[ROM][5.1.1][Shamu][UBERTC] Euphoria-OS 1.1 - Faster than light!
    Androidiano VIP L'avatar di fabioo123
    Ringraziato 451 volte in 347 Posts
    Rom sviluppata e seguita dallo sviluppatore MAHDI, conosciuto per l'omonima rom.
    Premessa:
    Ne IO Ne ANDROIDIANI siamo responsabili di un eventuale danneggiamento al vostro dispositivo!
    Installation instructions
    [HIDE]Installing Euphoria-OS for the first time, or coming from another ROM:
    - Make sure you're running a proper working ClockworkMod-Recovery/Team Win Recovery Project - WITH SELINUX SUPPORT!
    - Copy GApps PA Gapps and ROM ZIP to your SDCard
    - If you are running an encrypted kernel, your data will be encrypted on first boot
    - If you are running an unencrypted kernel, your data will remain unencrypted
    - Boot into Recovery
    - DO A DATA WIPE / FACTORY RESET
    - Flash Euphoria-OS zip from SDCard
    - Flash GApps zip from SDCard
    - Flash SuperSU
    - Reboot
    - Don't restore system data using Titanium Backup!
    Upgrading from an earlier version:
    - Copy the ROM ZIP to your SDCard
    - Flash the ROM zip from SDCard
    - Reboot[/HIDE]
    Features
    [HIDE]
    Under The Hood
    AOSP Based
    Un-encrypted
    Theme Chooser
    Customize Quick Settings
    Delta Updates
    Disabled tether checking
    IME selector notification control
    Advanced reboot
    Adb notification control
    Adb over network
    Long press back to kill
    CPU info overlay
    Status bar brightness control
    Superuser built into privacy gaurd
    Battery Icons options
    Option to disable lock screen carrier label
    Slim heads up options
    Headsup - don't show if notification drawer is visible
    HeadsUp: Swipe options
    -left swipe dismiss
    -right swipe put into background
    -swipe down opens notification drawer and moves the notification into it
    USB OTG support
    cLock widget
    Notification weather panel
    Disable battery saver bar color
    Dialer - reverse number lookup
    HSPA+ Icons
    Statusbar clock and date customizations
    Sound
    AudioFX
    Eleven
    Increasing volume ringtones
    Profiles
    Increasing ring volume
    Less frequent Notifications
    Long Press Volume Keys to skip track
    Disable volume adjust sound
    Separate Ringtones & Notification volumes
    Expanded Volume Panel
    Navigation
    Navigation bar options - Size & Hide
    Left Handed nav bar in landscape
    Double tap to wake
    Sweep To Wake
    Double tap statusbar to sleep
    Wake on charge
    Keyboard cursor control
    Quick settings quick pulldown
    Long Press recent buttons to switch apps
    Long press back to kill app
    Customize clear all button location
    Security
    Privacy guard with advanced app opp control
    Blacklist for calls and sms
    Dialer
    Forward lookup
    Speed dial
    Vibrate on answer
    MMS
    Updated to material theme
    Pinch and zoom conversation screen
    Custom vibration patterns
    Quick reply
    Delay message timer
    Mms import & export
    Kernel
    Based on LeanKernel
    flar2 wake gestures
    intelli_plug
    intelli_thermal
    faux sound
    USB FastCharge
    USB OTG
    [/HIDE]
    Downloads
    Euphoria-OS Site | Android File Host | Android File Sharing | Basketbuild
    Fonte: http://forum.xda-developers.com/nexu...a-0-3-t2954615
    Ultima modifica di fabioo123; 22-04-15 alle 20:32
    Pro e contro riscontrati?
    Inviato dal mio Nexus 6 usando Androidiani App
