Pagina 1 di 11 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 103
[ROM][KK- 4.4.x][AOSB] Maguro
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Ciao a tutti , vi presento un 'altra rom interessante per il nostro Gnex. Si tratta della AOSB ed è su base CM11 ma con un sacco di personalizzazioni
    Features
    Screenshots
    Changelog
    Secondo post
    Downloads
    Build 1.3.7 (4.4.4)
    OLD Builds
    Gapps Banks
    GAPPS alternative
    Installation
    wipe data factory
    wipe cache
    wipe dalvik cache
    wipe system (o format system su cwm)
    flash rom
    flash gapps
    reboot
    Ultima modifica di morfances; 10-09-14 alle 13:12
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. I seguenti 5 Utenti hanno ringraziato morfances per il post:
    fedelamb (15-02-14),Luisyfer (15-02-14),skizzomsn (16-02-14),Tardis00 (19-02-14),TheAlmighty (15-02-14)
    Sep 2010
    ROMA
    Changelogs
    AOSB 1.3.7
    New Features/Improvements:
    Android 4.4.4 R2
    AOSB: New BootAnimation supported all devices!
    Frameworks: SlimROM Heads up
    Swipe left for notifications and recents
    Swipe left an app in recents to open in floating mode
    Swipe down an app in AOSB recents to open in floating mode
    ActiveDisplay: Huge Fixes/improvements
    Sync AOSPA Floating window Changes with AOSB
    Implement App circle sidebar
    Floating widow: snap modes (up, down, left, right)
    HALO windows moveable and scaleable
    Over scroll effects
    code fixes HOVER And HALO
    Navbar: reimplement navbar cursor keys
    User defined wifi/usb tether network.
    Torch: fix torch toggle delay on boot
    Make torch shutdown by camera usage work properly
    Download: add to support pause/resume download by manual
    Bring DownloadManager API inline with AOSPA
    Send a boost hint when a key on the navbar is pressed
    MultiWindow: Improvement and more [buggy]
    Fix lock screen notifications proximity sensors
    Add APN for Tele2 4G, Claro (Panama), Tiscali Mobile (Italy), TIGO and VOX for Paraguay
    Themes: Fixes on Style, boot animation, and wallpaper , etc
    NavRing: Fix visibility issues on some devices
    SystemUI: New Smart Pull-Down
    SystemUI: Smart Pull-Down - Any Notification
    SystemUI: Over scroll effects
    SystemUI: Weather
    SystemUI: show statusbar icon if quiet hours is active
    SystemUI: Fix crash of SystemUI (OutOfMemory)
    SystemUI: Fix SystemUI crash on Recent App
    SystemUI: Fix crash of SystemUI (AOSB Recent Landscape)
    SystemUI: Show notification when charging.
    SystemUI: Fix Airplane mode toggle issue using Quick Access menu.
    SystemUI: Update UserTile from Google 4.4 code
    SystemUI: fix double tap to sleep not working with secure lock screen
    SystemUI: Swipe to float mode for notifications and recents
    SystemUI: Fix tile fliping
    HeadsUp: Fix dismiss on back key press.
    AOSB Bubble: Integrate with gesture SlideLayer
    AOSB OTA: Gapps auto update
    AOSB OTA: integration with Sourceforge download servers
    Settings: Search anywhere for anything !
    Settings: Driving Mode
    Settings: Heads up
    Settings: Show heads up at the bottom of the screen
    Settings: Implement App circle sidebar
    Settings: Vibration options customizer
    Settings: App Sidebar, Support for Configurable Trigger Region
    Settings: Protected apps
    Add native heads up support on dialer
    Remove Old non-intrusive dialog
    Remove Old Wakelock Blocker
    Mms: Fix thread view bugs also in black UI
    Mms: Fix FC issue that when tapping contact icon many times
    Mms: Add native heads up support
    Mms: Emoji and Smiley support
    Mms: Add quick emoji button next to text input
    DownloadProvider: add to support download into sdcard storage
    DownloadProvider: fix the crash when rotate screen.
    Add to support pause/resume download
    DownloadNotifier: Standardize play store and browser downloads
    DownloadNotifier: Normal notification for singles
    DownloadProvider: Add transfer speeds in notification
    Camera2: remove the pause button when timelapse is on
    Camera: Fix beauty mode & slow shutter indicator
    Camera2: Fix camera application memory leak
    Camera2: Add 50MP, 37.5MP resolution entry
    Camera: Fix JPEG quality DB update
    Blacklist call recording for US/EU mccs, remove sysprop flag for enabling
    Call recording service implementation, show recordings and allow playback in call history
    Dialer: Refactor SmartDial for additional languages
    Hardware: Add high touch sensitivity support
    Devices Blob:
    msm8960-common: kk gps blobs
    msm8960/express: ril blob dance
    HLTE: Update to GSM KK blobs
    klte: use prebuilt NFC HAL
    serrano: Remove prebuilt GPS blobs
    msm8960-common: update mpdecision/libqc-opt
    serrano: Massive KitKat blob updates
    klte: Import proprietary libs
    kltespr: Import proprietary libs
    klte: Initial import of klte
    jflte: gpe 4.4.4 adreno
    jflte: use gpe camera hal
    jflte: Clean up and remove extra libs
    hammerhead: Update proprietary libs
    KitKat Camera Blobs
    m7spr: update blobs from 5.03.651.3 RUU
    s4-common: update wcnss blobs from mint 9.2.A.0.295
    Samsung Kernel:
    Update WiFi drivers from 1.61.47 --> 1.61.58
    Boeffla sound 1.6.6
    prevent freeze on smart dock plug
    updates ROW to V4.
    tweaks SIO a bit.
    add more governor
    add more schedulers
    enable conservative
    update mali driver
    mali r3p1 for devices that need it
    audio: Remove hackaround for broken audio in first call
    Telephony And Dialer (Technical):
    Contact photo in call log can not change in time
    Dialer: revert old non-intrusive dialoger for incoming calls
    Dialer: Blacklist call recording for Australia.
    Add up navigation to call barring activity.
    Fix handling of unavailable network in call barring activity.
    Fix FC when phone type switched from GSM to CDMA.
    Delay setting of active subscription
    Fix crash during back to back emergency calls.
    Fix issue that phone would crash when PLMN search
    TeleService: Return to previous activity when click back icon in Dual SIM settings
    TeleService: Remove the option menu of the restore defaults
    Fix crash when call to voicemail with no number.
    TeleService: Do not save an empty quick respond message
    TeleService : Disable network mode select when it is GSM only
    TeleService: Remove "vibrate when ringing" from multi sim call settings
    TeleService : Add networkmode changed listener and CDMA APN item
    Fix the failure when doing unit test
    TeleService: Highlight the forbidden network operator
    TeleService: Remove the function of MO call on APM
    TeleService: Support call waiting on CDMA phone
    TeleService: Hide sim label when calling sub is absent
    Disable data in manual PLMN search on non-dsda mode.
    Add MSIM check to avoid phone app crash
    Phone: Disconnect current call if there is an active call on other sub
    MSIM: on permanent failure cause, don't redial
    Fix call barring always request from default sub
    Telephony: Add Multi SIM support for voicemail ringtone
    TeleService: Add FDN seting for CDMA network type
    MSIM(DSDA): if any sub is active dont disconnect BT
    fix cannot end videocall issues after NFC read contact and lauch another call
    Make incoming call screen style configurable
    no quote
    Ultima modifica di morfances; 10-09-14 alle 13:09
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    fedelamb (15-02-14),skizzomsn (16-02-14)
  6. #3
    Sep 2010
    ROMA
    OLD CHANGELOGS
    no quote
    Ultima modifica di morfances; 10-09-14 alle 13:10
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #4
    Androidiano VIP L'avatar di erghetto
    Napoli
    Galaxy S6 Flat SM-G920F
    Ringraziato 385 volte in 344 Posts
    una cmRemix insomma XD più o meno hanno tutto sia questa che quella. forse questa (dando un occhio veloce agli screens) ha anche qualcosa in più
    [Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
    [ROM] Noble Nougat Experience 4.5
    [kernel] Kiboi kernel 2.5
  8. #5
    Sep 2010
    ROMA
    Quote Originariamente inviato da erghetto Visualizza il messaggio
    si ti consiglio di provarla..sembra peraltro piu stabile xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. #6
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    Eccomi, presente.......anche se i Pie Controls non li ha uff..............
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  10. #7
    Androidiano L'avatar di Gabboplano
    Reggio Emilia
    Samsung Galaxy Nexus
    Ringraziato 61 volte in 60 Posts
    Quote Originariamente inviato da dado70 Visualizza il messaggio
    Ma questa tua fissa per i PIE da dove viene? lol
    La BeanStalk li ha comunque
    Forlimpopoli (FC)
    Ė davvero così, una fissa ahahah... Però escono queste nuove Roms senza di essi, come mai :-D no no ci sono diversi modi poi per farli apparire..
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  12. #9
    Senior Droid L'avatar di LuCiolla90
    Pisignano di Lecce
    Asus Zenfone 2 ZE551ML
    Ringraziato 178 volte in 150 Posts
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Tu la monti con la prima versione dei kernel della cm-remix o con la seconda versione?
    Vorrei provarla stock: ho letto che il kernel è quello cyano quindi il touchcontrol dovrebbe funzionare senza cambiare kernel...no?
    Il thanks rende sempre felici: datelo!
    Ogni messaggio di assistenza sarà cestinato!
    DEVICE: Asus Zenfone 2 ZE551ML
    ROM: Stock MM
    KERNEL: Stock
    MODS: No
    LAUNCHER: Nova Prime
    RECOVERY: TWRP
  13. #10
    Sep 2010
    ROMA
    Quote Originariamente inviato da LuCiolla90 Visualizza il messaggio
    monto il kernel del 22 gennaio linkato nel thd dei kernel touch control
    col suo stock cyano ho provato ma non funziona!!
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  14. Il seguente Utente ha ringraziato morfances per il post:
    LuCiolla90 (16-02-14)
