Pagina 8 di 22 primaprima ... 67891018 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 215
[ROM][4.4.x]MAHDI ROM Maguro
  1. #71
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da JackSlaterIV Visualizza il messaggio
    Installata la final, confermo tutto ok.
    Adesso c'è da sperare in una Mahdi Lollipop.
    Quote Originariamente inviato da Gianlucarena10 Visualizza il messaggio
    Migliore rom kitkat secondo me
    fireworks e mahdi sono le migliori al momento xD
    si gli sviluppi ci saranno..l'ho letot sulla loro community
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    Gianlucarena10 (07-11-14),JackSlaterIV (07-11-14)
    Androidiano L'avatar di JackSlaterIV
    Sep 2014
    Mi5, LG G3, Galaxy Nexus
    Ringraziato 28 volte in 25 Posts
    Pare che la nuova Lollipop by MAHDI si chiamerà Euphoria-OS.
    Letto sul profilo G+ di MAHDI.
    https://plus.google.com/communities/...22179206449806
    Euphoria-OS profilo G+:
    https://plus.google.com/communities/...82851167273031
    Quoto un messaggio di Mahdi sul thread del N5
    Originally Posted by Mahdi786
    Hello everyone, just a little headsup. Mahdi-Rom is finished and I've been working on lollipop for the last couple of days now.
    The new ROM will be called Euphoria-OS and the github is here https://github.com/Euphoria-OS, things will move slowly and its not going to be like this ROM, meaning that it wont be overloaded with features, I will keep the same routine as before so I will release test builds with features before they are merged into stable. I kind of like how lollipop is so at the moment there are no plans to start loading features in. I'm already running a build with preview binaries and kernel, also enabled Ambient Display which running well too. At the moment Gapps are not very good and there are also issues with recovery, Dees-Troy is working on merging lollipop recovery into TWRP so we should have a new version soon. Google should release images and kernel soon so we will have proper binaries and proper kernel to match.
    So stay tuned and look out for the new thread which will come soon.
    Ultima modifica di JackSlaterIV; 08-11-14 alle 13:46
  5. Il seguente Utente ha ringraziato JackSlaterIV per il post:
    morfances (17-11-14)
  6. #73
    Senior Droid L'avatar di DeathHawk
    Il Mondo Intero
    Nexus 5, Redmi Note 6 Pro
    Ringraziato 63 volte in 58 Posts
    ma c'è già una versione flashabile di sto euphoria os con almeno la ril funzionante? xD
    Membro semiattivo di androidiani..
    I'll turn you to the Dark Side
  7. #74
    Androidiano L'avatar di peps92
    Trapani
    Gnex; Hua.P9 Lite; Galaxy A71
    Ciao, io vengo da Slimkat (prima PA) e mi ci trovo molto bene, solo che ogni tanto quando lo schermo si spegne devono passare tipo 40-50 secondi per riaccendersi.. vorrei provare questa rom. Ho kernel della slimrom, 3.0.101-Slim-kk-alpha etc.. quale versione del francy kernel dovrei flashare? Ce ne sono di due tipi.. Grazie!
    Ultima modifica di peps92; 08-11-14 alle 15:40
  8. #75
    Sep 2010
    ROMA
    Quote Originariamente inviato da peps92 Visualizza il messaggio
    Quella RAM fixed r60
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. Il seguente Utente ha ringraziato morfances per il post:
    peps92 (09-11-14)
  10. #76
    Senior Droid L'avatar di Vahelin
    sull'amaca in giardino...
    Honor 9 EU
    Ringraziato 41 volte in 37 Posts
    Monto la slimkat con kernel stock e non ho questo problema dello schermo
  11. #77
    Trapani
    Quote Originariamente inviato da salemt87 Visualizza il messaggio
    Non so, la slim è sicuramente molto meglio della PA come consumi e prestazioni, ma molto spessa mi capita questo fatto sopratutto quando ricevo messaggi o notifiche.. anche io kernel stock nella slim.. oggi penso di provare questa rom
  12. #78
    Trapani
    Ho avuto un problema nell'istallazione.. dopo aver fatto i wipe e istallato la rom, durante l'istallazione delle gapps mi spunta segnale di errore della memoria, dice memoria insufficente necessari tipo 1036kb tu hai solo 16kb liberi... io ho 3gb liberi nel telefono -.- ; per fortuna avevo altre rom e ho rifatto wipe e messa un'altra rom per ora (aokp).. come posso risolvere?
  13. #79
    Sep 2010
    ROMA
    Metti le mini gapps PA
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  14. #80
    Trapani
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Grazie per la risposta, ma erano proprio le mini gapps PA quelle che provavo a istallare.. pesano 160mb circa
