morfances
New build!!
April 30, 2015 -
Electroactive-N5-1.47
-optimize memory allocation in check_partition()
-Fix changes not applying on boot
-Add electroactive.sh script support
-Thermal throttling set to Cooler by default for less heat
Gią installato da ieri!!
Risolto problema con Euphoria scaldava di bestia!! Ho qualche micro lag nella app come google e chrome!
Per il resto si comporta bene, fluida e reattiva!
New build May 13, 2015 - Electroactive-N5-1.52
Download
-Add sanity check to avoid unregistering the driver twice (therefore preventing kernel panic)
-Add optimized SHA-256/224
-Update kernel sources to linux 3.4.107
-Move VFP init to an earlier boot stage
-CAF sound codec driver
-Fix voltage tables and scripts
-Specifically modified PVS voltage tables per each unique device. Stock voltages now set
differently depending on your CPU binning.
-Update msm-kernel sources to android-5.1.1_r0.10
-Update Documentation & arch to 3.4.104
-Fix SMD packet sync loss issue
-lmk tune up
-Chrome freeze issues gone
-Overclocking up to 2.9 GHz
-Min CPU frequency down to 96 MHz
-Can have different frequencies and/or governors for each CPU core
-Ramdisk updated to be more compatible and better performance on more ROMs
-FSTRIM now built-in: trims /data and /cache to discard any unused data blocks on boot, no more lag
New build!!!
May 14, 2015 - Electroactive-N5-1.56
-Kernel sources updated. Reverted some bad commits. Added GPU implementation to prevent wavelocks and be more responsive and less freezing/lagging, especially in Chrome.
-Updated the ramdisk, now has greater compatibility and better performance on more ROMs.
-Chrome freeze issue being worked on. Some improvements
-Script errors from previous build fixed
-Updated config file and sh scripts, and kernel zip. MUCH more options in the config file, enhanced kernel options
-Ability to change kernel governor in config file.
- Overclocking experimental (may not work)
-More incremental underclocking
-Minimum CPU frequency now down to 96 MHz. Can also be changed in the configuration file. (Working)
NOTE: Not needed, but highly recommended to delete these two files:
-/etc/electroactive.conf
-/sdcard/.electroactive.backup
New build!!
May 19, 2015 - Electroactive-N5-2.00
-Kernel Rebased
-Removed unneeded/unwanted commits and left all the good stuff in new base
-Add deeper incremental overclocking up to 2.95 GHz. Still boots at stock frequency
-Min CPU frequency down to 96 MHz, options for 192 and 249 MHz. Still boots at stock frequency
-Built with -O3 CFLAGS Makefile variables for extreme optimization
-Add MultiROM support
-exFAT support built-in to kernel rather than a module
-Add some speed and stability updates
New build :June 2, 2015 - Electroactive-N5-2.10
-Major Update. Getting close to second major release.
-More chrome fixes, should be almost completely gone. General UI speed-up and smoothness optimizations.
-Memory leak issue fixes, a bit better memory efficiency.
-Fix issues with any previously installed kernel files not being removed/reappearing after installation.
-Battery life issues with wake-locks and screen power consumption are fixed, GPU and CPU drivers updated.
-2 different versions of kernel: TC-DEF and TC-TEST. Only differences are the compiler toolchains and GCC. Try both and report which is better. TC-DEF uses the default old style build compiler and TC-TEST uses the new test compiler.
-Update advanced color control
-Kernel sources updated back to 3.4.107 from 3.4.0, some backports from Linux 3.18+ kernel sources.
-F2FS Support Built-In to ramdisk. No need to flash any F2FS support patch before installing kernel.
-More focus on optimization.
Link download in OP
New build : per 5.1.1 e per android M
Downloads in OP
June 29, 2015 - Electroactive-N5-2.40/3.00-M
-CPU Power Aware Scheduling
-Partial-Resume Framework
-Merged android M sources
-Fix cpu sticking issue
-Introduce PM Suspend Freeze
-Remove compiler warnings to prevent any issues in installation
-Re-add fsync control
-Add GPU sysfs reporting in pwrctrl
-Add 8974 support for enabling GPU GDHS
-Use new global screen-off detection variable
-Electroactive cpu governor: Introduce powersave-bias
-Greatly improve memory access performance
-Skip sensor_ind wakeup source activation via sysfs to prevent wakelocks
in test.
davvero interessante per vari aspetti per quanto riguarda il mio stile:
- governor personalizzato dal dev (un nuovo mondo da provare)
- frequenze min e max davvero particolari. chissą che batteria ci verrą fuori con un 300 e un 1100 (pił ovviamente governor etc.)
per quanto riguarda le prestazioni, di sicuro sono inferiori a certi kernel come elemental x, code blue. lo stesso franco/hells mi sembrano migliori in questo. abbastanza ovvio visto le frequenze con cui gira, anzi! mi stupisco che il cell non si pianti con sti settaggi xD
insomma e vediamo come andrą xD
per il momento ho aumentato la frequenza massima almeno a 1200etc.
con 1100 non riesco
EDIT GIGANTE: b b b bbaaaallee xD era un fail mio! kernel adiutor si impostava a caso e mi ha messo ste frequenze. non fate caso al mio messaggio, non vale una cicca ed č tutto falso xD
Per il momento mi sto trovando molto bene :)
fabi_92
Anch'io ,che lo seguo da sempre,noto miglioramenti nel consumo batteria e sopratutto non scalda a bestia ...come le prime releases
