Pagina 16 di 20 primaprima ... 61415161718 ... ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 194
[ROM][N4][6.0.x][7.0.x] Fake Nexus Rom for Nexus 4
  1. #151
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    NEW RELEASE
    Aug/29/2016: 20160829 (alpha)
    Rebase device tree from @zaclimon V2
    Primo post aggiornato con link per il download
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
    SAMSUNG S20+5G
    Il dev @zaclimon continua a lavorarci ed è arrivata alla V3 della AOSP:
    V3: (30/08/16)
    - Fixed sensors (For you Pokemon Go people )
    - Semi-Fixed Camera (Taking pictures works but video recording not saving and I'm a bit clueless. See below for details)
    - Fixed MPDecision
    - Enabled Doze
    - Used GPU drivers from Flo's N developper preview
    About sensors, as some of you may know, it looks like the use of Clang broke the use of our sensors, however we can force the part responsible of it to be compiled with GCC. The patch for you builders can be found here:
    https://github.com/xyyx/android_bion...1bd527231d9302
    About camera, I don't know what's happening since I have 2 possible theories. I can see that the OMX encoder has some issues. That said, it could be possible that our HAL needs to be modified for Nougat support as seen here:
    https://source.android.com/devices/c...html#hardening
    If we use API1 HAL1, that's where it could get a bit tricky and can go harder than what I can possibly do. Flo doesn't have the same issue since it uses Camera2.
    @ganachoco What's your insight regarding this? I know you had some issues with getting Google Camera because of Camera2.
    Anyways enough talking. The build is available in the OP and I hope you'll be happy enough for the moment. Time for a little break now.
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  4. #153
    SAMSUNG S20+5G
    NEW UPDATE
    Aug/31/2016: 20160831 (alpha)
    Rebase device tree from @zaclimon V3
    Primo post aggiorato con link
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  5. #154
    SAMSUNG S20+5G
    NUOVA RELEASE
    Sep/03/2016: 20160903 (beta)
    Enable cpuset
    implement exclusive core feature with simple mpcpusetd. @xenyz hints to me how to implement. Thanks.
    Tune cpu governor while booting
    PRIMO POST aggiornato con changelog e LINK per download
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  6. #155
    SAMSUNG S20+5G
    AL momento @ganachoco non ha ancora incorporato la V4 di @zaclimon che ha il seguente changelog:
    Update/Future
    Hi guys! Another day, another update for the Nexus 4. I don't know if it'll be enough but anyway here it is:
    V4 (02/09/16):
    - Fixed H/W video decoding for the most part (can see YouTube 60 FPS videos/Was able to play some local video files using it as well)
    - Kernel: SDCard FS enabled (I leave the discretion to the custom roms whether to really enable it or not)
    - Attempt to fix permissions for GApps
    - Enabled Navigation Bar tweaks and Night mode in SystemUI Tuner.
    If YouTube is somewhat posing a problem with 60 fps playback, I compiled a test version of Quanta V19 which is compatible with Nougat. Please note that I won't be offering any support for this version as it is mostly experimental stuff.
    It has been a somewhat challenging two weeks trying to get everything working, I definitely won't have a lot of time to be on this project anymore starting next Tuesday. School is beginning for me and I want to focus on some other projects (Quanta stuff mostly) Though, It's nice to see that there are still a lot of people interrested in flashing new updates and that's what is somewhat the heart of XDA. I wanted to get mostly everything working and I believe that it has been mostly accomplished. (minus some minor stuff like the flashlight and notification light) I'll leave out all the source required to build for the N4 + some patches I used. (GApps/Navigation bar + night mode)
    At the same time I take the time to remind to some people here that might have some hope of features coming to this rom. Sorry to say it to you bluntly but I'll crush these dreams right away. This rom is meant as a way (even more as a proof of concept more than anything else really for this device) to get Android 7.0 running. As such it will act as a base for the custom roms that will have all your favorite feature.
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  7. #156
    SAMSUNG S20+5G
    NEW VERSION
    Changelog:
    Sep/05/2016: 20160905 (beta)
    Rebase device tree from @zaclimon V4
    Remove w/r permission from vidc encoder device to all
    It seems while mediacodec server open vidc encoder, camera server cannot use hardware encoder, and cannot record video stream.
    Fix facelock funtion
    Update widevine drm binary blobs from bullhead.
    It might prevent to crash mediadrm and media service. But I cannot be sure it can play drm contents.
    Switch to user build.
    Primo post aggiornato con link e tutto
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  8. #157
    SAMSUNG S20+5G
    NEW VERSION
    Sep/07/2016: 20160907 (beta)
    update to NRD90S (android-7.0.0_r4)
    Turned on sdcardfs
    Primo post aggiornato con link e changelog
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  9. #158
    Senior Droid L'avatar di jhonnyzzo
    Potenza
    Nexus 4
    Dai dai che stiamo per arrivare alla definitiva. 😁
    Inviato dal mio Nexus 4 utilizzando Tapatalk
  10. #159
    SAMSUNG S20+5G
    Quote Originariamente inviato da jhonnyzzo Visualizza il messaggio
    Dai dai che stiamo per arrivare alla definitiva. ��
    SI secondo me è nell'aria !
    Questo ultimo update è basato su una 2° factory emessa da Google (ovvio non per il nostro N4)
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  11. #160
    Androidiano L'avatar di panoss
    OnePlus 3, Nexus4, Nexus 7
    Qualcuno che la sta provando?? o devo fare da cavia io?
