Pagina 50 di 65 primaprima ... 40484950515260 ... ultimoultimo
Visualizzazione dei risultati da 491 a 500 su 645
[Recovery] TWRP touch recovery
  1. #491
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Grandissimo !
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
    Banned
    What's new in 2.6.0.0:
    Special Note: If you are running a custom theme, some of the changes in 2.6.0.0 will likely not be visible with your custom theme.
    Can encrypt a backup to prevent theft of private data from your backup files
    Updated graphics / icon courtesy of shift
    Updated exFAT to latest commits
    Fixed a problem with Samsung TouchWiz decryption
    Update SuperSU binary
    Fixed saving of backup partitions list
    Fixed saving of last used zip install folder
    Fixed backup of datadata on devices that use a separate partition for datadata
    Fixed some issues with the advanced wipe list (android_secure, can now wipe internal storage on data/media deivces and wipe data on the advanced list no longer formats the entire data partition)
    Fixed some problems with partitioning a SD card
    Various other bug fixes and tweaks
    Notes about encrypted backups:
    Why encrypt your backups? -- Most people store their backups on the device. Any app that has permission to access storage could potentially read your backup files and try to harvest your data. Encrypted backups also provide an added layer of security if you move your backups to other storage devices or to the cloud. The encryption that we're using is probably not strong enough for enterprise level security, but should be strong enough to make it significantly difficult to get to your data.
    Encryption is using OpenAES which uses AES 128-bit cbc encryption. If you happen to use a longer password (over 16 characters) then the encryption strength improves to 192 or 256 bits. Do not forget your password. If you forget your password you will be unable to restore your backup. We don't encrypt the entire backup. Encryption is very CPU intensive and can be fairly slow even when we spread the workload over multiple cores even on the latest high-end devices. To ensure that encrypted backups don't take forever, we don't encrypt any other partitions besides /data and in /data we don't encrypt /data/app (or other app related directories where apks are stored) and we don't encrypt dalvik cache.
    Tradotto da Google :
  4. Il seguente Utente ha ringraziato Gynlemon per il post:
    Pelide (09-07-13)
  5. #493
    Ringraziato 9 volte in 6 Posts
    Gyn io che ho già tale recovery devo flashare da recovery o da toolkit??
  6. #494
    GNexus, Nexus 5/6
    Quote Originariamente inviato da Fatjon Visualizza il messaggio
    Da recovery ................... l'aggiornamento se hai la versione 2.5
  7. Il seguente Utente ha ringraziato dadenet per il post:
    Fatjon (09-07-13)
  8. #495
    Banned
    Quote Originariamente inviato da dadenet Visualizza il messaggio
    Esatto..
    finalmente hanno rimesso il salvataggio dell'ultima posizione
    nel fare il backup e si vuole rinominare fare tap in alto.. perchè nella precedente posizione c'è la nuova funzione No Encryption , cui c'è da impostare una password per il backup, provato ora..
  9. #496
    Ringraziato 39 volte in 35 Posts
    attenzione da xa pare che ci siano problemi a copiare i backup sul computer con questa 2.6.0.0
  10. #497
    GNexus, Nexus 5/6
    Quote Originariamente inviato da fracama87 Visualizza il messaggio
    Quoto , non è possibile fare la copia del backup su Pc , con al versione 2.6.0.0.
  11. #498
    Banned
    a me 2 me li ha copiati.. ( fatto un test, solo uno non riesce...probabilmente era per la nuova funzione : Can encrypt a backup to prevent theft of private data from your backup files
    cui occorre disabilitare e quindi immettere la password.. ne sto facendo uno ora senza " encrypt "
  12. #499
    GNexus, Nexus 5/6
    Buon gionro Gyn ,
    a me ha copiato solo una parte della cartella del bk , provo come dici.
  13. #500
    Banned
    Buon gionro Gyn ,
    Ciao..
    Allora i backup fatti con le precedenti versioni li copia su pc.. con la nuova anche togliendo " encrypt " non li copia una volta fatti..
