Visualizzazione dei risultati da 1 a 10 su 28
[ROM][JBO03E][i9020T,i9020A,i9023] Brainmaster's Stock JB 4.1.1
    Androidiano L'avatar di nuccio23
    Ringraziato 11 volte in 6 Posts
    Ho deciso di riportare anche qui, con link a XDA, il thread della rom JB 4.1.1 di Brainmaster per il nostro Nexus S.. La sto usando ora e mi trovo molto bene!
    Questo quello che trovate sul suo post su XDA
    What do you get with this ROM?
    Its Full Stock JB 4.1.1 ROM that includes following
    Tweaks:
    - Deodexed
    - Rooted
    - Zipaligned
    - Busyboxed
    - Busybox Run-Parts (support for scripts in the init.d)
    - Supercharged
    - Circle Battery
    - Unsecured Boot.img
    - ADB Enabled
    - EXT4 and TCP Tweaks
    - Dalvik moved to the /cache partition
    - Advanced automated Zipaligning of system/app and /data/app
    - ADFree Hosts file
    - Sticky Recovery (Custom recovery doesn't get overwritten after flashing the ROM)
    - Unicode support for SMS/MMS
    - AppWidgetPicker
    - 360° Rotation
    - Symlinked SDCard to /storage/sdcard0
    DISCLAIMER:
    You are installing this ROM on your own risk!
    How to install:
    - Copy ROM file on your SDCard,
    - Start Recovery,
    - Go to "mounts and storage" and select format /system, /data, /cache, /boot,
    - Install ROM,
    - Reboot,
    - After the Setup procedure, let the Phone settle down for few minutes.
    Further Instructions:
    Don't forget to Force the GPU Rendering in the Developer Options.
    Download:
    Brainmasters.JB.4.1.1.JRO03E.Nexus.S - Size: 198 MB MD5: 1c7f4896c52937a4fce912db33a7104a
    If you like this ROM you can support my work with a PayPal Donation.
    Note:
    This is probably my last tweaked ROM for the Nexus S Community, since I'll be probably moving in the next weeks to GNex.
    You are great guys and great Community - thanks for supporting my work. Without you, I wouldn't spend so much time tweaking my Phone.
    TRADUZIONE:
    Cosa avete con questa ROM?
    E' una rom stock JB 4.1.1 che include le seguenti
    Modifiche:
    - Deodexed
    - Rootata
    - Zipaligned
    - Busyboxed
    - Supercharged
    - Circle Battery Mod inclusa
    - ADB Abilitato
    - EXT4 e TCP Tweaks
    - Dalvik spostata nella partizione /cache
    - ADFree Hosts file
    - Sticky Recovery (La custom recovery non viene sovrascritta dopo aver flashato la ROM)
    - AppWidgetPicker
    - Rotazione 360°
    DISCLAIMER:
    Installate questa ROM a vostro rischio e pericolo!
    Come installare:
    - Copiare la ROM nel telefono
    - Riavviare in Recovery
    - Andare in "mounts and storage" e selezionare format /system, /data, /cache, /boot
    - Installare la ROM (install zip from sdcard e scegliere la ROM)
    - Riavviare (reboot system now)
    - Dopo la procedura d'installazione, lasciare che il telefono si assesti per qualche minuto.
    Ulteriori istruzioni:
    Non dimenticate di spuntare il Rendering GPU nelle Opzioni Sviluppatore.
    Download:
    Brainmasters.JB.4.1.1.JRO03E.Nexus.S - Dimensioni: 198 MB MD5: 1c7f4896c52937a4fce912db33a7104a
    Mi sono permesso inoltre di postare la rom anche su Mediafire come mirror link, visto che l'originale è moooolto lento..
    MIRROR LINK MEDIAFIRE
    Spero di essere stato utile, e nel caso serva altro al thread principale scrivetelo che provvederò ad aggiornare al più presto!
    (P.s. Ciao Brainmaster ci mancherai!)
    Eccovi anche qualche screenshot
    Screenshot_2012-07-21-14-49-20.jpg Screenshot_2012-07-21-14-49-55.jpg Screenshot_2012-07-21-14-50-16.jpg Screenshot_2012-07-21-14-50-58.jpg Screenshot_2012-07-21-14-52-59.jpg
    Ultima modifica di nuccio23; 21-07-12 alle 15:59
    Telefoni principali: SE Xperia X10 Mini Pro > Blackberry 9700 > iPhone 3GS (periodo buio della durata di un mese) > Samsung Galaxy S2 > Samsung Galaxy Note
    Altri posseduti: LG Optimus 7, Huawei Sonic, Motorola Fire, Samsung Galaxy Tab 7, Google Nexus S
    Galaxy Note: CyanogenMod 9.1 stable
  2. I seguenti 4 Utenti hanno ringraziato nuccio23 per il post:
    alessinho (21-07-12),d128b (21-07-12),Eidolon (23-07-12),ELX75 (22-07-12)
    Traduzione trascritta! Spero ora vada bene!
  5. #3
    Quote Originariamente inviato da nuccio23 Visualizza il messaggio
    l'ho appena installata...speriamo bene
  6. #4
    Quote Originariamente inviato da alessinho Visualizza il messaggio
    Se hai seguito tutte le istruzioni (pochissime a dir la verità) puoi stare tranquillo.. Brainmaster è una certezza!
  7. #5
    Nexus s
    Appena installata.. va da dio.. ma instagram non é ancora compatibile con jelly bean? Mi dice che non é disponibile per il mio dispositivo..
    Inviato dal mio Nexus S usando Androidiani App
  8. #6
    Quote Originariamente inviato da castel89 Visualizza il messaggio
    A me va tutto normalmente eccetto Viber.. Instagram compreso..
  9. #7
    Senior Droid L'avatar di varefaz
    nexus s
    Ringraziato 113 volte in 74 Posts
    cos'è il rendering gpu?
    Nexus 5
    kernel: stock | uber kernel
    rom: PA|Pure White|LS|Pulse|Hazy.4
    [GUIDA] Governor e Scheduler: kernel settings
    <- ti sono stato utile ?? ringraziarmi con il tasto Thanks qui in basso
  10. #8
    Quote Originariamente inviato da varefaz Visualizza il messaggio
    Si attiva tramite Impostazioni > Opzioni Sviluppatore > Forza Rendering GPU
    Proprio nella descrizione della funzione ti spiega a cosa serve! Dice: "Forza l'uso della GPU per i disegni 2D"
  11. #9
    Galaxy Nexus
    Installata anche io e con il kernel Air per JB. Niente male!!!
    A voi funziona Google earth?
  12. #10
    Baby Droid L'avatar di Alexone
    Mar 2011
    Samsung Galaxy S3
    No, a me non funziona :-(
    Inviato dal mio Nexus S con Tapatalk 2
