[ROM] Nexus xperia 1.0.1 4.0.3 full release!
Nexus xperia 1.0.1 4.0.3 full release! - xda-developers
This is the port of the original beta XPERIA ICS ROM.
http://forum.xda-developers.com/atta...1&d=1332592293
UPDATE 24/03/2012
Full release :
Bad Request - FileFactory
Mirror
NexusXperia 1.0.1 - Minus
FULL WIPE IS RECOMENDED
Fixed:
Touchscreen
Wifi
Camera ( original ics camera for the moment)
market
root
To get ROOT access:
1.Flash the superuser fix via recovery. Superuser-3.0.7-efghi-signed.zip
2. Go to the market and download busybox by Stephen Sterricson and then select any version of busybox and install it. NOW YOU HAVE ROOT
****For the launcher fix check post 133*******
In case the market says that the device is not compatible open the build.pro file and change the line: ro.sf.lcd_density=230 to 240 and you will be ok.
UPDATE 23/03/2012
Huge progress during this time.Now XPERIA S framework.
ALPHA RELEASE
Radio fixed
Data fixed
Bluetooth Working
Lights working
Gallery working
USB & Storage working
Music works
Screenshot working
Internet works.
Orientation, xloud, ringers,timescape, track id and etc xperia stuff works.
BUGS:
The dock of the Home launcher is a little out of borders.I ma looking for a good looking version.
Pattern Lock
