Pagina 106 di 131 primaprima ... 65696104105106107108116 ... ultimoultimo
Visualizzazione dei risultati da 1,051 a 1,060 su 1305
[ROM][JB] Slim Bean
  1. #1051
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    mi sa che è troppo presto anche per la weekly 7.8 XD
    SlimBean weekly build.7.8
    no space on buildserver, builds delayed...
  2. I seguenti 2 Utenti hanno ringraziato Pelide per il post:
    fedelamb (28-07-13),oleksandr (28-07-13)
    Jul 2010
    Per il nostro dovrebbe essere tutto a posto
    http://www.slimroms.net/index.php/do...-7-8-weekly-29
  5. Il seguente Utente ha ringraziato Pelide per il post:
    oleksandr (29-07-13)
  6. #1053
    Jul 2010
    Io ci leggo due news
    - nel weekend uscirà una 4.2.2 stabile
    - la alpha 4.3 è già a buon punto
    ovviamente a vostro rischio
    EDIT: nuovo link per il download http://goo.im/devs/gmillz/maguro/Sli...30801-0926.zip
    Quote Originariamente inviato da kufikugel Visualizza il messaggio
    Hey guys,
    sorry that I am not much around....but I am a lot ill last time + that I need all power for 4.3. Since one week now griff and me merged 4.3 into SlimBean. A lot user do not realize that this is IMO one of the most major updates google did since last 2 years. There are about 5 million changes they did in the last 8 months...mainly optimizing under the hood.....doing the code more logic etc etc. So really a hard task for 2 ppl to merge that in and do not break the rom lol. Beside some other teams behave other especially a famous one I can say that we merged everything in and have beside some small glitches everything working. Due that I have maguro you guys are the lucky one for the first alpha version now
    So small heads up what is working and what not
    - Working....as far as I can see all major phone functionallity. As well all features from Slim
    Glitches:
    - QS layout is a bit off
    - rambar does not show up
    - keyboard swipe crashes
    A hint to SU:
    - at the moment KOUSH is still working on it to have a full functional SU. In general it works quiet well with most of the apps. But you need to toggle it in developer options!!! (Root access....and set it to Apps and ADB or anything other then disable....even if it is set to App when you install)
    A hint to 4.3 kernel
    - this alpha version still has lean 6.6 version in...the reason is ADB. Currently on maguro all 4.3 kernel do not have adb for whatever reason. Which is for debugging a pain lol. As well most 4.3 kernel are not 100% stable. From that what I have tested fancy 4.3 kernel is really good already, only downside his kernel has currently is that it conflicts with media provider (you get FC when connecting to mtp). Other then that fancy is great. So if someone want to test a 4.3 kernel fetch fancys one.
    - Do not install 4.3 stock kernel.....it has functional issues with theme manager
    A hint to Contacts:
    Contacts is now AOSP stock version with trds backed in.....due off major major changes it does not make sense to merge that into our old one. So you will miss there features (contacts and dialer)
    A install hint:
    - backup
    - latest recovery
    - full wipe
    - install as usual
    https://dl.dropboxusercontent.com/u/...30801-0702.zip
    and a temp gapps package (I just put in the main lib files which changed...no new apk's they will follow on weekend with the stable release of 4.2.2)
    https://dl.dropboxusercontent.com/u/....3.build.1.zip
    gnow package etc you can use the 4.2.2 for now.
    So and now after one week nearly no sleep and IMO an awesome result have fun report back and enjoy
    kufi
    PS: And do not blame us for apps which do not work with 4.3
    PS2: our official beta tester....we will start next days our jenkins for you guys which will build alpha builds on daily usage
    PS3: BLE is enabled for maguro
    PS4: IT IS AN ALPHA DO NOT FORGET so only install if you want to help us and see what is going on on 4.3
    PS5: updated to new build
    hey,
    yes sorry about the APN....was my fault because of that we reseted phone and contacts back to AOSP
    whatever here the new build after working again the whole night
    Using third party keyboards fixed
    APN FC fixed
    added back all phone features
    migrated blacklist feature into new dialer
    more or less we are now on the old state on phone and contacts. Only the detailed statistics not where we are not sure if we want to have it at all.
    @gapps yes update will come as well for the playstore. A bit complicated currently to do all at the same time lol
    cheers
    PS. updated other post with new build as well
    Quote Originariamente inviato da shreddintyres Visualizza il messaggio
    For those who are interested,
    I am waiting to charge to full before i flash the 4.3 alpha, but i have been running a few other 4.3 roms and the Franco kernel with modified ramdisk works well with 4.3 and has full adb but is not compiled from 4.3 sources. it is rather quick faster than it was on 4.2.2 at any rate.
    Ill update later on with usage on slim 4.3 alpha 1
    here is a copy of an inverted multidpi playstore latest version, that i have been using on other 4.3 roms, i did not create it and unfortunately cant remember where i found it.
    Ultima modifica di Pelide; 01-08-13 alle 11:17
  7. I seguenti 4 Utenti hanno ringraziato Pelide per il post:
    fedelamb (01-08-13),Mithril (03-08-13),oleksandr (01-08-13),slv96 (01-08-13)
  8. #1054
    Ragazzi ha qualche giorno che ho un problemone.. Praticamente avendo una connessione dati di 50mb al giorno mi sono accorto che dopo qualche secondo che sono collegato mi finiscono i mb.. Ho controllato il traffico dati ed ho visto che me li ha consumati tt il processo "servizi Google".. Col wifi ovviamente Nn mi accorgo di niente, ma così praticamente Nn posso utilizzare la rete dati.. Mettendolo con il limite dei dati in background il problema Nn si pone, ma ovviamente perdo delle sincronizzazioni con le tacche che rimangono grigie.. Qualche idea..? Ho provato a reinstallare le gapps ma niente..
  9. #1055
    Jul 2010
    Quote Originariamente inviato da fabioantonio99 Visualizza il messaggio
    L'ho letto in un paio di thread ma non ci ho fatto tanto caso, quindi dovresti provare a leggere qualche pagina indietro sul thread di xda.
    Quello che mi ricordo è, potresti fare una prova, disabilitare la sync di "dettagli persone" e lasciare il telefono in wifi per un po' di tempo in modo che sincronizzi quello che deve.
  10. #1056
    Quote Originariamente inviato da Pelide Visualizza il messaggio
    Ma io le sincronizzazioni dell'account Google le ho sempre avute tt disattivate, e Nn ho mai avuto di questo problema.. E adesso che succede sta cosa sono sempre tt disattivate.. Cmq potresti mandarmi il link del thread di cui parli..?
  11. #1057
    Jul 2010
    Ah, se sono inattive allora non so proprio
    Qua il thread ufficiale http://forum.xda-developers.com/show....php?t=2060396
  12. #1058
    Qua il thread ufficiale [ROM] [4.2.2] Slim Bean (Maguro) [Build 7] | Galaxy Nexus > XDA
    Appunto è questa la cosa strana.. Ho tt le sincronizzazioni inattive, ma da qualche giorno in background scarica tantissimi dati sia con il wifi che con la rete mobile.. Per adesso tengo limitato il traffico così Nn scarica però rimangono le tacche grigie Boh.. Ma potrebbe essere un problema di rom..? Cioè se provo a fare wipe e riflashare potrei risolvere..?
  13. #1059
    Jul 2010
    Prova con wipe cache - dalvik - system e reflash rom e gapps così da non perdere dati.
    Cerca anche l'ultima versione, credo 4.2.3, del play store e sostituiscila a quella che c'è di default
    Edit: a pagina 474 su xda due utenti hanno trovato stanotte la causa nella sincronizzazione di dettagli persone, che però tu mi hai già detto ieri essere disabilitata. Rimane da fare una prova col play store nuovo e lasciare il telefono qualche ora sotto wifi con le sync attive per vedere che non sia rimasto qualcosa in coda
    Quote Originariamente inviato da Nebucatnetzer
    Hey guys new 4.3 build. The QS FC is now fixed and some other stuff I've forgotten.
    http://goo.im/devs/gmillz/maguro/Sli...30803-0731.zip
    We have now as well 4.3 Gapps
    http://goo.im/devs/gmillz/gapps/Slim...3.alpha2.1.zip
    Do NOT flash them on the 4.2 build.
    Sent from my Nexus 4 using Tapatalk 4 Beta
    Tapatalkeggiato - Improve SwiftKey http://goo.gl/xKYfc
    Ultima modifica di Pelide; 03-08-13 alle 10:34
  14. #1060
    Androidiano VIP L'avatar di fedelamb
    Ancona
    Honor 8
    Ringraziato 736 volte in 610 Posts
    Per questi consumo di dati da parte dei servizi google non Sei il primo a lamentarlo . . . in sezione nexus4 lo lamentano in quasi tutti i thread . . .
    Si pensa che sia il sistema che cerca di fare l'update a 4.3 . .
