[KERNEL] [22.11.2013] [KK4.4] [HAMMERHEAD] n3oHammer_v11 [CPUQUIET|S2W|DT2W|WIFI FIXE
    Nexus 4 - Nexus 5 in arrivo
    [KERNEL] [22.11.2013] [KK4.4] [HAMMERHEAD] n3oHammer_v14 [CPUQUIET|S2W|DT2W|WIFI FIXE
    banner by jonas2295
    ==[n3oHammer]==
    codice:
    FEATURES:
    - USERSPACE VOLTAGE CONTROL
    - FAST CHARGE
    - CPUQUIET HOTPLUG
    - KERNEL BASED THERMAL CONTROL
    - SMARTMAX GOVERNOR FOR BALANCE BETWEEN BATTERY AND POWER
    - XZ COMPRESSED
    - SWEEP2WAKE
    - DOUBLETAP2WAKE
    USE TRICKSTER MOD FOR CONTROLING ALL FEATURES
    HOWTO REPORT ERRORS -> THE RIGHT WAY
    -) YOU need to provide me the following information, otherwise I´m not able to help:
    -) On wich ROM you are
    -) Wich Kernel and wich modules did you flash
    -) ALWAYS provide a last_kmsg AND a logcat (you dont know how to do that ? Use google or search here in this forum, its posted nearly everywhere)
    -) posts like "XYZ feature on ROM XYZ does not work" will be ignored (what should i do with that information ???)
    CHANGELOG (old versions) & KERNEL FEATURES
    codice:
    Code:
    n3oHammer_v1
    -initial release
    -backported earlysuspend
    -fast charge
    -voltage control
    -stock freqs
    -cpuquiet hotplug
    n3oHammer_v2-v7
    -internal testing
    n3oHammer_v8
    -added s2w, s2s, dt2w (thanks showp1984)
    -added francos sound control
    -removed mpdec so its off by default and should stay off
    -new lowest freq: 96 MHz thanks showp1984
    -OC upt to 2,53 GHz thanks showp1984
    - slightly cooler colors, whites are more white (thanks franciscofranco)
    n3oHammer_v9
    - fixed flashing issue, everythings working now
    n3oHammer_v9_fix
    -fix Wifi
    n3oHammer_v10
    -ditch out mpdecision, u cant turn it on anymore so cpuquiet can do its job as it should
    -should fix reboots
    n3oHammer_v11
    -hopefully fixed L1 cache error
    -ditched out earlysuspend and keep in line with google
    -better battery life
    KERNEL Battery infos:
    v11: s2w,dt2w disabled, cpuquiet load stats, smartmax governor, mobile data
    lost 3 % in 7 hours. Think thats ok
    HUGE THANKS TO @maxwen who always support and teaches me
    Howto install:
    Scaricate il pacchetto QUI
    riavviate in recovery (CWM o TWRP)
    Install from ZIP
    Wipe Cache
    Wipe Dalvik
    Reboot
    Github
    Link
    Disclaimer
    -) I am not responsible for bricked devices / Non sono responsabile per eventuali brick dei telefoni
    -) If you flash this, your warranty will be void / Sappi che perderai la garanzia
    CREDITS
    MAXWEN: FOR ENDLESS SUPORT AND TEACHING STUFF
    FRANCISCOFRANCO:mako_hotplug control
    SHOWP1984: sweep2wake, doubletap2wake, and always be friendly guy that helps
    XDAevDB Information
    n3oHammer Kernel , a Kernel for the Google Nexus 5
    Contributors
    n3ocort3x, nimrodity, LorD ClockaN
    Kernel Special Features:
    Version Information
    Status: Testing
    Created 2013-11-13
    Last Updated 2013-11-
    LINK AL THREAD SU XDA FORUM
    Ultima modifica di pirosoft; 28-11-13 alle 19:43
    ragazzi, qualcuno ha provato questo kernel sul N5?
    io lo sto testando ora sulla rom CATACLYSM
    appena ho qualche feedback ve lo posto?
    nexus 4
    Ringraziato 49 volte in 45 Posts
    Quote Originariamente inviato da pirosoft Visualizza il messaggio
    io sarei curioso di vedere come va, ma sto testando il franco..facci sapere come va!
    Senior Droid L'avatar di grifis78
    Nexus 5, Nexus 7, GNexus,
    Ringraziato 37 volte in 24 Posts
    Niente knock on?
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Ma hai fatto copia/incolla?
    Ha messo pure questo, XDAevDB Project
    codice:
    XDA:DevDB Information
    Contributors
    Version Information
    Status: Testing
    Created 2013-11-13
    Dovresti tradurre in italiano visto che il forum si chiama Forum Android Italiano
    uscita la versione 14
    http://d-h.st/qDs
    n3oHammer_v11
    n3oHammer_v13
    -reboots are gone (for those who had one)
    -ondemand and interactive governor from hammerhead baseline + fixes and improovements from showp-1984
    -adjusted regulator voltages higher min and max
    -removed OC just to be 100% sure the reboots are gone
    -UC is still there
    -Bootup with stock freq 300Mhz - 2,2GHz
    -adjusted smartmax to act a bit more aggressive
    -implemented support for faux FREE gamma adjustment APP (great job btw, and for FREE)
    n3oHammer_v14
    - synced with latest stuff from @myfluxi for fauxs free gamma app control app thanks to both
    dopo aver provato il bricked, elementarX e faux, posso dire che questo è il kernel migliore che ho provato in quanto a prestazioni e a durata della batteria
    non sono mai riuscito a farlo durare 19ore in batteria con quasi 3ore di schermo acceso, luminosità display auto, no wifi. navigazione, facebook video youtube
  9. Il seguente Utente ha ringraziato pirosoft per il post:
    ryk (28-11-13)
  10. #8
    ryk
    ryk non è in linea
    Nexus 4,G2,Nexus 5,Xiaomi MI3
    Ringraziato 317 volte in 277 Posts
    Ciao vorrei provarlo,hai fatto qualche prova di come girano i giochi pesanti ?
    Nexus 5 Rom Pac Man + ElementalX
    Xiaomi Mi3 Rom RayGlobe Miui
  11. #9
    torino BIANCONERA
    NEXUS 6P
    Ringraziato 499 volte in 419 Posts
    FRANCO HAI provato?
    quasi quasi provo anche io questo..
    una domanda, il kernel ha per caso la possibilità di modificare un settaggio dei colori tipo l'elementarX ?
    grazie!
    Smartphone posseduti:
    "iphogne " 3gs
    galaxy s2 - s3 - s4 poi NEXUS 5, lg g3, P9 e finalmente li NEXUS 6P
