Pagina 22 di 167 primaprima ... 1220212223243272122 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 1668
[ROM][UFFICIALE][KK 4.4.x]LiquidSmooth MAGURO
  1. #211
    macijeep
    Da XDA
    3.0 just released , saw this from the LiquidSmooth facebook page
    *3.0 Feature list*
    HALO Credit: PA/cristinamatos/xjcook/beerbong
    New CM Theme Chooser/Engine
    OmniRom App Circle SideBar Credit: SquadZone
    Allow Disablin of FC messages Credit: jmztaylor
    PEEK Credit: PA
    Allow notification virbaration during calls Credit: maniac103
    Gesture Unlock Credit: 0xD34D
    LockScreen Notifications Credit: AOSPAL
    Development Shortcut Credit: sarbyn
    Switch Recent panel styles Credit: cristianomatos
    BatteryBar Credit: cphelps76
    Status bar notification count and signal style Credit: burnsra & rmcc (cm)
    Status bar clock font style Credit: daxxmax
    Network speed indicator Credit: htchoi1995
    Time-context headers to the notification header Credit: Xplodwild
    Ram Bar Credit: cristianomatos
    Cistom Clear recents button Credit: cristianomatos
    Camera Button Support Credit: CM
    On the Go mode Credit: Evisceration
    Custom Lockscreen wallpaper and blur Credit: david96
    Audio Theme support Credit: Xplodwild
    Battery around unlock ring Credit: Xplodwild
    Gesture Anywhere Credit: 0xD34D
    Active Display Credit: 0xD34D/AOSPAL
    Alternate default app picker Based on @kufikugel 4.3 idea
    Toast Animations Credit: XuiMod
    Custom ProgressBar Credit: GwonHyeok
    Custom Scolling values Credit: Squadzone
    WakeLock Blocker Credit: Squadzone
    Muliuser support for phones Credit: AlmightMegadeth00
    IME Animations Credit: Squadzone
    Custom System Animations Credit: Steve Spear
    Battery Saver Mode Credit: OmniRom/timpohladthomas
    Everything Below this point is from SlimROM and is included in LiquidSmooth
    SlimPIE
    Quiet Hours
    Slim Recents
    LockScreen Style
    Notiifcation Reminder
    Hardware key rebinidng
    Custom Carrier label
    Smart pulldown
    ADB over network
    GlowPad Torch
    Advanced Reboot
    Listview Animations
    Liquid Dungeon
    National Roaming
    Custom Tiles
    flip to Mute/Reject Call
    Incoming call in background
    Hide usb debugging notification
    Stylus Support
    Stylus Gestures
    Notification Drawer Style
    LockScreen pin shuffler
    Quick Unlock
    Statubar Brightness control
    Volume rocker wake
    Safe headset volume
    Privacy Guard
    Statusbar clock and date style
    DRDevs.com Android Hosting
  2. I seguenti 2 Utenti hanno ringraziato macijeep per il post:
    giupa87 (15-05-14),LuCiolla90 (15-05-14)
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da macijeep Visualizza il messaggio
    Da XDA
    *3.0 Feature list*
    PEEK Credit: PA
    SlimPIE
    Quiet Hours
    Slim Recents
    LockScreen Style
    Smart pulldown
    ADB over network
    GlowPad Torch
    Advanced Reboot
    Listview Animations
    Liquid Dungeon
    National Roaming
    Custom Tiles
    Stylus Support
    Stylus Gestures
    Quick Unlock
    Volume rocker wake
    Safe headset volume
    Privacy Guard
    gia detto xD
    forse avevo scritto troppo piccolo...
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  5. #213
    Androidiano VIP L'avatar di giupa87
    Gela, Italy, Italy
    Galaxy Nexus
    Ringraziato 225 volte in 194 Posts
    Aspetto qualche opinione prima di provarla. Dal changelog si legge al solito new cm theme engine..., un utente su xda ha già avuto 4 fc della ui in 30 minuti.
  6. #214
    Sicilia
    Sony Xperia Z2
    Ringraziato 78 volte in 66 Posts
    Con quale kernel la consigliate? Ho una vanir mi trovo benissimo ma alcuni giochi non vanno..restano le schermate vuote senza testo. Avete mai avuto problemi del genere con questa rom?
  7. #215
    Senior Droid L'avatar di shocker94
    LG D855 32GB
    Ringraziato 49 volte in 45 Posts
    Io uso il dirty fancy 51 reloaded+ e mi trovo benissimo.
  8. #216
    Sep 2010
    ROMA
    Quote Originariamente inviato da giupa87 Visualizza il messaggio
    Sembra che da quando hanno introdotto sto maledetto theme engine della cm si stiano ..anando tutte le rom!!
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. #217
    Androidiano VIP L'avatar di Alkemix
    TRAPANI
    GALAXY NEXUS
    Ringraziato 2,219 volte in 1,084 Posts
    Impressioni su Liquid official
    Configurazione: tutto stock (anche il kernel, l'ho lasciato a posta)
    La rom soffre di grossi problemi in fase di installazione apps in background... diventa lenta al limite dell'usabilità come la c-rom che provai non molto tempo fa...
    Sembra veloce la rom ma quando si installano apps e si prova ad abbassare la tendina notifiche tutto diventa lento e scattoso al limite dell'usabilità.
    La rom non è assolutamente stabile...
    Volete subito mandare in crisi il sistema? Procedete nel seguente modo:
    Provate ad impostare i ring target in "navigation" .. dopo che avete impostato i target con 2 custom apps oltre al target "ricerca" e uscite dal menu navigation per provarli quindi premendo e tenendo premuto il tasto home il systemUI crasha di colpo e non si riprenderà più.. scompaiono i softkeys e da li crashes a ripetizione... soluzione ? Riavvio forzato o togliere la batteria ma non risolvete il problema perchè al riavvio si ripresenterà lo stesso problema... anche wippando tutto (wipe system compreso) il sistema non si riprenderà più, evidentemente si sarà pure corrotta la partizione data per qualche motivo... quindi nuovamente factory reset e full wipe, ecco la soluzione...
    Non ci siamo proprio per niente...
    Io lascio definitivamente kitkat (mi ha proprio stancato) ... tra qualche giorno devo partire e mi serve un Nexus stabile...
    P.S. Ma io dico togliere questo maledetto Theme engine che io tra l'altro non uso no eh? Non funziona bene? Non sapete svilupparne uno decente? Ok toglietelo per diamine ! Niente temi, ma chi se ne frega ! Ma almeno rendete utilizzabile il sistema !
    Ultima modifica di Alkemix; 15-05-14 alle 13:43
    Il duro lavoro condiviso gratuitamente va rispettato, non calpestato !
    SuperMIUI ROM 4.2.2 modificata e convertita a F2FS e resa compatibile con TWRP: kernel dfk 1.5 F2FS MIUI edition inside !
  10. I seguenti 5 Utenti hanno ringraziato Alkemix per il post:
    giupa87 (15-05-14),gnex88 (15-05-14),Kainen (21-05-14),LuCiolla90 (15-05-14),Mastrolindo91 (15-05-14)
  11. #218
    Gela, Italy, Italy
    Galaxy Nexus
    Io come official dichiarerei quella del 13 aprile ::
  12. #219
    Senior Droid L'avatar di LuCiolla90
    Pisignano di Lecce
    Asus Zenfone 2 ZE551ML
    Ringraziato 178 volte in 150 Posts
    Dopo quello che ho letto qui e su xda riguardo la liquid mi sa che mi manterrò sulla vanir a vita visto che a molti giorni dall'installazione (con tante apps sopra) ancora va una scheggia e a consumi stiamo molto ma molto bene (con il dfk r+).
    Il thanks rende sempre felici: datelo!
    Ogni messaggio di assistenza sarà cestinato!
    DEVICE: Asus Zenfone 2 ZE551ML
    ROM: Stock MM
    KERNEL: Stock
    MODS: No
    LAUNCHER: Nova Prime
    RECOVERY: TWRP
  13. #220
    Gela, Italy, Italy
    Galaxy Nexus
    Io mi sono leggermente stancato tanto che mi sa ritornerò alla purity
