Visualizza i risultati del sondaggio: State provando questa ROM ?
Chi ha votato
13. Non puoi votare questo sondaggio
  • Si , aggiorno ogni nightly della AOSPAL
    7 53.85%
  • No, ma seguo gli aggiornamenti pensando di usarla in futuro
    5 38.46%
  • No , non è una Rom interessante
    1 7.69%
Pagina 12 di 21 primaprima ... 21011121314 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 203
[AOSPA4][KITKAT][SABERMOD4.8] ParanoidSaberDroid - AOSPAL
  1. #111
    NexusZero
    Nella beta 5 però "modalità immersiva disattivata" è improponibile
    Androidiano L'avatar di johnmuddy
    Ringraziato 68 volte in 44 Posts
    Nuova versione di AOSPAL basata su Paranoid [Beta 6] basata sul recentissimo firmware KVT49L (4.4.2_r2) . ecco i changelog
    February 17th, 2014 | PA 4.0 BETA-46
    Duplicate SMS bug fixed
    Merge with PA BETA6
    AOSPA 4.0 Beta 6 <2014-02-17>
    Update to KVT49L (4.4.2_r2) AOSP
    KVT49L (4.4.2_r2)
    Update Color Scheme summary explicitly
    Show mic key option on sw540 device
    Fix unusual NPE after onDestroy
    Add keyboard color switch option
    Add JB/ICS resources from Azuki MR1 release
    Rename KLP theme related resources
    KLP/JB/ICS common resource name suffixes to _holo
    Add key press vibration value for Motorola DVX
    handleBackspace should always send KEYCODE_DEL for InputType.TYPE_NULL
    Fix: PtNode array size writirng when array size > 127. DO NOT MERGE.
    Import translations. DO NOT MERGE
  4. #113
    February 22th, 2014 | PA 4.0 BETA-6
    AOSP:
    *Merged AOSP's latest changes (android-4.4.2_r2)
    *Just some changes in LatinIME
    PA (BETA6):
    *Quicksettings:
    *Immersive: Make last active state a system variable.
    *Removed PA beans, back to PA's kitkat easter egg.
    Features:
    *Renamed "Additional Settings" to "Remix Settings", also includes layout revamp by me. NOTE: Using Dual Panel will cause issues with it. We'll wait for the new Hybrid feature and *currently it's beeing worked by aaron.
    *Lockscreen: Slider Shortcuts (CM) (Remix Settings -> Lockscreen -> Slider Shortcuts)
    *Wakelock Blocker (Chamaleon OS)
    *ADB Paranoia mode (Settings -> Developer Options)
    Fixes
    *Immersive: Fix Left handed navbar during landscape mode
    *Settings: fix QuietHour start time
    *-when user decide when quiethour will start/stop using time preference alarm manager will setup the time, and call stop service in many times before starting the service
    this add some check to prevent call stop service before time to start
  5. Il seguente Utente ha ringraziato johnmuddy per il post:
    Nikoracing (23-02-14)
  6. #114
    A chi interessasse solo le Lockscreen Notifications della AOSPAL ma preferisce restare in Cyanogenmod , può utilizzare la Nexus 5 Experience - CM11 Based che comprende gapps , root e busybox. le caratteristiche della rom le potete trovare a QUESTO INDIRIZZO , inoltre se siete già in cyanogenmod 11 pura è sufficiente un wipe cache e dalvik senza cancellare i propri dati per mettere questa. Qualora dovreste riscontrare un consumo eccessivo di Sistema android, è dovuto esclusivamene alla pocket mode. Disattivandola non incontrerete tale problema.
  7. #115
    March 2nd, 2014 | PA 4.0 BETA-6
    PA:
    • Speed up booting for multi core devices.
    • VolumePanel: Don't force to show navigation bar on immersive mode.
      Features:
    • All in one animation control (AOKP). Consists from ListView, System. Scrolling and Keyboard. (Remix Settings -> Animations)
    • Return: Always show battery status on Keyguard (SlimRoms) - (Remix Settings -> Lockscreen)
    • Toast Animations from XuiMod xposed framework. (Remix Settings -> Animations)
    • SmoothProgressBar + Custom ProgressBar Settings (Dokdo project) (Remix Settings -> System)
    • Notification Reminders (SlimRoms) - (Remix Settings -> Notification Drawer)
    • Statusbar clock font style (Remix Settings -> Statusbar -> Clock and date)
    • Double tap either on Lockscreen PIN, password, pattern or GlowPad to sleep other than statusbar.
    • Partition information menu (MiniCM) - (Settings -> Storage)
    • Displays the current used space on certain partitions
    • DSP Manager (Omnirom)
      Fixes
    • ADB Paranoid: Dont show pref if RSA verification is disabled
    • Lockscreen shortcuts: Fix icon pack usage
    • Fix Connection Manager crash when dual panel is activated
      Improvements:
    • Settings: Moved Performance, Gesture Anywhere, Wakelock blocker into Remix Settings, on System.
    • Frameworks: Add support for translucent volume panel
    • Theme data chart to white in Data Usage menu.
  8. #116
    Androidiano VIP L'avatar di dubledude
    Napoli
    LG Nexus 5
    Ringraziato 608 volte in 559 Posts
    Solo io non la trovo più? Tornata la voglia di riprovarla
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  9. #117
    Solo a me con l'ultima nightly del 14 marzo c'è un utilizzo molto elevato della batteria da parte di com.android.systemui? Non dovevano fixarlo nelle relase seguenti a quella che conteneva il bug?
  10. #118
    Napoli
    LG Nexus 5
    Quote Originariamente inviato da dega95 Visualizza il messaggio
    Provieni da full wipe?
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  11. #119
    Quote Originariamente inviato da dubledude Visualizza il messaggio
    Si avevo 4.4.2 stock e ho messo anche Hells Doctor
  12. #120
    Napoli
    LG Nexus 5
    credo di metterla in giornata e ti dico..
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
