Pagina 17 di 19 primaprima ... 71516171819 ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 182
[ROM]uXylon | Stable // Nightly [4.2.2][Linaro][Mako]
  1. #161
    Androidiano VIP L'avatar di Aetos
    LGoogle Nexus 4
    Ringraziato 280 volte in 210 Posts
    Nuova Build BMQ_
    07/08/13
    android:
    switch external/zlib to cm source
    Merge pull request #5 from CrispyCreme/jb4.2
    Add Evita Support
    Add Linaro 4.8.2 6/3 Build Toolchain
    Someone derped
    Add Media-Caf
    Sync jfltexx
    packages/apps/uTool:
    Use custom ActionBar background
    Update of some Simplified Chinese translations
    Remove transparency for Left Chevron
    Update of some French Translations
    Add hardware keys bindings into uxy
    Added some French translations.
    New category for Custom Colors (Quick Toggles) [1/2]
    New category for Custom Colors (Quick Toggles) [2/2]
    frameworks/base:
    Hardware key custom rebinding (1/2)
    android.policy: Fix launching home when waking the device with the home button again
    bugfix: allow recent apps dialog to work with menu long-press
    Frameworks: Adds ability to answer call with hardware HOME button (1/2)
    More options added to hardware key rebinding (1/2)
    Fix issue with hardware keys KEY ACTION comparisons.
    Framework: Add Home/Back buttons available for rebinding (1/2)
    Fix for navbar back/menu firing for longpress actions
    Camera button rebinding (1/2)
    [2/2] Permit home button wake to be configurable
    Derp duplicate
    derp again
    Code fixes
    Add permission that allows cancelling notifications from other apps.
    packages/apps/Settings:
    Settings: privacy Guard enhance app logic
    Update PG
    Revert "Use the new PreferenceDrawerActivity to make use of the navigation drawer UI."
    update Settings
    Merge branch 'jellybean' of https://github.com/UltimatumKang/and..._apps_Settings into jellybean
    Code fixes
    vendor/ukg:
    Change the way the Build Date is set (Auto-Update now) (MBQ)
    Merge pull request #1 from MBQsniper/patch-1
    Some changes
    Merge branch 'jellybean' of https://github.com/UltimatumKang/android_vendor_ukg into HEAD
    Update my OCD
    android/external/exfat:
    Add support for building on Android
    Handle 64-bit offsets correctly on Android
    Call exit instead of abort on unhandled errors
    Google Nexus 4 (Mako)
    Samsung Galaxy S II (i9100)
    HTC Desire (Bravo)
    Androidiano L'avatar di Erendal
    Grugliasco (TO)
    LG Nexus 4
    E proviamo questo aggiornamento _\m/ al momento sono state due le cose negative (ma non avevo la stable):
    - qualità pessima dell'audio in chiamata
    - hot reboot (o come si chiama quel reboot 'istant')
    Edit:
    L'aggiornamento ci piace! _\m/ La gestione dell'Hybrid Engine è ancora un po' così ma non usandola non mi pesa troppo. Domani mattina test audio.
    Ah, non ho testato la ROM con il suo kernel stock.
    Ultima modifica di Erendal; 10-07-13 alle 01:56
  4. #163
    LGoogle Nexus 4
    Quote Originariamente inviato da Erendal Visualizza il messaggio
    Edit:
    Quale hai provato? Quella di daxMax ("l'originale) o quella di MBQ?
    Comunque 0709 by MBQ:
    Pie status expanded (2/2)
    Fix string derp
    Derp strings and move up this feat
    packages/apps/Mms:
    external/fuse:
    Support for building on Android
    Add missing config.h for Android
    lib:fuse: -fno-strict-aliasing
    system/core:
    init: create mountpoint for fuse
    system/vold:
    UMS support with any volume, not only primary (1/3)
    vendor/ukg:
    cm: Add ntfs-3g and exfat tools to the build
    frameworks/base:
    Pie Status Expanding (1/2)
    Revert "When DPM is updated while lock screen is inhibited, don't"
    Prevent notification acces via HALO on protected lockscreens
    Don't show pinned Halo))) apps on PIE (hide count, icons and text)
    Code fixes
    Merge branch 'jellybean' of https://github.com/UltimatumKang/and...rameworks_base into jellybean
    external/e2fsprogs:
    Fix dev time initialization for cache age caculation
    blkid: Add support for probing exFAT
    external/skia:
    Revert "Neon optimized implementation of S16_opaque_D32_nofilter_DX"
    Add shader for Clamp_S32_Opaque_D32_filter_DX.
    Add shader for Clamp_SI8_opaque_D32_filter_DX.
    Add shader for Repeat_SI8_opaque_D32_filter_DX.
    Add shader for Clamp_S32_Opaque_D32_nofilter_DX.
    Add optimized S16_opaque_D32_nofilter_DX blitter.
    Modify sample buffer size for larger displays.
    Add optimization of Skia S32A_Opaque blitter
    Add optimization of Skia S32A_Blend blitter
    Add optimized S32A_D565_Opaque_Dither blitter.
    exynos4: fimg2d acceleration
    skia: exynos4: add support for fimg2d3x
    Fimg2d3x: fix icon scaling issue with acceleration enabled
    Fimg2d: set fimg.isFilter in SkDraw::drawBitmap
    android:
    Track our vold
    derp..
    hardware/qcom/audio-caf:
    Merge branch 'cm-10.1' of https://github.com/CyanogenMod/andro...qcom_audio-caf into cm-10.1
    hardware/qcom/media-caf:
    dont use strict fix omx_vdec error
    HTC Desire (Bravo)
  5. #164
    LGoogle Nexus 4
    frameworks/base:
    Validate restored file paths against their nominal domain
    Ensure install-during-restore is like install-then-restore
    Add a delimiter between scheme and host
    libdrm: fix bad strncpy / snprintf calls
    Notification cancellation fixes
    Fix requery behaviour of MemoryCursor.
    FileUtils: add method to get UUID of a volume
    android/libcore:
    libcore: Better Enum fix for JDK 7
    Remove support for duplicate file entries
    Merge branch 'jellybean' of https://github.com/UltimatumKang/android_libcore into jellybean
    vendor/ukg:
    The Ultimatum Project
    Let accessibility feature instructions scroll.
    Add gesture based lockscreen security. [2/2]
    Dont enable Wi-Fi if it's not toggleable in flight mode
    Clamp date setting for the SetupWizard as well as Settings.
    Storage Settings: Allow user to trigger a volume rescan
    android:
    Update default.xml
    **MBQs Changes**
    Frameworks/base:
    Roboto Light font
    Change recents_return_to_launcher_enter animation duration to 300
    Change recents_return_to_launcher_exit to 300
    In string_toggles.xml, I renamed some strings to be a little more descriptive
    In colors.xml, I changed the status bar background to black
    Minor UI adjustments in styles.xml
    packages/apps/Mms:
    Holo theme
    build:
    -O3 again
    Use GCC 4.8 toolchain
    set TARGET_ARCH_ARM to be cross-compiled with arm-eabi-4.9
    packages/apps/HALO:
    Holo theme
    kernel/lge/mako:
    *governor_simpleondemand.c:
    define DFSO_UPTHRESHOLD (100) instead of 90
    if (dfso_upthreshold > 110 || instead of 100
    *cpufreq_interactive.c:
    set DEFAULT_UP_THRESHOLD to 95
    define DEFAULT_MIN_SAMPLE_TIME to 95
    Change "android:Theme.Holo" to "android:Theme.Holo.Light.DarkActionBar"
    Invert some icons (Sorry if theyre ugly)
    Reduce the lock animation duration to 165
    By MBQ
    Ultima modifica di Aetos; 11-07-13 alle 16:38
    HTC Desire (Bravo)
  6. Il seguente Utente ha ringraziato Aetos per il post:
    klp (11-07-13)
  7. #165
    klp
    klp non è in linea
    dopo tanti sbattimenti sono incappato quasi per caso in questa rom e non la cambio manco sotto tortura
    ho la versione del 4/7 presa direttamente dal profilo g+ di Daniel mm , chi ha provato, mi può dire se ci sono cambiamenti significativi nei recenti update ?
    comunque provatela ragazzi che va alla grande :P
  8. #166
    LGoogle Nexus 4
    Quote Originariamente inviato da klp Visualizza il messaggio
    Ti consiglio ti mettere la stable che trovi al primo post.
    Invece i recenti update che sto postando sono invece della ROM di MBQ_ (Developer che sta creando questa ROM sulla base di quella di Daniel MM alias daXmax).
    E devo dirti che mi piace molto quest'ultima, provala!
    EDIT: Non flashate l'ultima versione di MBQ_ ha parecchi bug
    Ultima modifica di Aetos; 11-07-13 alle 17:47
    HTC Desire (Bravo)
  9. #167
    Grugliasco (TO)
    LG Nexus 4
    Quote Originariamente inviato da Aetos Visualizza il messaggio
    Sto provando questa:
    uXylon by daXmax:
    - Official Stable 2.9.0
  10. #168
    LGoogle Nexus 4
    Provata anche io. La migliore!!
    HTC Desire (Bravo)
  11. #169
    klp
    klp non è in linea
    Ragazzi una domanda... Anche la stable che avete voi ha il layout delle impostazioni simile al dualpanel?... Non mi piace proprio e lo sai vorrei in stile normale.... :screwy:
  12. #170
    Filadelfia (VV)
    Samsung Galaxy S4
    Salve ragazzi, la nuova uxylon 2.9 si può flashare direttamente come aggiornameto sulla vecchia xylon 2.7.7? Grazie.
