Pagina 1 di 7 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 69
[KERNEL] ElementalX-N6P
    Androidiano VIP L'avatar di Vanhalino
    Modding Land
    Google Pixel 6
    Ringraziato 715 volte in 561 Posts
    ElementalX Kernel
    for Nexus 6P (angler)
    Features
    Easy installation and setup with Aroma installer
    Wake Gestures (sweep2wake and doubletap2wake)
    Camera launch gesture
    Sweep2sleep
    Overclock or underclock CPU
    Advanced color control (RGB, Saturation, Value, Contrast, Hue)
    Sound control (headphones, speaker and mic)
    Backlight dimmer option
    High Brightness Mode option
    Option to disable touchboost
    NTFS r/w and exFAT support
    Option to disable fsync
    Adjustable vibration
    Does not force encryption
    Does not modify system partition
    Compatible with systemless root and Android Pay
    ElementalX is designed for maximum stability. It is made for people who depend on their phone every day.
    ElementalX has useful and well-tested features that make your phone better. It does not have useless kernel patches or make dangerous or experimental changes to your phone that cause weird or inexplicable problems.
    ElementalX behaves like the stock kernel by default, but offers you the option of changing almost anything you want.
    Installation
    1. Flash in recovery
    For maximum compatibility with all ROMs, ElementalX uses your existing ramdisk.
    Do NOT flash this over other custom kernels!
    You should only flash ElementalX over the kernel that came with your ROM!!!
    Download
    Android 6.0.1 (Marshmallow) versione 1.19
    Solo per le ROM con patch di Luglio, il WiFi non funziona con versioni precedenti
    Link
    NOTE: if camera force closes, reboot to recovery and wipe cache.
    Android 6.0 (Marshmallow) versione 1.18
    Installare questa versione se non vi funziona il WiFi
    Link
    Android N 7.0 preview 4 versione 3.03
    Link
    Please consider a donation to support ongoing development
    Many thanks to those who have donated!
    Google+ Community
    https://plus.google.com/communities/...29618226326192
    Source code
    https://github.com/flar2/angler
    _____________________________________
    XDAevDB Information
    ElementalX-N6P, Kernel for the Huawei Nexus 6P
    Contributors
    flar2
    Source Code: https://github.com/flar2/angler
    Kernel Special Features:
    Version Information
    Status: Stable
    Current Beta Version: 1.03
    Beta Release Date: 2015-12-17
    Created 2015-11-04
    Last Updated 2016-07-08
    FONTE: http://forum.xda-developers.com/nexu...x-n6p-t3240571
    Ultima modifica di Pasqui1978; 21-07-16 alle 23:32 - Motivo: aggiornamento
    Nexus 4, Nexus 5, HTC One M8, Oneplus One, LG G3, Galaxy Note 4, Nexus 6, Iphone 6P, Nexus 6P, Xiaomi Mi5, Moto X Style, Leeco LP3, Xiaomi Redmi Note 4, Honor 8 Pro, Xiaomi Mi6, Google Pixel Xl, Xiaomi RN5, Xiaomi RN7, Google Pixel 2 XL, POCOPHONE POCO F2 PRO, Oneplus 8, Google Pixel 4 XL
  2. I seguenti 2 Utenti hanno ringraziato Vanhalino per il post:
    nicolovitello (25-12-15),Pasqui1978 (22-12-15)
    Senior Droid L'avatar di nicolovitello
    Rimini
    Samsung S4 gt-I9505 16GB
    Ringraziato 83 volte in 73 Posts
    Ottimo, qualcuno ha già provato a cambiare governor o altre opzioni? Io con il governor ElementalX lo tropo più fluido rispetto ad interactive che è impostato di default.
    Phone: LG G2 D-802 16gb
    ROM: Alla ricerca
    MODEM: Alla ricerca
    Kernel: work in progress
    Se ti sono stato utile clicca sul thanks è gratis!!! nicolovitello
  5. #3
    Modding Land
    Google Pixel 6
    Questo Kernel non mi ha soddisfatto particolarmente.
    Non l'ho trovato nè più reattivo dello stock, né più efficiente in termini di autonomia.
    Il Governor migliore, come rapporto fra prestazioni ed autonomia, mi è sembrato l'elementalx.
    È senz'altro godibile anche la possibilità di utilizzare un proprio profilo di colore.
    L'ho comunque rimosso dopo un paio di giorni...
    Inviato dal mio Nexus 6P usando Androidiani App
  6. #4
    Rimini
    A me insieme a cataclism non dispiace però ovviamente è ancora presto per trarre una conclusione
    ROM: Alla ricerca
    MODEM: Alla ricerca
  7. #5
    Modding Land
    Google Pixel 6
    Ah, la app delle wake gestures funziona perfettamente.
    Anche con la Screw'd Rom per chi fosse interessato (nonostante non monti l'elementalx...).
  8. #6
    Salve, io avevo pensato di installare questo kernel con rom stock, qualcuno mi sa dire se si ha un effettivo miglioramento nell'autonomia, e vorrei anche sapere se con kernel modificato continuano ad arrivare le patch di sicurezza di google. Grazie
  9. #7
    Jul 2015
    Ringraziato 365 volte in 329 Posts
    Uscita nuova versione 1.17... Con la update di maggio.
  10. #8
    Modding Land
    Google Pixel 6
    Messo! :-)
    Per ora sembra essere molto reattivo.
    Buone temperature.
    Vi aggiorno fra un paio di cicli.
  11. Il seguente Utente ha ringraziato Vanhalino per il post:
    damivig (10-05-16)
  12. #9
    Androidiani Power User L'avatar di Pasqui1978
    Jul 2014
    HTC U11 - LePro3 - Huawei P9
    Ringraziato 947 volte in 819 Posts
    Quote Originariamente inviato da Vanhalino Visualizza il messaggio
    Messo! :-)
    Buone temperature.
    Fai sapere (ho i miei dubbi a riguardo) se è migliore di altri...
    Inviato dal mio Nexus 6P utilizzando Tapatalk
    OnePlus 7 Pro 12/256 Nebula Blue {xXx NoLimits}
  13. #10
    Modding Land
    Google Pixel 6
    Avevo messo l'ultimo Franco Kernel e mi stava piacendo parecchio: ho apprezzato soprattutto il fatto che con la sua app proprietaria fosse possibile l'integrazione di automatismi via Tasker, e la possibilità di gestire la temperatura del colore tramite profili precaricati.
    ...però alla fine questi Kernel mi sembrano un po' tutti uguali sia a livello di consumi che a livello di prestazioni.
    Non so se è una mia impressione...
  14. Il seguente Utente ha ringraziato Vanhalino per il post:
    Pasqui1978 (10-05-16)
