[ROM] RASBEANJELLY Maguro OTA By Rascarlo
Ho notato che questa ROM manca in questo forum... mi sono permesso di postarla... Changlog a seguire...
changelog:
changelog:
- first build
- power menu with screenshot and reboot options
- power widget
- volume rocker music control
- volume rocker wake
- long press to kill
- battery percentage
- expose rotation lock toggle (hidden in stock os)
- black and holo blue glow ui
- black ui for contacts
- frameworks and performance optimization
### Flash
- wipe cache
- wipe dalvik cache
- flash zip
- (opt.) flash kernel since it comes with stock (i would flash trinity)
- reboot
- log into google and let it sync
- (opt.) push your busybox in the way you want or use Stericson BusyBox
- fix_permissions
- (opt.) reboot
## About busybox
Quote from stericson email:
"The free apk, or the binary is fine.
Actually, I wish more rom devs included the free version in their roms.
It would help keeping busybox standard across different roms instead of devs having different tweaked modified version of busybox that don't have all the functionality needed by other applications.
Pleasure is all mine.
Honored to have an application baked into a rom.
:D"
### gapps?
included
### md5sum
you can also download the md5sum file and check in TWRP
### Any official thread?
Support can be found in the trinity kernel thread for your device on xda.
### I am @rascarlo on twitter
Download
euroskank
R: [ROM] RASBEANJELLY Maguro OTA By Rascarlo
markusssss
come mai non ha avuto seguito questa rom tra gli androidiani? :) screenshot non ce ne sono?
QUOTO! qualcuno sa come si comporta la 4.2? Impressioni?
tonee
L'ultima release è basata sulla 4.2?
R: [ROM] RASBEANJELLY Maguro. OTA By Rascarlo
vidaqui73
Si credo.
