto tutti i passaggi descritti, ma mi esce la recovery del produttore lenovo .Mi potresti dare un consiglio. Grazie. E se c'è qualcuno che ha avuto lo stesso problema mi può dare una mano ringrazio tutti.
    Ultima modifica di zebepi; 09-09-16 alle 09:21
  10. #18
    Mar 2015
    SHENZEN
    Quote Originariamente inviato da zebepi Visualizza il messaggio
    la tua versione è K50a40?
  11. #19
    Jun 2015
    grazie daniele
  12. #20
    Jun 2015
    No è la Versione K50T5 e con questa non si puo fare l'aggiornamento?
    Ultima modifica di zebepi; 09-09-16 alle 15:59
