in pratica questa Liquidsmooth è una Slimbean con il kernel Franco...
v.2.7 official 18/06/2013
perche' non seguite piu' questa rom?
e pure e un ottima rom ha un buon compromesso tra prestazioni e consumi della batteria e de molto stabile , e poi e di una personalizzazione unica :)
gia' la monto su gn2 da piu' di un mese , e prendendomi l'n4 sono andato a colpo sicuro ;) e anche su questo terminale e impeccabile :cool:
questo e il changelog della 2.7 come si puo leggere a anche halo ;)
- LIQUIDSMOOTH v2.7 CHANGELOG
- Frameworks: Dark Liquid v2.0 (kufikugel)
- Mms: enhance easy selector (mnm9994u)
- Lockscreen : Fix widgets disabled (Danesh)
- Contacts: Show voicemail only (mnm9994u)
- Updated Nova Launcher to v2.1.1 (TeslaCoil)
- Frameworks: Expanded Profiles (mnm9994u)
- Frameworks: Rework thumbnail handling (fun)
- Frameworks: Fix 0% battery QS tile (kufikugel)
- Frameworks: Fix Expanded Mode (mnm9994u)
- Phone: Hide additional blacklist separator (vixin)
- Removed Old Init.D System Tweaks (liquid0624)
- HALO: Option to pause the underlying app (tonyp)
- SystemUI: Reworked transparent layer (beerbong)
- New Liquid Blue Havoc Boot Animation (JaeKar99)
- Settings: Shortcut to Interface Settings (mnm9994u)
- Mms: Prevent FC in low memory conditions (M66B)
- Frameworks: fix QS shortcut picker icons (kufikugel)
- Phone: transparent in call widget (optional) (kufikugel)
- Updated DashClock Widget v1.5 Beta 5 (romannurik)
- Contacts: Fix number issue with T9 dialer (maniac103)
- Fixed bluetooth for grouper and manta (Stevespear426)
- Permit home button wake to be configurable (sam3000)
- Bluetooth: Fix MAP SDP record generation (maniac103)
- Telephony : New SamsungQualcommRIL Class (noobnl)
- Mms: Add Multi-Part and Split SMS Configs (mnm9994u)
- Wireless: Add triggers to change profile based on AP (grimpy)
- Frameworks: Clean up some possible memory leaks (kufikugel)
- Frameworks: several fixes for TouchKey light duration (kufikugel)
- SystemUI: Reduce Observers In BatteryBarController (kufikugel)
- Framworks: app loading: boost boost hints (AlmightyMegadeth00)
- Way More Linaro Butta Sauce, Using Latest 4.74 Toolchain (Linaro)
- Camera button rebinding and lockscreen action additions (corcoran)
- Phone: Add missing back icon in action bar of Network Operator (Kali)
- Don't assume any ringtone is present on external storage (maniac103)
- Settings: add an AlertDialog before to delete APN to avoid fails (Matthias)
- Settings: Organized Interface Layout & String/Layout Cleanup (liquid0624)
- Settings: Show application's package name in the "App Info" (chirayudesai)
- NotificationManagerService: fix typo on led off time variable (Mustaavalkosta)
- HALO notification system is now implemented and working (ParanoidAndroid)
- Fix the flipping animation sometimes being played when pulling QS (maniac103)
questo e downloand della 2.7 official mako del 18/6/13 : (QUI)
e se vi interessa qui potete trovare le inverted Gapps del 12/5/13 : http://goo.im/devs/BAKED/gapps/gapps...512-signed.zip
v2.8 is out!
aetos tnx per la segnalazione ;)
alla tua segnalazione aggiungo il changelog della v-2.8
- LIQUIDSMOOTH v2.8 CHANGELOG
- HALO: Minimal Style (daxxmax)
- HALO: Master Switch (daxxmax)
- HALO: Custom Colors (daxxmax)
- SMS: add middleware layer (koush)
- Add Statusbar Quick Peek (mnm9994u)
- Frameworks: Privacy Guard (cyanogen)
- Profiles: Add bluetooth triggers (grimpy)
- FIx: Phablet UI NavBar in landscape (gs2usr)
- Profiles: Add 2g/3g connection option (grimpy)
- Add IRDA system service for galaxy S4 (twendt)
- Frameworks: Fix Statusbar Quick Peak (kufikugel)
- Profiles: Add a profile picker activity (jruesga)
- Fixed bluetooth for grouper and manta (liquid0624)
- Speed up statusbar/notification drawer (IcecoldJelly)
- Use sticky broadcast to convey torch state (maniac103)
- Keep notification LED on while daydreaming (maniac103)
- Add Settings shortcut to Interface Settings Activity (mnm9994u)
- WebSettings: Move Liquid tag to the end of the user-agent (rmcc)
- Show application's package name in the "App info" screen (chirayudesai)
- Galaxy S4 devices uses Google Play Edition resources (noonl & cyanogen)
- Settings: fixed HALO options so now they stick and function (liquid0624)
- Close notification panel when swiping away the last clearable (maniac103)
- Frameworks: Reduce Navbar, Navrings, Slimpie observer footprints (kufikugel)
- Don't bring home to the front if we're opening a floating activity (beerbong)
- Profiles: Fix turning bluetooth on/off when its in intermediate state (grimpy)
- Settings: Rename 'Power sounds' to 'Charging sounds' and add summary (DvTonder)
- Galaxy S4 devices gps and wifi location can now be enabled together (invisiblek)
- Rolled back linaro patches, switched back to google gcc 4.7 toolchain (liquid0624)
qui il downloand della rom : Goo.im Downloads - Downloading Liquid-JB-v2.8-OFFICIAL-mako.zip
qui le gapps normali : Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
qui le inverted gapps : Goo.im Downloads - Downloading gappsinverted-jb-20130512-signed.zip
in download;) questa rom è una garanzia ......la usavo sul mio n2,mai avuto un problema!!!
ps...dopo il flash di rom e gapps,basta solo il factory reset??........ cache e dalvik ,non serve??
visto e considerato, che questo 3D e stato aperto e poi non e stato piu' seguito, e da l'altro non e neanche quello ufficiale del team liquidsmooth
chiedo hai MOD di sezione se si può aprire un altro 3d riferendosi alla rom liquidsmoonth OFFICIAL.
e veramente un peccato che questa rom e poco seguita qua, come già detto e una rom super fluida,personalizzazione al massimo e sopratutto assente da bug ;)
aspetto vostra risposta, grazie.
checco1926
