Pagina 7 di 9 primaprima ... 56789 ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 85
[ROM][CM10.1][4.2.2] PitchBlack
  1. #61
    Sì anche i miei SMS rapidi hanno sfondo bianco
    Senior Droid L'avatar di misterblonde
    Jun 2009
    napoli
    Samsung Galaxy S4 Bianco
    Ringraziato 300 volte in 203 Posts
    Ho aggiornato il tema sostituendolo in system. Queste sono le mie impostazioni con i miei consumi e governor hyper
    Inviato dal mio Nexus 1926
    HTC DREAM---HTC HERO---SAMSUNG GALAXY S---GALAXY NEXUS BIANCO!
    Se ti sono stato utile ringraziami attraverso l'apposito tasto
    <------------- qui
  4. Il seguente Utente ha ringraziato misterblonde per il post:
    LuCiolla90 (16-05-13)
  5. #63
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    Quote Originariamente inviato da itasoulas Visualizza il messaggio
    PitchBlack 2.1M (Milestone) is now available for download!
    Changelog is now fully released at 2nd post
    Installation procedure is changed. >>> Read carefully 1st post and do only that! <<<
    Rom is probably one of the fastest and most stable you have ever flashed!
    Lots of improvements and bug fixes from my side
    Cool stuff from Beanstalk Dev, Scott. Thanks to sykomaniac for building this for maguro
    Initially 2.1M was based on BS 1.205. I needed to start all over to base this on 1.210.
    Can you imagine that? And I did finish in less than a day!
    Don't forget to set up Nova Launcher with one-click restore. It saves you time from doing all from scratch!
    :highfive: ENJOY THE FIRST PB Milestone Release! :good:
    ATTENTION!!!
    INSTALLATION FOR 2.1M (Milestone) Release
    do a full wipe, including system
    flash 2.1M release, reboot and complete setup
    open Settings>Security
    reboot and flash PitchBlack_Settings.zip @ 2nd post
    you now have the fastest rom in existence for you GNEX!!!
    [ROM] [THEME] [CM10.1] PitchBlack v2.1M | Galaxy Nexus > XDA
  6. I seguenti 2 Utenti hanno ringraziato Pelide per il post:
    LuCiolla90 (16-05-13),misterblonde (10-05-13)
  7. #64
    Jun 2009
    napoli
    aggiornata prima pagina
    io non riesco ad installarla
    mi va in bootloop quando installo il pbsetting.zip
    <------------- qui
  8. #65
    Senior Droid L'avatar di noviz
    Oct 2010
    Molise
    Pixel 6 pro ; oneplus 7 pro
    Ringraziato 271 volte in 207 Posts
    Quote Originariamente inviato da misterblonde Visualizza il messaggio
    A me non ha dato nessun problema ho flashato la rom riavviato sono andato in impostazioni - sicurezza - abilitato origine sconusciute, riavviato in recovery e flashato il pbsettings.
  9. Il seguente Utente ha ringraziato noviz per il post:
  10. #66
    Jun 2009
    napoli
    Quote Originariamente inviato da noviz Visualizza il messaggio
    penso sia un problema del mio download anche se però averlo corrotto due volte su due mi fa strano
    <------------- qui
  11. #67
    Oct 2010
    Molise
    Prova scaricarlo per la terza volta e segui come ho fatto io vedi se va...
  12. #68
    Jun 2009
    napoli
    Sto provando in questo momento, al massimo glielo pusho dentro come solo io so fare xD
    Come ti stai trovando? Impressioni?
    Finalmente installata ed odexata
    Ultima modifica di misterblonde; 10-05-13 alle 19:27
    <------------- qui
  13. #69
    Senior Droid L'avatar di LuCiolla90
    Pisignano di Lecce
    Asus Zenfone 2 ZE551ML
    Ringraziato 178 volte in 150 Posts
    Salve ragazzi.
    Vorrei sapere se questa rom abbinata al fancy kernel (r25 ext - che io adoro profondamente) può presentare problemi di compatibilità, casini vari, boh.
    Gracias.
    Il thanks rende sempre felici: datelo!
    Ogni messaggio di assistenza sarà cestinato!
    DEVICE: Asus Zenfone 2 ZE551ML
    ROM: Stock MM
    KERNEL: Stock
    MODS: No
    LAUNCHER: Nova Prime
    RECOVERY: TWRP
  14. #70
    Jun 2009
    napoli
    Quote Originariamente inviato da LuCiolla90 Visualizza il messaggio
    Salve ragazzi.
    Gracias.
    Assolutamente no, però ti sconsiglio di metterla adesso visto che questa è ancora basata sulla vecchia beanstalk che aveva dei problemi. Ho installi quest'ultima oppure attendi l'aggiornamento che arriverà a breve
    <------------- qui
  15. Il seguente Utente ha ringraziato misterblonde per il post:
    LuCiolla90 (17-05-13)
