Pagina 12 di 471 primaprima ... 210111213142262112 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 4710
[ROM][4.4.4] SlimKAT
  1. #111
    Senior Droid L'avatar di mlucky
    Ringraziato 160 volte in 139 Posts
    Qualche anticipazione sulla prossima release, la 4...a mio modo di vedere, tanta roba davvero...il solito grande passo in avanti
    4.2.2 Build 4 WIP
    Changes and Features
    Add SlimPIE
    Add Custom Shortcut Tile
    Add SlimIRC
    Add Sound Recorder [deleted speechrecorder]
    Add Camera sound toggle
    Add Auto-Hide Statusbar
    Add Classic Recents switcher
    More Camera resolutions
    New Blacklist functionality
    Add ability to dismiss voicemail notifications
    Polish and cleanup SlimCenter
    Enhance NFC from upstream AOSP
    Add complete IBSS Support in base
    Tons and Tons of Translations... Thanks to all contributing in Crowdin
    And as usual Tons of optimizations and Fixes
    Added support for
    Galaxy Tab 2 7" Wifi
    Galaxy Tab 2 7" 3G
    Galaxy S i727 Skyrocket
    Device specific
    Mako
    Inline kernel
    Added SIO & ROW
    Added Conservative
    Krait retention
    Fast Charge (motley)
    Thermal temp throttle selector (showp1984 & franciscofranco)
    Basic sound gain (franciscofranco)
    Fsync(Ezekeel)
    Gamma control (franciscofranco)
    Linaro toolchain
    Other smaller changes
    Added init.d support
    N7100/I9100G
    Update to 3.0.73
    Fix wakelocks
    Updated conservative
    Updated Interactive
    Updated Logger
    Updated LMK
    Updated android staging files
    Enhance string arithmetic
    Higher Read-ahead
    One more mmc patch [n7100]
    Added SIO and Interactive [n7100]
    Tons more.
    D2: Updated kernel to 3.4
    I9100G: Added noise suppression for voice calls
    I9300: OpenSource RIL [CM]
    Nozomi: Added FIOPS
    Tuna: Lean Kernel 6.4
    Skyrocket: Added init.d support
    Fixes
    Camera extra settings menu
    Fixed DSP Manager
    Fix Photosphere/Camera FCs
    Fix Unable to pulldown Notification in Expanded mode
    Fix some issues with Exchange and Email
    Device specific
    Nozomi: Fixed Intellidemand
    I9100: CM camera fixes upstream
    N7100: Fixed thethering
    I9300: Fix dock audio
    D2: Phone call freeze fixed
    Known Issues
    Android Beam doesn't show confirm window.
    Androidiano L'avatar di Emans
    Catania
    NEXUS 5
    Quote Originariamente inviato da mlucky Visualizza il messaggio
    Tantissima roba! Non vedo l'ora che la rilascino!
    [NEXUS_4] + [slimBEAN]
  4. #113
    Quote Originariamente inviato da alexjuve Visualizza il messaggio
    Ciao a tutti, ho installato da pochi giorni questa ROM e sinceramente mi piace molto, vorrei però chiedere se qualcuno di voi è a conoscenza se le icone del centro notifiche si possono spostare in basso, funzione molto utile x l' uso con una mano. Ne approfitto x fare i complimenti a chi ha fatto questa ROM e saluto tutto il forum
    .... Dimenticavo, è possibile installare s-voice su questa ROM? Grazie
  5. #114
    Androidiano VIP L'avatar di pittar
    huhuuhuhhuuhuhuh
    htc m8 lg g2 nexus 5x
    Ringraziato 409 volte in 252 Posts
    Quote Originariamente inviato da Emans Visualizza il messaggio
    post aggiornato con il download della nuova release.....sto scaricando.....
    http://www.androidiani.com/forum/avatars_and_pics/signaturepics/sigpic95055_6.gif
  6. #115
    Quote Originariamente inviato da pittar Visualizza il messaggio
    dico solo "SPETTACOLO"
    p.s.: attenzione, è caldamente raccomandato il full wipe anche se si proviene dalla versione 3.
    Ultima modifica di mlucky; 19-04-13 alle 23:00
  7. #116
    Senior Droid L'avatar di cm0s
    undefinied
    Ringraziato 32 volte in 30 Posts
    porca miseria ho appena messo la v3.x cmq ottima ROM. solo 1 riavvio fino ad ora nella atto di caricare una foto su wattsapp..
    Inviato dal mio Nexus 4 con Tapatalk 2
    Attualmente con: op5 8/128gb, OxygenOS, android10, stock kernel, twrp, magisk
    Device story: sony cmd z7, samsung sgh-e700, motorola razr v3x, nokia n73, n82, samsung gs3, nexus4, nexus5, opo, Xiaomi rn3pro,op5
  8. #117
    Senior Droid L'avatar di Majeh
    Ringraziato 19 volte in 19 Posts
    Se non sbaglio è quello di default...hai già provato un kernel diverso? Io ti consiglierei Faux o Air...
    ciao,
    vedo varie possibilità di download della faux
    quale versione mi consiglieresti per la batteria?
    momentaneamente ho scaricato la Turbo Boost Ultimate 4.2.2
    grazie in anticipo
    HTC One M7 Google Play Edition 32GB - Kit Kat 4.4.4
  9. #118
    Ho aggiornato alla build 4 e ho sempre questo dannato problema delle notifiche in roaming... Che palle!!!,
  10. #119
    Quote Originariamente inviato da Majeh Visualizza il messaggio
    ciao,
    la mainline è quella con i consumi migliori, mantenendo le frequenze standard.
    Le altre due overclokkano e, di conseguenza, aumentano i consumi.
  11. Il seguente Utente ha ringraziato mlucky per il post:
    Majeh (20-04-13)
  12. #120
    Androidiano VIP L'avatar di Pomponio2196
    Pennadomo (CH)
    Nexus 4
    Ringraziato 335 volte in 262 Posts
    Ma perche dal market mi esce questo se provo a scaricare qualche app?? Permettono che ho fatto un full wipe e che ho cambiato la densità a 320
    Immagini allegate
    Telefono: Nexus 5
    Rom: The PureNexus Project
    Kernel: Blue_spark r16
    Gapps: TK Gapps Pico
    <--Se in qualche modo ti ho aiutato,premi il tasto THANKS
