[ROM][N6][5.1.1][LMY47V] Chroma | Native LED | Layers
]Chroma è una rom che focalizza l'attenzione sui consumi, le prestazioni e la stabilità.
Ricca di personalizzazioni ma priva di funzioni inutili.
NON COMPATIBILE CON XPOSED
Premessa:
Ne IO Ne ANDROIDIANI siamo responsabili di un eventuale danneggiamento al vostro dispositivo!
Features: [hide]
Franco Kernel
Layers Support
Native LED Notifications built-in (solid, limited to RGB colors)
Status Bar Customization:
Battery Style (Icon Portrait/Landscape, Circle, Text, Hide) and Battery Percentage
Clock & Date (Show/Hide, Color, Alignment, AM/PM, Show/Hide Date, Date Style, Date Format)
Brightness Control (long press status bar to change brightness)
Double-tap status bar to turn device screen off
Quick pull-down on left/right side to pull down tiles
Long press tiles actions
Pressing on clock or date on status bar opens up Clock, Calendar
Show/hide notification count on status bar
Tile customizations (LTE, Screenshot, Sync, etc tiles)
Enlarge 1st row, show 4 tiles per row, show/hide brightness slider
Heads up notifications
Network traffic indicator
Navigation bar customization
Rearrange navigation bar to your likings
Navigation bar height (48/44/40/36/32/28/24/20/0dp)
Navigation button tint
Show/hide arrow keys while typing
Kill app back button
Navigation ring customizations
Clear all recents button (enable/disable) and location (top left, top right, top center, bottom left, bottom right, bottom center)
Clear all task (dismiss all task or ignore the foreground task)
Lock screen customization
Power menu customization (power off, reboot, screenshot, airplane mode)
Advanced Reboot (reboot/soft reboot/recovery/bootloader)
Volume rocker customization:
Wake device with volume keys when screen off
Long press volume up/down keys to skip track when screen off
Volume key adjustment sound (enable/disable)
Other:
A large number of optimizations and memory leak fixes
Ambient display controls
Animated expandable volume panel
Long press recents to swap back to previous app
AOSP Gallery2 with material design
Prevent accidental wake (proximity sensor before waking screen)
... and more (see changelog)[/hide]
Instructions
Pre-requisites: unlocked bootloader, latest TWRP recovery
1. Download ROM, Gapps, SuperSU and put it on the phone's internal storage.
2. Boot into TWRP recovery.
3. Coming from a different ROM? Perform a factory reset using TWRP. If you're upgrading from Chroma ROM, proceed to dirty flash (nandroid backup before flashing is a good idea)
4. Clean Installation: Flash ROM, Kernel (Optional), GApps, SuperSU
....Dirty Flash: Flash ROM, Kernel (Optional)
5. Reboot and enjoy.
Enjoy what I do? Want to show your appreciation? You can donate HERE.
Changelog: HERE
Download: Chroma 2015-04-21 | GApps | SuperSU
Note: If you're using a custom kernel other than the one with the ROM, flash THIS after to pertain Chroma's sepolicy fixes.
All Chroma Builds
You must flash SuperSU otherwise you will not have root access.
Want to be notified when a new update comes out? Subscribe to Chroma on Pushbullet and you’ll receive a push notification when a update is out.
Fonte: http://forum.xda-developers.com/nexu...-2015-t3000003
