Pagina 2 di 4 primaprima 1234 ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 31
[ROM] [4.4] SlimKat (grouper) [Official Builds]
  1. #11
    Androidiano VIP L'avatar di KlaasMad
    /home/klaasmad
    OPO - Asus T100/Teclast x98
    Ringraziato 2,815 volte in 1,419 Posts
    Quote Originariamente inviato da killerfrog Visualizza il messaggio
    Ora quindi funziona tutto? Ero tornato stock per installare l'OTA che però tarda ad arrivare ma mi sta venendo voglia di provarla
    Purtroppo no, ho avuto un misunderstanding e non funziona ancora la rotazione e la camera, mentre tutto il resto vola una meraviglia. Ho aggiunto anche gli screenshots della batteria per un confronto con le versioni 4.2.2 e 4.3
    /home/klaasmad
    Aggiornato il secondo post con il changelog.
  4. #13
    /home/klaasmad
    Nuova build online!
    Quote Originariamente inviato da kufikugel
    it is currently a hard task on the one hand we bring all our devices up on the other hand we put back our features...some are redefined some we programm completly from scratch with new stuff. Eg today we pushed about 200 commits from 4.3 into 4.4 for our other devices + fixes for current devices
    but mostly ppl are interested in new features...so new build has:
    - superuser included (need to be enabled in developer options!!!)
    - a lot new features just discover them...to much to write up
    - a new crt animation...check it out
    - fix settings locale language problem
    - and tons of fixes under the hood
    and new build is up
    I added a simple list yesterday but it is actually more we have already included:
    - all keyboard features are back (force auto rotate, disable landscape fullscreen, force enter button, ime notification, volume key cursor control)
    - clock statusbar features
    - crt animation
    - statusbar brigthness slide
    - safe headset volume
    - volume rocker features (wake device, sound skip)
    - slims privacy guard
    - volume panel features we had
    - keyguard on supported devices shows now transparent navbar/statusbar as well
    - wifi country code
    - advanced reboot menu
    - custom LED battery and notification features
    - swipe qs -> notification and back
    - disbale OTA from google
    - slims camera and video features (smart capture, image quality, image size, gps indicator etc)
    - implemented root (needs to be enabled in developer settings or in superuser settings. Disabled by default)
    - tons of fixes in google code and optimizations
    - a lot under the hood stuff
    - and whatever I forgot to mention lol
  5. #14
    /home/klaasmad
    Build 4 online, aggiunto il changelog al secondo post.
    Mi sento un po' solo a scrivere sempre io
  6. #15
    Quote Originariamente inviato da Dionysus Visualizza il messaggio
    Ok, mi inserisco anch'io. Avevo provato la build 1 ma sono passato alla cyano 11 a causa del bug sulla rotazione. Ritornato subito alla slim build 4 e bypassato il bug alla rotazione con app. Fluida, scattante e veramente ben fatta.
  7. Il seguente Utente ha ringraziato gialeto per il post:
    KlaasMad (14-11-13)
  8. #16
    /home/klaasmad
    Quote Originariamente inviato da gialeto Visualizza il messaggio
    Ecco facciamoci compagnia hai provato ART?
  9. #17
    Senior Droid L'avatar di heatledger
    Jul 2010
    (VR)
    Ringraziato 75 volte in 65 Posts
    finchè non rilasceranno le stabili, o quantomeno beta, io non la installo
    sto aspettando l'ota 4.4
  10. #18
    /home/klaasmad
    Quote Originariamente inviato da heatledger Visualizza il messaggio
    Io sto usando queste build come quotidiane praticamente è KitKat puro con 3-4 features slim e la rotazione non funzionante.
  11. Il seguente Utente ha ringraziato KlaasMad per il post:
    heatledger (14-11-13)
  12. #19
    Banned
    Google Nexus 5
    Ringraziato 3,070 volte in 2,700 Posts
    Essendo un alpha ha molti bug ? Se la volessi usare e possibile farlo giornalmente ?
  13. #20
    /home/klaasmad
    Quote Originariamente inviato da 0raziel0 Visualizza il messaggio
    Gli unici due bug grossi sono il giroscopio non funzionante (bypassabile con Ultimate control center) e la Camera non funzionante (niente blobs per 4.4 ancora). Il resto funziona tutto a meraviglia, la uso come rom quotidiana e non mi da mai problemi. Arrivo tranquillamente a 6-7 ore di schermo dilazionate in 25~35 ore di scarica totale.
  14. Il seguente Utente ha ringraziato KlaasMad per il post:
    0raziel0 (14-11-13)
