Pagina 4 di 322 primaprima ... 234561454104 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 3216
[ROM] [Lollipop 5.x.x] [HAMMERHEAD] Cataclysm for Nexus 5
  1. #31
    Androidiano L'avatar di Rufyz
    Google Nexus 5X
    Ringraziato 17 volte in 13 Posts
    Quote Originariamente inviato da SPAstef Visualizza il messaggio
    wipe system, data, cache e dalvik + unmount system + reflash rom.
    Fai un backup dei file
    risolto
    Androidiano VIP L'avatar di SPAstef
    Ferrara
    Google Nexus 5; Acer A501
    Ringraziato 1,691 volte in 1,319 Posts
    Quote Originariamente inviato da Lanz Visualizza il messaggio
    Questa è la to do list postata dal dev. Piano piano queste feature verranno aggiunte alla rom.
    - QuickToggles - toggle2g3g - inCallBlocker - ScreenSHots -
    ScreenRecorder - Volume - Screen Timeout - Ringer Mode -
    Fast Charge - Wifi ADB - Cataclysm Settings - GPS - Hot Reboot -
    Ime switcher - Lte - System stats - Connection speed - Nfc - Sync -
    Usb tethering -
    - InCallBlocker
    - Smart Radio
    - Softkeys Fade Mod
    - One click app picker
    - Custom Lockscreen Wallpaper
    - Immersive mode
    - Battery: Text Only / Circle battery / Text + Icon
    - Nfc polling mode. Disable Nfc sounds
    - Expandable Volume Overlay
    - Unlink Notification Volume
    - Force show menu
    - Optional data activity overlay on statusbar
    - Remember Headset Volumes
    - Resize Navigation Bar
    - Custom Lockscreen Targets
    - Statusbar brightness control
    - Screen recorder service
    - App Ops shortcut
    - Clear All Recents Button
    - Sleep Button
    - AOSP Keyboard Customization
    - Volume Rocker Wake
    - Volume Rocker Music Control
    - Volume Rocker Cursor Control
    - Longpress Back to kill foreground app
    - Optional vibration on remote call connect/disconnect
    - Quick PIN Unlock
    - Toggles quick pulldown
    - Full screen lockscreen
    - 180° rotation
    - Led notification support for missed calls.
    - Led pulse shortened to 3sec.
    - Extended Power Menu
    - onClick and onLongClick actions to StatusBar Clock/Date
    - Double line layout for statusbar date
    - Disable wake when (un)plugged
    - H+ UI Support
    - Rom settings backup support
    - 3G Only network mode
    - LTE Only network mode
    - Go Home after a phone call
    - Announce caller over earphones/headsets (tts).
    - Hide phone number to unknown
    - Lockscreen rotation
    - Optional CRT animation - Landscape animation
    - Center statusbar clock - AM/PM Style - Disable StatusBar clock
    - Longpress recents go to last task
    - Privacy mode: hide statusbar ticker
    - Start lockscreen widgets maximized
    - Longpress lockscreen slider to unlock
    - Disable lockscreen camera
    - Disable Safe Headset volume warning
    - Disable beep on volume adjust
    - Disable USB Debugging notifications
    - Disable GoogleNow swipe gesture
    - Unhide statusbar on incoming notifications if on fullscreen.
    - Disable powermenu if secure.
    - Disable fullscreen keyboard on landscape.
    Alcune cose ci sono già...
    Quote Originariamente inviato da italiano Visualizza il messaggio
    Linear funziona con questa rom?
    Al momento visto il decesso di xposed esiste una possibilità vana di moddare la rom ?
    si va benissimo
    PER RINGRAZIARE LASCIA UN THANKS
    Le mie ROM preferite:
    • Android M2 + HellsCore Kernel
    • Chroma ROM + Franco Kernel
  4. #33
    Senior Droid L'avatar di AxlDemocracy
    Lg Nexus 5 - Nokia 5800
    Ringraziato 53 volte in 51 Posts
    Seguo il progetto. La cataclysm è stato il mio primo amore
  5. #34
    Ferrara
    Quote Originariamente inviato da AxlDemocracy Visualizza il messaggio
    Si. Insieme alla DroidKang
  6. #35
    Senior Droid L'avatar di italiano
    Honor 8 pro blu
    Ringraziato 64 volte in 61 Posts
    Pure il mio .... Ma poi ci si abitua a molte cose che senza si fa male..
    Ci fosse sempre xposed avevo già flashato .
    Sono sempre in fase riflessiva ...mi tira la.stabilità , ma non so se aspettare la slimpop
  7. #36
    Senior Droid L'avatar di themr87
    Vicenza
    Nexus 5 32GB white
    Ringraziato 228 volte in 190 Posts
    ragazzi qualcuno ha il problema del cellulare sempre attivo? sembra che il processore non vada in deep sleep
  8. #37
    Ferrara
    Quote Originariamente inviato da themr87 Visualizza il messaggio
    Non mi pare...
  9. #38
    Ferrara
    Confermo... Non va in deepsleep!
  10. #39
    Honor 8 pro blu
    Hai hai hai ....
  11. #40
    Vicenza
    Nexus 5 32GB white
    Abbiamo trovato un grosso bug
