Pagina 96 di 207 primaprima ... 46869495969798106146196 ... ultimoultimo
Visualizzazione dei risultati da 951 a 960 su 2063
[ROM] [4.2.2] Purity | AOSP JDQ39
  1. #951
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    Quote Originariamente inviato da DariosF
    Purity v5.2 Changelog Preview
    Build:
    - Build again voice dialer
    - Enable Bionic optimizations on Cortex platforms
    - move bionic optimizations to NEON makefile
    - Relax Cortex CFLAGS
    External_skia:
    - memcpy_76(): fix behavior on non-ARM architectures
    - skia: SkPaint::SkPaint(): don't cast away const …
    - Skia: Introduce caching of unscaled Bitmaps.
    Dalvik:
    - Fix -Xjitthreshold
    - Zygote: replace set?id() with setres?id()
    - Disable DalvikVM GC logcat spam
    Framework_native:
    - enable strict_aliasing
    - binder: Add MemoryHeapBaseIon
    - dumpstate: Squash fixes from CM 10.0
    - Fix build in ISO C++ 11 mode
    - binder: Fix ABI incompatibility between older and newer compilers
    - frameworks/native: Fix build with ISO C++11 compilers
    - native/libs/ui: Adding fix for conf 2.0 seg faults
    - frameworks/native: Increase EGL blob cache size limits
    - Reset the FrameNumber for dropped frame in async mode
    - kill the log spam for no trace file
    - surfaceflinger: Work around aliasing violations
    Framework_base:
    - Function uri.getAuthority is called twice. Minor doc corrections.
    - core/jni/android/graphics: Cache copy of pre-scaled Bitmaps
    - Account malloc mmaped pages as native heap.
    - Vectorize bitmap operations on A15 too
    - frameworks/base: vectorize Bitmap operations
    - ServiceState: add support for DCHSPAP
    - Reflect current state of torch in navigation ring button.
    Some performance improvements...
    Tapatalkeggiato - sorry for my bad english
    Quote Originariamente inviato da Tex99 Visualizza il messaggio
    devi cercare i file dei softkeys da utilizzare con zipthemer tipo qui [SOFTKEYS] Softkey Collection [08-01 Fonts!] - xda-developers
    Grazie mille ho scaricato i file dei softkeys ma non capisco come funziona l'app...
  4. #953
    Androidiano L'avatar di AndreiVolk
    Samsung Galaxy Nexus
    Ringraziato 35 volte in 34 Posts
    Quote Originariamente inviato da TheArax Visualizza il messaggio
    In questo post c'è la guida a zip themer sotto spoiler.
    Edit
    Scusami mi sono scordato di linkarti il post xD
    https://www.androidiani.com/forum/sh....php?p=2278124
    Ultima modifica di AndreiVolk; 19-03-13 alle 14:50
  5. Il seguente Utente ha ringraziato AndreiVolk per il post:
    TheArax (20-03-13)
  6. #954
    Jul 2010
    Se non ho capito male su questa rom mancano, riguardo la navbar, sia gli anelli personalizzabili che le funzioni per la pressione prolungata.
    Mentre è presente la possibilità di customizzare il led notifica.
    Giusto?
    Tapatalkeggiato - Sorry for my bad english - CyberGr v3 + AK014 + maguro
  7. #955
    Quote Originariamente inviato da Pelide Visualizza il messaggio
    Giusto?
    Gli anelli personalizzabili ci sono, la pressione prolungata ancora no. Il led di notifica si può personalizzare dalle impostazioni del dislpay
  8. Il seguente Utente ha ringraziato AndreiVolk per il post:
    Pelide (19-03-13)
  9. #956
    Androidiano VIP L'avatar di Beggs
    Napoli
    Xiaomi Mi A1
    Ringraziato 458 volte in 353 Posts
    adoro questi changelog così corposi sotto il profilo performance... *-*
  10. #957
    Samsung galaxy Nexus
    E' presente il volume waker? ovvero, si può accendere il display premendo i tasti del volume? e un'altra domanda.. ma è da flashare anche la baseband o quella che ha va più che bene?
    EDIT:
    ah si il volume waker è presente, c'è scritto anche nella pagina iniziale..
    Ultima modifica di FireAlchemist; 20-03-13 alle 12:35
  11. #958
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    Quote Originariamente inviato da FireAlchemist Visualizza il messaggio
    EDIT:
    La baseband non viene cambiata dalla ROM ma dalla factory image da cui sei partito. Se sei partito da 4.2.2 non ci sono problemi se dalla 4.2.1 flasha da recovery l ultima bb. Il ril è lo stesso quindi non serve
  12. Il seguente Utente ha ringraziato Tex99 per il post:
    FireAlchemist (20-03-13)
  13. #959
    ragazzi una domanda, sono riuscito a cambiare le soft usando rom toolbox, ma non mi fa cambiare ad esempio l immagine in background nel pannello notifiche, qualcuno sa perchè?Grazie
  14. #960
    Ringraziato 35 volte in 29 Posts
    Ho la versione 4.4 per aggiornare alla 5.1 che devo fare?
