Pagina 63 di 71 primaprima ... 13536162636465 ... ultimoultimo
Visualizzazione dei risultati da 621 a 630 su 706
[Guida] Nexus toolkit | sblocco| root | backup| factory restore
  1. #621
    kat
    kat non è in linea
    Androidiano L'avatar di kat
    Apr 2010
    Prova con questa :
    Procedura Flash Factory Images con metodo manuale
    LINK
    Grazie mille ha funzionato, una volta flashata la factory e bloccato il bootloader (non c'è più il lucchetto all'avvio) è pronto per essere riportato in garanzia, giusto?
    Banned
    Quote Originariamente inviato da kat Visualizza il messaggio
    Esattamente come da guida.. pronto per l'assistenza..
  4. #623
    Banned
    AN AUTO UPDATE IS AVAILABLE TO DOWNLOAD
    |=======JB======= WHAT'S NEW [V11.2.8] 9TH JULY 2013 =======JB=======|
    |+Updated all SuperSU Root [by Chainfire] methods to lastest version V1.41 |
    |+Custom Recovery now downloaded automatically by the Toolkit after Build Selection|
    |+Custom Recovery files checked and verified after download by Toolkit |
    |+Fixed Verizon Model [toro] IMM76 build not verifying after model files download |
    |+Bug fixes and improvements |
    | [V11.2.6] 19TH JUN 2013 |
    |+Added Toolkit support including root for JDQ39A-JDQ39E builds |
    |+Updated all SuperSU Root [by Chainfire] methods to lastest version V1.34 |
    |+Fixed problem with Toolkit crashing when selecting to root with SuperSU |
    | [V11.2.5] 09TH JUN 2013 |
    |+Changed Toolkit download method [now using cURL] for all downloads |
    |+Split up Model Files into much smaller size so only build selected is downloaded |
    |+Uploaded Model Files to SkipSoft.net and added option for Model File download |
    |+Uploaded Stock Rom images to SkipSoft.net and added option for download |
    |+Added option in Model Selection screen to go straight to Main Menu |
    |+Updated firmware flash code to fix minor bugs |
    |+Updates and fixes to main code to improve Toolkit stability |
    | [V11.2.0] 08TH MAY 2013 |
    |+Added missing Superuser apk file from chainfire root from V11.0.0 public build |
    |+Added Clockworkmod Root 1.0.1.8 to replace ChainsDD method for better support |
    | ALL root methods in the Toolkit now include Clockworkmod Superuser method |
    |+Added TWRP NAND backup/restore procedures and finally FIXED all NAND procedures |
    |+Added Universal driver pack from koush which works well on Windows 8 |
    |+Added Sideload another zip file whilst in Recovery to save time [user request] |
    |+Added Toolkit Hard Reset option in Toolkit Settings screen |
    |+Added text in driver install screen to test drivers properly |
    SAMSUNG GALAXY NEXUS TOOLKIT AUTO UPDATE V11.2.8 [9TH JULY 2013] AVAILABLE!!
    Changelog:
    [Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the professional features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other professional features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please email me at toolkit.support@skipsoft.net about them and do not post in the open thread]
    Donation links can be found at http://www.skipsoft.net/?page_id=703 for users who wish to update to the Professional version and enable Auto Updates.
    Mark.
  5. I seguenti 2 Utenti hanno ringraziato Gynlemon per il post:
    Pess (10-07-13)
  6. #624
    Ringraziato 20 volte in 16 Posts
    E' normale però che in prima pagina del thread ci sia ancora la 11.1, e pure su xda?
    Quell'aggiornamento è solo per la versione a pagamento?
    Ultima modifica di Ste45988; 20-07-13 alle 12:29
  7. #625
    Banned
    Quote Originariamente inviato da Ste45988 Visualizza il messaggio
    Esattamente.. e per ora ti conviene usare la versione in OP , in quanto nonostante si è "donatori" non funziona l'ultima versione se si compone il 17.. proprio 4.2.2 JDQ39
  8. Il seguente Utente ha ringraziato Gynlemon per il post:
    Ste45988 (20-07-13)
  9. #626
    Ok grazie!
  10. #627
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    Confermo non funziona
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
  11. #628
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Problematica segnalata qualche giorno fa.
    http://forum.xda-developers.com/show....php?t=1392310
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
  12. #629
    E' due ore che le provo tutte, ma non mi riconosce il telefono. Ho installato i driver dal toolkit, poi da Pda Net, poi da altre fonti ancora; l'ho collegato in fastboot, in tutto questo il debug USB è sempre stato attivo.
    Ma niente, il telefono non è mai stato riconosciuto e non è mai comparso il seriale nel main menu.
    Tra l'altro ho provato a installare Helium Backup, e neanche quello ha mai riconosciuto il telefono.
    Cosa posso provare? Quando lo collego in impostazioni connessione usb deve esserci "collegato come dispositivo multimediale" o come "fotocamera"? (queste sono le due opzioni, anche se le ho provate entrambe.
    Cosa ho sbagliato?
    In gestione dispositivi non mi è mai comparso "Android 1.0" ma sempre "android device", e nel sottomenu "Samsung Mobile Interface"
    EDIT: tra l'altro PDA net ha installato gli USB driver, i network driver, ma ha fatto l'ultimo step (install PDAnet on your phone), nel senso che è rimasto in sospeso per mezzo'ora finchè l'ho chiuso io, ma i driver in teoria li aveva già installati
    Ultima modifica di Ste45988; 20-07-13 alle 15:52
  13. #630
    ho letto qualcosa di striscio in rete ma non ho capito se sia vero o no. C'entra qualcosa avere una USB 3.0?
    Perchè sfortunatamente il mio portatile ha solo 3.0
    Ultima modifica di Ste45988; 20-07-13 alle 18:35
