Pagina 46 di 79 primaprima ... 36444546474856 ... ultimoultimo
Visualizzazione dei risultati da 451 a 460 su 787
Guida al Root del Nexus 7
  1. #451
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    L'autore del toolkit per l'N7 ha messo disponibile per i sostenitori del suo progetto un update per il nuovo modello 4.2.2
    NEXUS 7 TOOLKIT AUTO UPDATE V4.3.4 [17TH FEB 2013] AVAILABLE!!
    Changelog:
    +Added FULL support for yakju/takju 4.2.2 Jelly Bean builds [everything works perfectly]
    +Added insecure boot image for 4.2.2 JDQ39 build for Nakasi and Nakasig for more stable operation
    +Updated google adb + fastboot files so device can connect on 4.2.2
    +Uploaded google stock images for 4.2.2 to goo.im and added links to Toolkit
    +Fixed several parts of code and made improvements
    +Completely restructured Toolkit code for future Toolkit integration
    I tried to get this out as soon as possible for people who are facing problems with 4.2.2 after updating. This update should fix everything and I will be updating all the other Nexus Toolkits over the next day. I can then finally start building the next set of public versions.
    [Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the donator features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other donator features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please pm me about them and do not post in the open thread]
    Thread Link: [Google Nexus 7 TOOLKIT V4.0.0] Drivers, Backup, Unlock, Root, CWM, Flash + MUCH MORE - xda-developers
    Enjoy
    Mark
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
    Androidiano VIP L'avatar di chefare
    Dec 2009
    Torino
    Ringraziato 431 volte in 406 Posts
    Per chi non ha la versione "donate" o ha comunque una versione vecchia del Toolkit traduco le istruzioni per aggiornare i file usati dal Toolkit in modo da poter usare ADB (con i file non aggiornati in Android 4.2.2 il tablet risulta "offline" per il Toolkit quando è i modalità ADB)
    "NOTA1: Gli ultimi auto updates per il Toolkit includono i nuovi file di Google perciò non dovrebbe essere un problema per quanti hanno auto-aggiornato il Toolkit recentemente
    1. Scaricare Goo.im Downloads - Downloading adb_fastboot_files_for_4.2.2.zip
    2. Assicurarsi che il Toolkit sia stato chiuso correttamente con l'opzione "x" nel menu principale, altrimenti il server ADB sarà ancora in esecuzione
    3. Estrarre il contenuto del file ZIP nella cartella del Toolkit (sovrascrivendo i file originali)
    4. Avviare il Toolkit, apparirà un popup sul tablet con la richiesta per l'autenticazione
    5. Toccare OK per aggiungere il PC alla lista dei dispositivi consentiti
    6. Selezionare l'opzione "Refresh Main Menu" nel Toolkit e il tablet sarà indicato come "device" e non più come "offline"
    NOTA2: I file del Toolkit non sono certificati da Microsoft e potrebbero essere rilevati come dannosi da alcuni antivirus come AVG free o Norton ed eliminati, in questo caso ripristinarli ed escluderli dalla scansione dell'antivirus."
    I file sostituiti nella cartella del Toolkit sono:
    adb-toolkit.exe
    AdbWinApi.dll
    AdbWinUsbApi.dll
    fastboot-toolkit.exe
    Ultima modifica di chefare; 17-02-13 alle 13:00
  4. #453
    SAMSUNG S20+5G
    Posso copiare il tuo come al solito molto centrato consiglio laddove ho inserito la info dellìupdate del tollkit ??
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  5. #454
    Dec 2009
    Torino
    Quote Originariamente inviato da paolocorpo Visualizza il messaggio
    Ehm sì sì, era solo la traduzione delle istruzioni che hanno scritto su XDA
  6. #455
    Ringraziato 104 volte in 95 Posts
    @chefare. Il fatto che il mio nexus venga riconosciuto come dispositivo multimediale, ma non abbia accesso al tablet... nel senso che non trovo alcuna icona in risorse del pc, può dipendere dai driver? Ho la 4.2.2
  7. #456
    Samsung galaxy S2 i9100G
    Ragazzi con la 4.2.2 avete notato rallebtamenti e frezee...di tanto in tanto prende e si frezza mai successo prima!
  8. #457
    SAMSUNG S20+5G
    Quote Originariamente inviato da As7aro7h Visualizza il messaggio
    IO no ma l0putilizzatore principale è mio figlio e quindi chiederò anche a lui
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  9. #458
    Dec 2009
    Torino
    A me, per ora, sembra funzionare bene, eventualmente potresti fare il ripristino dei dati di fabbrica
  10. #459
    Dec 2009
    Torino
    Quote Originariamente inviato da pigio76 Visualizza il messaggio
    Io su Windows 7 lo vedo sempre come prima, dei "dispositivi portatili" su "Computer", a te è cambiato qualcosa dopo l'aggiornamento?
  11. #460
    Sì... È rilevato come djsp multimediale ma non ho accesso effettivo al tablet. Non mi dà accesso da risorse del pc
