Utente del giorno: Adriatic con ben 1 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: 9mm con ben 4 Thanks ricevuti negli ultimi sette giorni
[ROM][19JAN]CyberGR-MOD|NS.NGN ICS v.4 Hybrid+ICUP Speedy 5|CM9+AOKP|STORMY!!
    CyberGR-MOD|NS.NGN ver. 4.0 Hybrid ICS
    **CyberGR-MOD|NS-NGN ICS version 4 Hybrid is finally here with lots of changes, many additions and all ICS features working fully TWEAKED, really FAST, SMOOTH and STABLE..**
    Features :
    Based and built-on from latest sources of CyanogenMOD 9 + AOKP
    Kernel : ICUP Speedy 5 by eugene373
    Android version 4.0.3 - IML74K
    Radio : free (you can flash which is best for you and your area, or stay with what u have now)
    All the features till now supported from CM9 builts + AOKP additions
    SD-Nand Card I/O Speedtweaks - EXT4 | Ram Tweaks
    All Ezekeel`s Mods *BLN|BLD|BLX|Deep Idle|LIVEOC*
    NSTools by arifhn Integrated to easily configure all the above Mods
    Overclock able up to 1400Mhz + Extra Boost with LIVEOC
    Zipaling on boot
    Zipaling all apps for better Ram usage
    Fully Deodexed
    Rooted and Busyboxed
    Fast times on Reboots & Boots
    3G/HSDPA Tweaks
    Init.d scripts support
    Cron scripts support
    Full GPU HW accelaration
    Newest Host File (Ads.remove)- 95%+ of ads are now blocked
    Tweaked Trebuchet Launcher2.apk + 2 new wallpapers
    New HD ICS Galaxy Nexus Boot Animation
    Dev Tools + Spare Parts
    CyberGR-MOD Control App (Massive thanks to RomanBB and Open Kang Team for letting me use those source code.)
    Voodoo Control App
    Debugging notification hide tweak
    Working Media Effects under Video Recorder Settings
    Facebook Sync hack
    Newest Android Market and Google Music 4 ICS + MusicFX
    Car Home Included | Modified Calculator with scientific functions | ES File Explorer by EStrongs | ICS Sounds with +2db Boost |
    ROM Manager | Google Maps & Earth| Google+ & Messenger | Google Wallet |
    And more..
    What`s working : EVERYTHING!
    Installation Instructions :
    A clean install is recommended to avoid any FC etc.
    Download and copy the CyberGR-MOD.NS.NGN_ver.4*.zip file into your Nexus S storage
    Boot into ClockworkMod Recovery
    From main menu select wipe data/factory reset and wipe/cache partition
    Use Dalvik-wiper.zip to wipe Dalvik Cache.You can get it from here : Link 1 or here : Link 2
    From advanced select reboot recovery
    After rebooting recovery wipe data/factory reset & cache again and then from mounts and storage select format /system /data /cache /boot & if you want /sdcard
    From main menu select install zip from sdcard then choose zip from storage
    Select CyberGR-MOD.NS.NGN_ver.4*.zip and proceed with the setup.
    When done!Reboot your device
    First boot as expected might be slow but nothing to worry about, its normal.After first boot, before doing anything a reboot is recommended.(fixes misplaced CyberGR-MOD wallpaper in Ver.4 too)
    ENJOY!!
    PS : 1. First time NSToolls will ask you for superuser permissions, be careful to press ALLOW, then it will come up with a notification saying "some settings have been discarded" blah blah, don`t worry it`s absolutely normal!!Just open NSTools, configure and reboot!!
    2. Be careful don`t wipe battery stats, do it only if you want to calibrate your battery!!
    3. Version 4 requires a Clean Install...Huge Update...huge changes!!
    4. First start up might take a little bit longer this time.It`s 100% Normal.
    Download Ver.4 (Stormy) :
    Dropbox : Link
    FileSonic : Link
    (Huge thanks to my friend Harontas for offering me a Pro Oron account.)
    ORON : Link
    (Huge thanks to my friend Harontas for offering me a Pro FileSonic account.)
    CyberGR-MOD|NS.NGN ver.4 Hybrid ICS will be soon also into Rom Manager app. by Koush. Find it, Rate it, Leave a comment or feedback, Download it!!
    Extras :
    Gapps : No Gapps needed Please make a suggestion if you think that something must be removed or added reguarding the apps!
    DSPmanager : Link 1 - Link 2 In case someone still want it..!!But i don`t think there is a need.
    Tips & Tricks :
    Tip 1 : Trebuchet Launcher sometimes may be a little bit laggy when you open application drawer.Just press menu button when you are in home screen, select preferences and finally under Drawer menu un-check Join widgets with apps!! (Not any more in Version 4 and oncomings but always useful.)
    Tip 2 : Optional - Go to Settings -> Developer options -> Background process limit and select At most 4 processes.
    Disclaimer :
    You can always flash what ever kernel you want but keep in mind that this custom ROM has been tested and has been found to be really stable and fast with all features working on latest Ezekeel GLaDOS kernel.
    Recommended Kernel Alternatives :
    1 . GLaDOS V2.8 by Ezekeel-> Link
    2 . Matr1x ICS Kernel by mathkid95 -> Link
    3 . Reference for all ICS Kernel so you can choose which one fits you best by bedalus -> Link
    Please be aware that you are flashing at your own risk.
    I have spent many hours of my free time and nights asleep doing this (always with joy though), flashing the brains out of my Nexus S.
    So if you like my work, a small donation will be much appreciated for helping me buying a spare (used) Nexus S so my main device is not always tied up.
    Pressing the Thanks button is obligatory for encouragement!
    CREDITS and special THANKS to :
    CyanogenMOD 9 Team.
    Massive thanks to RomanBB for ROM Control App Sources and AOKP parts.
    Ezekeel for various MODs + Kernel.
    Supercurio for the voodoo app.
    arifhn for NSTools app.
    Eugene373 for ICUP kernel.
    Mathkid95 for Matr1x kernel.
    Morfic for dalvik-wiper.
    Bedalus for his very useful ICS Kernels comparison.
    My friend Harontas for offering me a FileSonic Pro & Oron account.
    Koushik Dutta for Rom Manager app. & host.
    ENJOY and don`t forget to press the THANKS BUTTON if you like my work!!Cost you nothing and gives me some encourage to continue my work!!
    Screenshots :
    LINK XDA: [ROM][19JAN]CyberGR-MOD|NS.NGN ICS v.4 Hybrid+ICUP Speedy 5|CM9+AOKP|STORMY!! - xda-developers
    la miglior rom mai provata in assoluto
    -Android*
    si ma è inutile che hai copiato quella roba dal sito,facevi prima a linkare il link del thread o se la volevi postare qua la potevi mettere in italiano.
    E poi hai copiato anche male , mancano i link....
    Ultima cosa,a me non piace molto....
    Ultima modifica di -Android*; 19-01-12 alle 23:09
    1 ringrazia il cielo che ho perso tempo a postarla 2 l'hai provata per giudicare?
    -Android*
    Quote Originariamente inviato da nicov Visualizza il messaggio
    ringraziare per cosa? CTRL+C + CTRL+V . 2 mancano le immagini 3. ovviamente facendo copia e incolla i link non si copiano es : : Link 1 or here : Link 2 , .-. dove clicco???
    ascolta basta io ho un nexus cosa sto a vedere le rom per il nexus s ciao..
    -Android*
    perchè l'hai fatto?
    pensavi che questa era una community poco attiva?
    ciao
    Jan 2011
    Galaxy S - Nexus S
    ahahah questa è bella
  9. #8
    Senior Droid L'avatar di Alessio70
    Mar 2010
    Roma - Trastevere
    Grande!!!!
    Quote Originariamente inviato da -Android* Visualizza il messaggio
  10. #9
    Mar 2011
    Io ho provato la versione 2 e poi la 3 ma avevo un paio di riavvii al giorno. Provato sia col kernel icup che col glados. Per la personalizzazione però è molto valida. Sono passato poi alla kangy che è stabilissima. Da 1 settimana nemmeno un riavvio
    Inviato dal mio Nexus S usando Androidiani App
    Nexus 5 Rom Linearboost
  11. #10
    Mar 2011
    Quote Originariamente inviato da Alessio70
    Grande!!!!
