Pagina 35 di 50 primaprima ... 25333435363745 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 493
[ROM] [JB] Team EOS 3 * Jellybean * Le nightly - Maguro
  1. #341
    Androidiano L'avatar di fritz87
    Quote Originariamente inviato da giannib Visualizza il messaggio
    Dipende dalle gapps se sta o no la fotocamera..non sò perché ma e cosi
    ho anche provato ad installare le gapp vecchie che prima mi funzionavano, ma niente
    Banned
  4. #343
    Androidiano VIP L'avatar di giannib
    Ostuni
    LG G4
    Ringraziato 116 volte in 104 Posts
    Changes
    crespo common: Use the crespo kernel and defconfig.
    Change-Id: I2987d4046203e7e89b6e65bbb90623ea32574c09
    -- Chris Trotman / detail
    Add the essentials that are needed to get a device to boot.
    Change-Id: If70f83c1874e53af8d9b5513d6212a126fe2e370
    Add crespo4g to the lunch menu.
    Om nom nom nom.
    Change-Id: If86a2e2ad9c51a65a6aba5018affeae3c64394a8
    Merge "Improve StatusBar Volume Control" into jellybean
    Improve scrolling cache
    Scrolling cache helps make short scrolls/flings smooth but will
    cause stutter when long flings are made. This patch disables
    scrolling cache when long flings are made.
    This patch also fixes a related bug where scrolling cache will
    not be enabled properly when transitioning from flinging to scrolling.
    Patch Set 2: Calculate threshold based on maximum velocity (Sang Tae Park)
    Change-Id: I1fdbaad92263c9f983a32900e74eba1f0367902b
    -- Pawit Pornkitprasan / detail
    ARM: Makefile: tuning: Adapt makefile tuning to use MACH_GROUPER
    These makefile tuning options where originally developed by Kenny Crudup, for
    the stingray.
    Change-Id: Ia839cd9dba49b43dc28b997f292459b9ba7596d5
    ARM: Makefile: tuning: improve compatibility with several compilers
    With these changes, I have been able to successfully build with:
    arm-linux-androideabi-4.4.x/bin/arm-linux-androideabi-gcc [1]
    arm-eabi-4.4.3/bin/arm-eabi-gcc
    arm-linux-androideabi-4.6/bin/arm-linux-androideabi-gcc
    arm-linux-androideabi-gcc (Linaro GCC 4.7-2012.05) 4.7.1 20120514 (prerelease)
    arm-none-linux-gnueabi-gcc (Sourcery G++ Lite 2010q1-202) 4.4.1
    [1] - section heading error in arch/arm/mach-tegra/pm-t2.c
    -- Kenneth R. Crudup / detail
    ARM: Makefile: Unify custom per-machine GCC build options to one place
    commit 7478c7f0 (hardfloat + toolchain change) scattered a bunch of
    GCC options all over "Makefile" and "arch/arm/Makefile", some of them
    either redundant, unnecessary or duplicated. Roll back both Makefiles
    to their kernel.org standard, and add the "CONFIG_EOS_MAKE_TUNING"
    Kconfig option so that any GCC build options may be consolidated
    there (and customized per-machine or per-cpu if desired).
    Add some preferred options for the Moto Xoom (MACH_STINGRAY) to start.
    Conflicts:
    arch/arm/Kconfig
    arch/arm/Makefile
    Change-Id: I32c632bddcd2cc911cbb5ebca9d3273ebba73432
    defconfig: Enable MMC_SDHCI_NATIVE_BLOCKSIZE
    Change-Id: Ia748a06100a6b666a043bfda852b14376f3ea234
    mmc: host: sdhci: Allow use of controller's native max blocksize
    Currently, any controller supporting a blocksize of 4K or higher
    is bumped back down to 512 bytes. This change allows using the
    controller's native blocksize on a per-hardware basis.
    Conflicts:
    drivers/mmc/host/sdhci.c
    defconfig: Use ext4 for ext2 and ext3 file systems.
    Change-Id: Ib49282f7a8975abe067d44c2079d8b4f4bfd639a
    defconfig: Add eos to the local version.
    Change-Id: I35557333a3bcae9910860dd860dd5ff63b9789a0
    defconfig: Align the local version number with the rest of the kernels.
    Change-Id: I9505c5cabeb5dda52790bab23cd739729f9e3555
    defconfig: Align the local version with the rest of the kernels.
    Change-Id: I5f982c2003d102b29d4b774d4f943cd2e881a177
    defconfig: Switch to Eos3 Local version number.
    Change-Id: I2d430ffb20721534315ba7e1253fdfea1a5455c0
    This project was added to the manifest.
    -- unknown / detail
    ARM: Makefile: tuning: Adapt makefile tuning to use MACH_TUNA
    the stingray.
    Also disable a few flags that result in the tuna device not booting.
    Change-Id: Ia270431084db9da102bede51248e401984dee61c
    Conflicts:
    arch/arm/Kconfig
    arch/arm/Makefile
    Change-Id: I67db9382380f2aeae9ea28f6e7c2d133a047c22b
    Conflicts:
    Change-Id: If52923e0b898584cd6084282e74d13349c19f66a
    Build "fstrim"
    Now that we're turning on "discard" on /data, "fstrim" can be used
    to have the EMMC controller reset/erase any blocks the filesystem
    isn't currently using (helps reduce NAND fragmentation, and write-
    amplification when the EMMC becomes full).
    Change-Id: I1d4742b81aa8080c705141fdac8131566c8c9724
    -- unknown / detail
    Crespo(4G) JRO03H broadcom binaries.
    Change-Id: I8439c90eeef77f6279e7ba63e0a69f9bd7cc3c7a
    CameraLauncher: Change to use the same code as the lockscreen.
    This is to avoid using the somewhat buggy method of calling the camera
    intent directly.
    Change-Id: I20d7945076ec0bdbc9205cb2f52c52b0d343bed3
    Add the "fstrim" binary
    Change-Id: I941a30e1d28b26b0d197da6a1c2dfc1ae72095b5
    Crespo(4G) JRO03H imgtec binaries.
    Change-Id: I012cbf273045275c797bc3f9094afd9995445c9d
    Cleanup of NVidia proprietaries (2 of 2)
    Remove proprietaries now in JRO03H-level NVidia proprietaries
    Remove build-supplied /system/etc/audio_effects.conf
    Change-Id: If7c0d463fc53ea7c89b4e2abc1a963c2d2ec5e7c
    Cleanup of NVidia proprietaries (1 of 2)
    Resume building libpkip.so from NVidia-supplied source
    Change-Id: Ie62b28b9fdf35f5c0eba98c0c99de384c64e53df
    Wingray JRO03H
    Change-Id: Iaee69f0d7126740ab047292832a1d4c0721b10c6
    -- unknown / detail
    Crespo4g: Only define packages if the target is crespo4g
    Change-Id: Iba1309e07f8126c8b0483ec15782ebd4068c5f9b
    Crespo(4G) JRO03H samsung binaries.
    Change-Id: Ic29a767500f5e7bccef838058d1229c25c66c8af
    Crespo(4G) JRO03H widevine binaries.
    Change-Id: I89cca8b74ee6ded091afcf2ba2b902c04327b091
    Clicca su thanks se ti sono stato di aiuto
  5. #344
    Senior Droid L'avatar di edwardeutsch
    Google Nexus 5
    Ringraziato 138 volte in 109 Posts
    Ei ciao ragazzi sono nuovo! Arrivo da un S2 con le experimental CM10 dopo aver passato un sacco di tempo su cm9! Ora monto la jellybro con leankernel...a questo punto dello sviluppo..ad oggi...è migliore questa EOS rispetto alla euroskank che monto? Grazie per l'aiuto in anticipo!
    Tapatalk @ Galaxy Nexus
    NEXUS 5 (32GB) / STOCK 4.4.2 (KOT49H) or PARANOIDANDROID 4.3 (BETA) / TWRP / SU
    IT'S A TRAAAP!
  6. #345
    Ostuni
    LG G4
    Quote Originariamente inviato da edwardeutsch Visualizza il messaggio
    a batteria sicurmente si ma a personalizzazione la euroshank è superiore..se vuoi usare la cyano10 ti consiglio la official build (c'è un post apposta )..io monto la EOS è mi bastano i toggle, power menù e la % nella batteria
  7. Il seguente Utente ha ringraziato giannib per il post:
    edwardeutsch (06-08-12)
  8. #346
    Google Nexus 5
    La batteria qui cala a vista d'occhio...grazie ancora!
    IT'S A TRAAAP!
  9. #347
    Ostuni
    LG G4
    Quote Originariamente inviato da fritz87 Visualizza il messaggio
    devi scaricare le ultime Gapps dal 1 post il link
  10. #348
    Ostuni
    LG G4
    118 in upload stasera vi faccio lo screenshot della 117 quasi 1 giorno e mezzo di utilizzo e ancora il 49%
  11. #349
    Banned
    Gianni!! manca poco e la #118 esce dalla cucina! .. io sto aspettando la fila per ultimo quasi.. interessante quella di oggi per lo xoom..
  12. #350
    Ho risolto cosi grazie
    Inviato dal mio GT-P5100 con Tapatalk 2
