Kernel per Nexus 6 basato su un fork del Flash Kernel , con aggiunta di opzioni varie, tra cui la piena compatibilità f2fs.
Estremamente stabile , completo e performante.
> Caratteristiche versione stabile
F2FS
Upstream up to 3.10.103
Governors: nightmare, zzmove, chill, elementalx, barry_allen, blu_active, impulse,darkness
Hotplugs: Zen Descision, Blu_Plug, MSM Sleeper
I/O Schedulers: Maple (default), SioPlus, Zen, BFQ, Fiops
Many TCP Congestion Algorithms
USB Fast Charge
Full voltage, sound, vibration, and color control
GPU/CPU Over/Under Clocking (166-800)/(223-2880).
LZ4 Support
Kexec (MultiRom) support
Toggleable BCL/Selinux
UKSM
Ofast Optimizations
XZ Compressed
MSM Limiter (on by default)
Adreno Idler
Default swappiness lowered to 30
No forced throttle below 40% script
UberTC 6.2.1
Under the hood fixes/tweaks
Filesystem performance tunables in fstab
No Force Encrypt/ dm-verity
Built with AnyKernel2
Works on 7.1! Thanks to @Nautilus74 for testing
More to Come!
> Caratteristiche aggiuntive versione Beta:
Beta builds will now be stable release number + beta (v1.1 stable -> 1.11 Beta)
Space saving tweaks
BCL Tweaks from franco kernel
Added Simple GPU Algorithm by @faux123
Added Intelli_Thermal
Raised voltages uniformly for 223 Mhz CPU step
Added a slimmed BusyBox 1.26.0 built from their source by me with Linaro 6.1.1
Patched Dirty Cow vulnerability
MP Decision file is backed up to /system/bin/mpd-backup and then removed to prevent it's interference
Reverted back to mostly stock setting on boot, I will leave tuning up to you.
Reverted back to stock init.shamu.power.rc
Pre-Edited Stable Features list above, will merge by Tuesday
Opzioni del kernel consigliate dallo sviluppatore: Nightmare / Maple / Zen
IntelliThermal: 70° x clock throttle e 75° x core.
ReadAhead:1024
SELinux: permissive
Vibration: 50
LMK: attivo
UKSM: Off
GPU max clock: 600Mhz
Nè io nè il forum Androidiani siamo responsabili per tutto ciò che può accadere al telefono in seguito ad installazioni di kernel personalizzati.
Chi le effettua lo fa a proprio rischio.
