Utente del giorno: hobin con ben 2 Thanks ricevuti nelle ultime 24 ore
[ROM][JB 4.2.2][JDQ39E] ThinkingBridge ROM [maguro]
    Ringraziato 187 volte in 150 Posts
    Quote Originariamente inviato da woorim98 Visualizza il messaggio
    Greets to the people here at XDA,
    We "Team BRIDGE" are here, attempting to compile Jelly Bean 4.2.2 Build JDQ39 from Android Open Source Project (AOSP). This thread is created to provide you people with the change logs, downloads, Instructions, bug submissions and development updates. So, kindly take over your ROM discussions to the Discussion thread under General Section, no appreciation posts or discussions are accepted here. If you like to appreciate, please press the THANKS button instead. Proceeding now towards the main content of this ROM. :angel:
    About
    ThinkingBridge ROM is an Android aftermarket firmware which is built with the purpose to offer maximum stability, high performance & an appealing User Interface. This ROM is based on The Android Open Source Project (AOSP) and CyanogenMod code. We are here to contribute to the Android Open Source world and provide our users with the Best-Of-Android.
    Team BRIDGE:
    1. htchoi5609
    2. woorim98
    3. black9
    4. DJBhardwaj
    5. Akibingbing
    6. dmc0306
    Supported Devices:
    1. GSM Galaxy Nexus (maguro)
    2. Nexus S (crespo)
    3. Nexus 7 (grouper)
    4. Galaxy S2 (i9100)
    5. Galaxy S3 (i9300)
    Disclaimer
    codice:
    #include <std_disclaimer.h>
    * Your warranty is now void.
    * I'm not responsible for bricked devices, dead SD cards,
    * thermonuclear war, or you getting fired because the alarm app failed. Please
    * do some research if you have any concerns about features included in this ROM
    * before flashing it! YOU are choosing to make these modifications, and if
    * you point the finger at us for messing up your device, we will laugh at you.
    General Info & Introduction
    • Android Open Source Project: Or in short AOSP. Android is an open-source software stack created for mobile phones and other devices. The Android Open Source Project (AOSP), led by Google, is tasked with the maintenance and further development of Android. Many device manufacturers have brought to market devices running Android, and they are readibly available around the world.
    • Rooting: Android rooting is the process of allowing users of smartphones, tablets, and other devices running the Android mobile operating system to attain privileged control (known as "root access") within Android's subsystem. Rooting is often performed with the goal of overcoming limitations that carriers and hardware manufacturers put on some devices, resulting in the ability to alter or replace system applications and settings, run specialized apps that require administrator-level permissions, or perform other operations that are otherwise inaccessible to a normal Android user.
    Fully Functional Features:
    • RIL (Calls, data and texts)
    • Wifi
    • Bluetooth
    • Touch UI
    • Contacts
    • Browser
    • Lockscreen
    • Settings
    • Notification drawer and toggles
    • Gallery
    • Quick Toggles
    Features Offered By ThinkingBridge ROM
    List will be added soon...
    Codice PHP:
    Change logs
    Quote
    Feb 172013 [Beta 1]
    Initial Jellybean 4.2.2 JDQ39 releaseAOSP 4.2.2_r1 branch merged
        Support
    new devices
        Fixed korean camera sound
        Support multiusers on phone
        Added Pie control
        Added Custom hardware keys
    Feb 24
    2013 [Beta 2]
    Fixed Camera FC
        Fixed Quiet Hours Custom Tile
        Added Quick Record Tile
        Fixed Updating 2G
    WiFi Tether and LTE Tiles
        Make System layour fill the homescreen properly on Expanded Desktop mode
        Smoother lockscreen framework on low RAM devices
    Mar 20
    2013 [Beta 3]
    Pie control update
        Removed Sense style recent menu
        Toggle rewrite
        Fixed SystemUI crash
        More detail back to kill toast
        Navbar performance update
        Fixed Expanded Desktop mode
        Fixed Camera settings FCs
        Fixed Tapatalk FCs
        Fixed many bugs
        Added many features
    April 5
    2013 [Beta 4]
    Performance Update
        Optimized System
        Redesign memory usage in recent apps
        Recents Lag Fix From PA
        ScreenShot QuickTrash
        Support
    new devices
        Volume toggle
        Memory size toggle
        Pie control update
        Selectable text in gtalk
        Adjust torch intent
    for CM torch
        Reduce boot up time
        Rework NavBar UI in ROMControl
        Added variable size pattern
        Added lock screen pattern dot
        Fixed navbar height reset issue
        Fixed audio services
        Fixed CMCircle battery interval
        Fixed screen off CRT animation
        Fixed multiuser layout
    for phones
    April 23
    2013 [stable1]
    Add Share ThinkingBridge ROM into DeviceinfoSettings
        Support Ad
    -Hoc (IBSSmode
        Support
    new devices
        Screenshot rotaion
        Status Bar Network Traffic Indicator
        Improved SystemUI layout
        Optimize Low
    -end devices
        Hide statusbar clock also
    for DashClock
        Update screenshot toggle
        Remove lag when launching an app
        Fixed Photosphere
    /Camera FCs
        Fixed memory leaks
        Fixed after change signal type
    or text color
        Fixed many bugs
    Known Bugs
    Let us know aboout them, refer Report Bug title below.
    Instructions to Install
    1. Download the latest ROM zip and GApps from the download tabs above.
    2. Connect your Galaxy Nexus into USB Storage mode to the PC via USB data cable.
    3. Drag the downloaded two zips to the root of your storage (and not in any folder).
    4. Power off the device, press Volume Up + Volume Down + Power buttons altogether until you see the Recovery screen
    5. You are now in Recovery mode.
    6. If you are flashing this ROM for the first time (coming from another ROM): wipe /data (factory reset) /cache, dalvik-cache and /system
    7. If you are updating this ROM (coming from previously installed version of this ROM): wipe /cache and dalvik-cache
    8. "Install zip from sdcard" > "choose zip from sdcard" > select the ROM zip and press "Yes" to flash.
    9. Follow the above step again to flash the GApps.
    10. When all is done, select "reboot system now".
    Links
    Github | Website (Not ready yet) | Google+ | Facebook | Twitter
    Want to report a bug? Read this first!
    The below stated format shall be strictly followed to report any bug related to this specific ROM. Make sure that you have not overclocked over the provided CPU frequency and also that you are not running any custom kernels. Such bugs will be subjected to ignorance
    Bug submission should majorly be done at the Bug Tracker.
    Credits & Thanksgiving
    • CyanogenMod
    • AOKP
    • ParanoidAndroid
    link xda [ROM][JB 4.2.2][JDQ39E] ThinkingBridge ROM | Galaxy Nexus > XDA
    Xoom : team eos 4
    Maguro : VanirAOSP 4.4.4 ART F2FS / TWRP 2.7.1.1 f2fs / SmittyV-UR-NoMeM
  2. Il seguente Utente ha ringraziato Nemis per il post:
    SamueleCiprietti (31-05-13)
