Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 2 di 6 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 51
Bluboo XTOUCH X500 [Modding]
  1. #11
    Feb 2014
    Marche
    Grandi, Grossi... Cinafonotti
    Ringraziato 8,535 volte in 6,485 Posts
    Quote Originariamente inviato da arnon Visualizza il messaggio
    Hi!
    First, thank you so much for making custom TWRP for Bluboo Xtouch. I'm using it on my Bluboo Xotuch and it's working fine. But link for boot animation "Marshmallows" is dead. Can you add new link?
    ciao, Aggiornato:
    https://mega.nz/#!SZ9RGQIA!0vPUiEVXB...7_dAedgQHsJ3kQ
    please write in italian on this forum!
    Thanks! Ciao
    Feb 2016
    Thanks for this very quick respond! Sorry, but I can't speak italian :/
    Ciao
  4. #13
    Mar 2016
    hello. I must have your help please. I bought a new xtouch and i have to Root it to try and fix my GPS. I dont understand the language you write in but this thread came up in google. I cant find how to root this device anywhere. if you have any advice i be gratefull..
  5. #14
    Feb 2014
    Marche
    Hi, this is an italian forum. So if you don't speak italian, go to this forum for reference:
    http://forum.xda-developers.com/andr...touch-t3288701
    The procedure is already available on needrom, following my link to twrp for Xtouch.
    Ciao
  6. #15
    @megthebest
    Annuncio firmware 21.04.2016
    Info - http://blog.geekbuying.com/index.php...198828-160503/
    Downlaod - http://www.mediafire.com/download/0z...828_160503.rar password = geekbuying.com
    Ultima modifica di bovirus; 08-05-16 alle 21:55
  7. #16
    Jan 2016
    .. sarà disponibile anche via ota update?
  8. #17
    Io non vedo il telefono da quando, spento, lo collego al PC...dove sbaglio?
  9. #18
    @mouse
    Hai instalalto i driver USB preloader?
    Come verifchi che non te lo vede?
  10. Il seguente Utente ha ringraziato bovirus per il post:
    mouse (19-05-16)
  11. #19
    Quando vado su "download" non accade nulla
  12. #20
    @mouse
    Fai una prova
    Scarica dal thread "Tools e driver mediateK" la versione aggiornata degli Android Platform Tools.
    Decomprimi il file nel disco fisso.
    verifica che nel teelfono sia abilitato "USB Debug" nel menu "Opzioni sviluppatore".
    Apri un prompt MSDOS nella cartella dove hai scompattato i file adb.exe e fatsboot.exe
    dai i comandi dos in neretto
    adb reboot bootloader - riavvia il telefono in modo fastboot (bootloader)
    adb kill-server - chiude il server adb
    Il telefono dovrebbe essersi riavviato e tu in basso a destra dovresti vedere un riga bianca fastboot
    Sul PC dovrebbe apparire per circa 44sec un popup "Mediatek preloader".
    Per ritornare con il telefono in modo normale digita il comando in neretto
    fastboot reboot - riavvia il teelfono in modo normale
    exit - per uscire dal prompt MSDOS
