Pagina 5 di 6 primaprima ... 3456 ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 54
[ROM][KK 4.4.x][HALO][CM11] **crDroid AOSP**
  1. #41
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Per chi la volesse provare la prima 4.4.4 di test!!
    crDroid-Build2-20140717-cookbyBangsti-maguro.zip
    Ultima modifica di morfances; 22-07-14 alle 15:40
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
    Sep 2010
    ROMA
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  4. #43
    Sep 2010
    ROMA
    New build 23-8-14 is out
    - Synced with CyanogenMod sources until build time (build.prop time);
    - New HOVER touch to hide;
    - fb: do not block home button if incoming call is a background call (affect only devices with home button);
    - Fix preload slimrecent with PIE (blank panel)
    - Change PIE icons on the fly on theme changes
    - HOVER: swipe right to dismiss only from hover and left to dismiss from all (hover, status bar and notification drawer)
    - Switch to SlimRoms Heads Up;
    - Heads up content:
    * Launch in floating window
    * Option to show always expanded
    * Show updates from pending background apps
    * Show at bottom of the screen
    * Snooze time
    * Notification time out
    * dismissing to right keeps notifications in notif panel
    * option to disable in lockcscreen (for thse using lockscreen notifications)
    - Heads up: enable heads up notification checkbox for all (disable check of system packages to allow check box for all. This will, for example, bring screenshot to heads up if SystemUI is enabled)
    - Separate category in setting headers for notification services (heads up, hover and halo)
    - Long pressing an app from notification drawer also show an option to receive notifications from Head up!
    - Add option to change size of QS ribbon bar
    - HOVER: A few improvements
    - Call recording enabled
    - Slim recent panel background color and transparency
    - A bunch of updates for CM repos including all theme manager related
    - More forgotten things...
    Ultima modifica di morfances; 15-09-14 alle 17:05
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. #44
    Sep 2010
    ROMA
    New build is out!!!Non deludetemi..provatela!!!
    Build 14-9-14
    - Synced with CyanogenMod sources;
    - Fix recent panel defaulting to white on clean flash;
    - Slimrecents card/text color;
    - DSPManager: add loudness enhancer
    - AdAway app updated to version 2.9.1;
    - Attempt to fix DSPManager of crashing;
    - Attempt to fix force close in Dialer/Settings
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  6. #45
    Androidiano VIP L'avatar di Nautiluz
    Nov 2013
    caput mundi
    GNEX, Nexus 6
    Ringraziato 798 volte in 647 Posts
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Build 14-9-14
    stavo provando a scaricarla, ma ci vorrebbero 2 ore abbondanti....... bel server! ....sta bene così!!!
    Nexus 6--> NitrogenOS 7.1 /f2fs
    GNEX--> [GNEX unified] OMNI 4.4.4
    - cMetal ext4/f2fs NautyTRASP.
  7. #46
    Sep 2010
    ROMA
    Build 14-9-14
    Quote Originariamente inviato da Nautiluz Visualizza il messaggio
    l'ho uppata su mediafire..fatemi sapere...purtroppo ho segnalato al dev e non ha scelto un server migliore xD
    cm-11-20140913-crdroid-maguro.zip
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  8. Il seguente Utente ha ringraziato morfances per il post:
    Nautiluz (15-09-14)
  9. #47
    Nov 2013
    caput mundi
    GNEX, Nexus 6
    grande! ora ci mette 6 minuti!!!
    Ti farò sapere come va... ma prima la devo convertire f2fs...
    [edit] la sto provando...:
    Sono riuscito a convertirla in f2fs inserendo direttamente il Fancy57_1 , e l'ho modificata con i miei vari NauTrasp .
    Sembra comportarsi bene, anche se la prima installazione ci ha messo UNA VITA !
    Ha un po' di opzioni in meno della Liquid in generale, tipo non ci sono le 1000 opzioni che ci possono essere sulla scelta del tipo batteria sulla status bar, meno scelte sulla doppia funzione dei tasti navbar o ringbar e altre piccole cose a cui ormai mi ero abituato....
    Mentre è in carica non c'è il lampetto o nulla che si muove sulla batteria....
    Però ci sono i tasti volume invertiti quando si ruota il cel!
    Non c'è l'opzione per rendere semitrasparenti i quick-tiles.... solo grigi e basta!
    Molto carina l'animazione per passare all'ultima app utilizzata.
    E' la prima rom che ho provato vove funziona correttamente la scelta dell'animazione di spegnimento totalmente disabilitata e il fade in uscita.
    AdAway non è integrato nella rom, ma solo come applicazione a sè stante (già presente)...: la creazione dei file host dava errore (in f2fs) e ho dovuto cambiare manualmente il percorso dei file, dalle impostazioni di AdAway (ma questa era una cosa riscontrata anche su altre rom).
    Privacy Guard molto invadente (l'icona spunta costantemente fuori sulla status bar), ma ben automatizzata (tra le impostazioni si può abilitare l'attivazione automatica su tutte le nuove app installate)
    sembra veloce e fluida... ma è appena messa....
    Ultima modifica di Nautiluz; 16-09-14 alle 00:03
  10. Il seguente Utente ha ringraziato Nautiluz per il post:
    morfances (16-09-14)
  11. #48
    Ringraziato 135 volte in 125 Posts
    visto che di la ho letto che hai già rimesso la liquid, come sono stati questi tre giorni e come mai hai cambiato?
  12. #49
    Nov 2013
    caput mundi
    GNEX, Nexus 6
    soprattutto per questo
    ...però anche perchè in ogni caso la Liquid è un pizzico più più reattiva.
    La crDroid è diversa..... a prima vista mi ha dato la sensazione di un Windows Phone: quando tocchi qualcosa, c'è quell'attimo di pausa e poi fila liscio come l'olio.... la Liquid invece magari non ha quei 500 frames al secondo, ma appena tocchi qualcosa è più reattiva.
    Come paragone, la sensazione che ho avuto con la crDroid è stata la stessa che ho avuto quando provai la Omnirom o Omnimetal..... e infatti non mi era piaciuta.
    Io distinguo bene reattività e fluidità... e preferisco la prima! Poi se con un kernel all'altezza si riesce ad avere entrambe, ben vengano!
    Ultima modifica di Nautiluz; 18-09-14 alle 00:18
  13. #50
    Sep 2010
    ROMA
    New build
    crDroid-4.4.4-20141010-OFFICIAL-maguro.zip
    – Synced with all CyanogenMod sources;
    – Fix incoming call ui not staying disabled;
    – Option to hide powermenu from secure lockscreen;
    – Option to Force Expanded Notifications if supported;
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
