Elephone P9000[ROM] cm 13 b1
http://bbs.elephone.hk/data/attachme....png.thumb.jpg
CyanogenMod is a free, community built, aftermarket firmware distribution of Android 6.0.1(MM), which is designed to increase performance and reliability over stock Android for your device.
codice:
#include
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it!
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
Unofficial builds of CyanogenMod 13.0 (Android 6.0.1) for the Elephone P9000
Working:
It is boots and hardware accelerated!
WiFi
Vibration
Audio
NFC
Rotation
All sensors
Bluetooth
Camera (Video and Photos)
External SD
RIL for SMS/Calls/Internet/Lte on 1 and 2 SIM
MTP and Mass Storage mode
Audio over Bluetooth
Enforcing SELinux
Fingerprint Scanner
FM Radio
Not working (yet):
Tethering
Gps - In process of fix...
Memory deffect (Settings/memory - no information - it is a reason why after reboot not loading widgets and recent's non working) - In process of fix...
Download CyanogenMod:
https://yadi.sk/d/MYgh6lYHtVZ4D
Download Recovery for CyanogenMod installation:
https://yadi.sk/d/FxLsZhabtVaGn
How to install:
Just install it via provided recovery. After boot in to the Recovery, you can easy navigate by touchscreen. HOME button (back). It is a good idea to use CyanogenMod Recovery, because you can easy install next build's.
Steps:
Copy CM on sd card
Go to: Factory reset
Choose: System reset (keep media) after Full factory reset and Wipe cache partition
Return and go to Advanced and choose: Wipe system partition
Return and go to Apply update choose: Choose from sdcard1 (your sd card) emulated (internal memory)
You will also need gapps if you want to use Google services. Download arm64 Android 6.X Stock OpenGApps package from The Open GApps Project
Sources:
Device Tree: Not released yet, soon
Kernel: Not released yet, soon
Thanks to:
@cyanogenmod team
@wuxianlin
@Xen0
Appendix:
If you want to mirror the files or port the ROM to another device, I encourage you to do so! Only please respect my work and give proper credits. Thank you!
Contributors
Deepflex
ROM OS Version: 6.0.x Marshmallow
ROM Kernel: Linux 3.18.x
ROM Firmware Required: Latest Stock Android 6.0
Based On: CyanogenMod
Version Information
Status: RC
Current Beta Version: Build 1
Beta Release Date: 2016-07-21
Created 2016-07-22
Last Updated 2016-07-21
fonte:
[ROM] [Build1] CyanogenMod 13.0 21/07 | Android 6.0.1 | RC - ROM download - Elephone forum,Elephone service,Elephone BBS of P8000,P9000,S3
versione lite
https://yadi.sk/d/QQutbHattVYBM
fonte:
http://bbs.elephone.hk/thread-11690-...l#.V5LD4DVZDIU
ringraziamenti a
Deepflex
per lo share
