Pagina 14 di 18 primaprima ... 41213141516 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 175
[ROM][UFFICIALE][KK 4.4.x]Resurrection Remix MAGURO
  1. #131
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Godetevela!!!Per quanto detto qualche post fa...dovrebbe essere l'ultima build
    # Resurrection Remix KitKat 4.4.2 - v5.1.5-20140609 # Basic
    - Navigation bar dimensions
    - Ability to disable hardware keys via nav bar settings
    - Add android:key in hardware keys enable/disable option to forward enable this option
    - Themes: Delete icon resources during uninstall
    - Themes: remove unused code
    - Themes: uninstallThemeForAllApps shouldn't check if map is empty if it's null
    - base: remove extra checks
    - Don't cleanup overlay mapping for non-theme apps
    - appops: enforce appop for bluetooth disabled action
    - About Resurrection: devcard layout - fix FC devcard on lanscape mode
    - settings: FC on quick settings editor on tablets without a vibrator*
    - Add a HAF access permission*
    - Fix layout recreation check
    - CameraTile: Launch default gallery app when long pressing active camera tile
    - SystemUI: prevent NPE on clear recents double press
    - MtpDatabase JNI: Fixed a memory-leak in getObjectPropertyValue().
    - Correct stride for drawing to cached glyph bitmap
    - Use alpha channel instead of red in drawCachedGlyphBitmap
    - Temporarily hide lock screen unlock targets if opening a widget*
    - fw: media: Handle NPE due to threading race*
    - FW: LS Notification: fix FC when an expanded notification gets reposted without bigContentView
    - fix derp on INotificationListener
    - WallpaperCropper: do not display null bitmaps*
    - Make theme change broadcast a protected broadcast.
    - Reduce memory leaks by removing all views.
    - appops: do not prune apps that are not present
    - apn: national roaming for ONO (Spain)
    - fix more keyguard derp
    - Mms: Clear notifications and mark messages read in certain situations*
    - galaxys2-common: fix front cam video recording
    - Recovery - Version 6.0.4.9
    - included all cm-11.0 m7 updates
    - Check out the source activities for more detailshttps://github.com/ResurrectionRemix
    Ultima modifica di morfances; 09-06-14 alle 22:16
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. Il seguente Utente ha ringraziato morfances per il post:
    PrimaScelta (10-06-14)
    noooooo l'ho appena installata e gia mi stavo innamorando! con le altre rom tanti problemi, troppa rom occupata.. questa rom è leggerissima, mi occupa meno della metà di rom che non l'ho mai vista così libera e fino ad ora non mi ha dato nessun tipo di problema.. per quale motivo dovrebbero stoppare gli aggiornamenti? non capisco!!
  5. #133
    Sep 2010
    ROMA
    Quote Originariamente inviato da Guidojk Visualizza il messaggio
    il dev migrerà su altri progetti....prima era su beanstalk...poi resurrection ora chissa xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  6. #134
    Mi hanno detto della liquid molto personalizzabile... Voi che mi dite?
  7. #135
    Sep 2010
    ROMA
    Quote Originariamente inviato da antoniojr86 Visualizza il messaggio
    Dico che qui siamo nel thd della resurrection
    Cmq come personalizzazioni siamo li
    fine OT
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  8. #136
    Scusami, ma tanto ormai c'è poco da dire su questa rom... Scusa per l'ot
  9. #137
    Ringraziato 23 volte in 13 Posts
    Dai commenti letti sembra che questa rom faccia le differenze un pò su tutte, voglio installarla!
    Il mio è un g nexus con una vecchia custom rom 4.2
    A me interessa anche un Kernel che faccia le differenza come prestazioni ed efficienza energetica, ho letto molto bene del dirty fancy kernel ma non so quale scaricare perchè sul link mediafire ci sono varie versioni
    Per fare una corretta installazione cosa mi consigliate oltre alle istruzioni in prima pagina?
    Le gapps sono comprese nell'ultima buil della rom o vanno scaricate a parte?
    Sep 2010
    ROMA
    Quote Originariamente inviato da Plutonash Visualizza il messaggio
    beh diciamo che è una buona rom 4.4.2 (ora stanno anche le 4.4.3)
    [OT]
    Nel tuo caso visto che provieni da una 4.2 e quindi ti mancano dei passaggi intermedi (4.3 e 4.4.2) ti consiglio prima tramite toolkit di dare una bella piallata.
    Per piallata intendo che tramite toolkit (di wugfresh) metti la factory image 4.3 (stock 4.3)
    In questo modo parti da un sistema pulito.
    Dopo di che segui le indicazioni in OP e con i dovuti wipes flashi rom e gapps( non sono incluse ) ed eventuale kernel
    Per il kernel l'ultimo se vuoi mettere il dfk metti l'ultimo dfk1.4 sabermod altrimenti ottimo è anche il fancy kernel (per esempio questo )
    Se hai altri dubbi sulla rom scrivi qui..altrimenti per il resto scrivi in sezione modding generale
    [/OT]
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. Il seguente Utente ha ringraziato morfances per il post:
    Plutonash (16-06-14)
  12. #139
    Ma secondo voi che Kernel va meglio su G Nexus?
  13. #140
    Senior Droid L'avatar di vismo
    LG G3
    Ringraziato 166 volte in 146 Posts
    Secondo me il dfk è un gran kernel
