New builds DALVIK e ART
LS-KK-TREX-2014-10-24 maguro (DALVIK and Optimized ART)
* frameworks/base/
50e643c Tinted Nav/Status Bar (1/2)
cda9930 'Delete application' development shortcut
* packages/apps/Camera2/
6c2b96a Camera2: Fix crash on cameras with 6mp 16:9 resolution
* packages/apps/Settings/
5d0df8a Tinted Nav/Status Bar (2/2)
699e3e4 Revert "TRLS for settings"
af838d3 Modify the Development shortcut help text
7676316 Fix German translation
* frameworks/base/
19d1941 MTU should be 1358 as per 3GPP standards, especially for LTE radio interfaces.
a34cbf3 NLP Combo feature : screen network locations
3199734 Keep people from complaining about logcat spam
516c5ab gps: LocationManager CTS proximity test fix
* hardware/qcom/audio-caf/
02e7d32 hal: Fixes for 8916 features
* hardware/qcom/keymaster/
f6ae49b qcom: keymaster: Include keymaster in all targets
34cee56 Add 16:9 to strings
97c8e66 Support all known DPI values
* system/core/
79dfaa1 adb/fastboot: Support SuperSpeed USB devices
* vendor/samsung/
7690ec7 klte-common: thermal-engine does not run without libthermalioctl.so
* external/koush/Superuser/
14db056 Automatic translation import
* external/stagefright-plugins/
f24eecb ffmpeg_source: add url check to android_open
8350203 hal: Update msm8916 library with new feature support
c3d05a8 hal: Don't mess with primary output
900741c hal: Allow msm8916 to enable compress voip/compress capture/dolby
* packages/apps/Bluetooth/
76dbe28 Automatic translation import
* packages/apps/BluetoothExt/
9b99138 Automatic translation import
cd9fe44 Camera2: disable the shutter button when not previewing
46f2f7c Camera2: the menu button should not visible in some cases
b5e5e59 Camera2: fix flash light turn on after resume camera activity
0b9bae7 camera2: Fix memory leak when suspend/resume camera
95f9cda Camera2: Add option to set max screen brightness
d989a5f Camera2: add new mime type for panorama picture
0121f80 Camera2: save the picture when rotate the device
e0a2e31 Camera2: wait for previous saving picture done during panorama capture
241b944 Camera2: some aapt warnings cleanup
a11ce3b Camera2: fix white balance still work when turn on the HDR mode
79c0c05 Fix WB indicator override
d97814a Revert "Camera2: Fix WB onScreenIndicator when some are settings filtered out."
451a727 Camera2: fix The flashlight still is on after set scene mode not auto
2cec466 Camera2: update the flash icon when set HDR on
6f5cb27 Camera: Block HFR option for Video HDR
0cb7b88 Camera: Disable DIS option for unsupported resolution
d1a6002 Camera: Block DIS and Timelapse for HFR
7c9c584 Camera: Check if codec supports HFR resolution/fps.
08a1edd Camera: Change video capture duration with HFR
3b8cbff Camera2: Fix ANR when switching camera during AF
5c1231c camera: Override color effect when scene mode is active
529889f Camera2: fix unresponsive shutter button after failure
e7c249e Camera2: Don't report incorrect supported picture formats
e8f9779 Camera2: fix camera crash when mPieRender is null
a380db3 Camera2: Fix video duration is wrong issue
50d36b2 Camera2: fix a camera status bug
9f87f1e Camera2: Do not restart preview to update flip params during orientation change.
562fcac Camera2: fix start preview when hdr is on issue
b4990d6 Camera2: Still popup tips when change scene to other after turn off HDR
0e4ff22 Camera: Disable HDR when scene mode is other than auto
9ca415b Camera: open Camera and start Preview in a seperate thread.
77468c1 Automatic translation import
* packages/apps/LockClock/
607bb5b Automatic translation import
* packages/apps/SoundRecorder/
c5bb502 Automatic translation import
* packages/apps/ThemeChooser/
070d645 Automatic translation import
* packages/providers/ThemesProvider/
67ae00a Automatic translation import
07a3e50 Change Regulatory Info Activity to prefer string over image
b771aaa Settings: Create SAR level preference, allow overlay.
* frameworks/base/
46f3e9e More fixes to carrier logo on statusbar
548d42c Support showing carrier/provider logo on statusbar [1/2]
ee80e54 Support showing carrier/provider logo on statusbar [2/2]
ad1bfba Automatic translation import
544f3ea TRLS for settings
* vendor/samsung/
944da0f ks01lte: Update libmmjpeg_interface.so to KK version.
acb91b6 ks01lte: Update some blobs.
* external/openssl/
87cf31e Fix for CVE-2014-0195
086ddd3 Fix for CVE-2014-0224
ffd2c61 Additional CVE-2014-0224 protection.
73946d4 Fix CVE-2014-0221
2a25381 Fix CVE-2014-3470
* build/
8392fbf build: Default to dtbToolCM
* frameworks/base/
82d087e Themes: Force recompiling common resources when scanning theme
e32adac new pfad Dinosound
* packages/apps/KernelTweaker/
2839fb0 Automatic translation import
* packages/apps/LiquidFileManager/
728ad2d Automatic translation import
* packages/apps/LiquidLauncher/
7489905 Automatic translation import
* vendor/liquid/
e411194 Add kltedv (vodafone variant)
14d1159 test Audio
6044488 Update common_phone.mk
6be160c ups :-)
d8c3633 enable swiqi
bdcb5fb clean up
* android/
d0bf70e fix error sync
46fb342 revert (lib hardware to trex)
e77c789 lib hardware to trex
342fd64 Automatic translation import
1c87ad3 Automatic translation import
a280feb Automatic translation import
69dca15 Automatic translation import
4d474cb Camera: Disable video HDR on devices that don't support it
8aa0a97 Automatic translation import
0527487 Update settings_headers.xml
fa119ab fix
23b2e5f derp
d32d165 new sequence (WIRELESS and NETWORKS)
e23da0e Automatic translation import
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di morfances; 17-11-14 alle
