Utente del mese: bluemask con ben 32 Thanks ricevuti nell'ultimo mese
Pagina 54 di 96 primaprima ... 444525354555664 ... ultimoultimo
Visualizzazione dei risultati da 531 a 540 su 958
[ROM][4.1.1][AOSP] Codename Android [JB]
  1. #531
    Senior Droid L'avatar di KingVidal93
    OnePlus 3
    Ringraziato 256 volte in 187 Posts
    R: [ROM][4.1.1][AOSP (JRO03H)] Codename Android [JB]
    Nightly del 18/09, piuttosto corposa:
    * added 720p recording support to the nexus 7
    * added theme, smiley, emoji, strip unicode and date support for Mms Quick Message
    * better multilanguage support (WIP)
    * added the ability to have up to 5 customizable ring targets
    * moved ring targets feature into the navigation bar settings
    * automatic lock screen weather refresh will no longer cause freezes
    * seperated the ability to center the lock screen widgets and the lock screen targets widget
    * lockscreen widgets can now be on the right, centered, or on the left
    * added timer snapshot support to the camera
    * added burst mode to the camera (up to 20 pictures at a time)
    * added jpeg quality settings to the camera
    * added settings for enabling and disabling WebGL in the browser
    * added option for preloading media in the browser
    * bluetooth audio streaming should be fixed across all music apps and hardware
    * added sms over bluetooth (i.e. ability to read sms via car stereo)
    * re-organized all phone settings
    * fixed export-to-storage function in contacts
    * better performing wifi connection
    * wifi will no longer avoid poor connections if not connected to a mobile network
    * fixed tethering issue that was occurring on some devices
    * added feature to configure wifi idle timeout
    * power widget no longer shows data options if they arent supported
    * fixed wi-max power widget toggle
    * fixed weird black line about Mms text feild
    * fixed small down arrow when keyboard is up and phone is in landscape
    * added landscape layout for the color picker
    * enabled fdatasync for SQLite
    * HTML 5 video user experience and stability fixes and network optimizations
    * better text rendering
    Download: http://goo.im/devs/codenamedroid/nightlies/cna_maguro
    Quote Originariamente inviato da dadenet Visualizza il messaggio
    Domanda ,
    ho su la 3.5.0 , se voglio fare l'upgrade all'ultima nightly ? , procedura ?
    I due wipe cache e dalvik e poi flashi ROM e gapps
    Ultima modifica di KingVidal93; 18-09-12 alle 10:59
  2. Il seguente Utente ha ringraziato KingVidal93 per il post:
    seblog (18-09-12)
    May 2010
    Ringraziato 32 volte in 28 Posts
    cavoli, che changelog da paura! non vedo l'ora di provare la prossima versione allora,
    sopratutto mi incuriosisce questo punto:
    -added burst mode to the camera (up to 20 pictures at a time)
    non sapevo che il nexus potesse fare gli scatti a raffica (a mo di S3 o OneX per intenderci...)
  5. #533
    ciao ragazzi, posso mettere anche io quasta rom sul galaxy nexus con versione android 4.1.1? se si le gapps dove le trovo? ora attualmente ho installata una cyanogenmod 10 sperimentale
    Ultima modifica di spensierata69; 18-09-12 alle 19:43
  6. #534
    Androidiano VIP L'avatar di Beggs
    Napoli
    Xiaomi Mi A1
    Ringraziato 458 volte in 353 Posts
    Quote Originariamente inviato da spensierata69 Visualizza il messaggio
    Si la puoi installare, 4.1.1 è solamente l'indicativo della versione di android che attualmente monti.Le gapps le trovi stesso al link in prima pagina.Ti consiglio quelle con no picasa ma con le camera features.
  7. #535
    per ringraziarti beggs, devo cliccare il tasto thanks, come devo fare per contattarti in pvt e come devo fare per mettere un edit? io sono nuova e di queste cose non ne capisco molto, scusatemi
    Ultima modifica di spensierata69; 19-09-12 alle 14:45
  8. #536
    Napoli
    Xiaomi Mi A1
    per ringraziarti beggs, devo cliccare il tasto thanks? io sono nuova e di queste cose non ne capisco molto
    Si è gradito da tutti gli utenti del forum, è meglio del commento, crea meno confusione e contribuisce all'ego di tutti!
    EDIT: vado un secondo OT(off topic per chi non lo sapesse) e ti spiego giusto due cose, la prima cosa da tenere a mente è cercare di non andare mai ot... quindi creare sempre domande e risposte inerenti alla discussione che visiti,sottoscrizioni alle discussioni è il tasto che fa al caso tuo per vedere se qualcuno risponde alle tue discussioni, non creare mai post doppi ma usa il tasto modifica messaggio sotto il tuo ultimo commento e se ti va metti un edit prima di modificare così salta di più all'occhio la modifica... Se hai problemi scrivimi in pvt o usa il tasto cerca prima di aprire una nuova discussione..
    Ultima modifica di Beggs; 18-09-12 alle 20:29
  9. Il seguente Utente ha ringraziato Beggs per il post:
    spensierata69 (19-09-12)
  10. #537
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Quote Originariamente inviato da KingVidal93 Visualizza il messaggio
    Download: Goo.im Downloads - Browsing cna_maguro
    Quindi ricapitolando , giusto per non sbagliare da versione stable a nightly sempre i 3 full wipe ? ,
    mentre se passo da nightly a upgrade nightly sempre e solo wipe cache e dalvik ? giusto ? + gapps sempre ?
    Grazie anticipatamente .... ( ok clikkato sul thanks )
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
  11. #538
    OnePlus 3
    Se passi da stable a nightly della stessa ROM bastano i due wipe cache e dalvik, stessa cosa da nightly a nightly...i 3 wipe sono necessari solo se si flasha un'altra ROM
  12. #539
    GNexus, Nexus 5/6
    Scusami ma non afferro il passaggio i due wipe cache , quali sono in recovery ?
    wipe cache partition e l'altro wipe ? + wipe Dalvik Cache.
    Ok x rom totalmente differente i 3 full wipe.
    Vi chiedo questo perchè quando passo dalla 3.5.0 all'ultima nightly , il sistema mi segnala che l'app android assistant si chiude in maniera anomala , ( questo il messaggio che mi da ) , se la disinstallo e poi la reinstallo il sistema mi dice che non ce sufficiente memoria , mah ?
    Ultima modifica di dadenet; 19-09-12 alle 15:30
  13. #540
    Viterbo
    LG Nexus 5
    Ringraziato 48 volte in 38 Posts
    Per questa ultima nightly raccomandano comunque i 3 wipe dato che sono cambiate molte cose. Per due wipe si intende Cache e Dalvik cache.
  14. Il seguente Utente ha ringraziato dellericcardo per il post:
    dadenet (19-09-12)
