Utente del mese: megthebest con ben 19 Thanks ricevuti nell'ultimo mese
Pagina 1 di 28 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 276
[ ROM ][INFO][AOSP][ICS] 4.0.4 IMM76I Android Open Kang Project "AOKP"
    Androidiano VIP L'avatar di Pakobis
    Taranto
    Nexus 5 - Tab Acer A500
    Ringraziato 153 volte in 117 Posts
    Per chi volesse provare la Rom AOKP creata da "Roman" e non quella con le modifiche di "Haka", può utilizzare questo topic.
    Riferimenti:
    Topic Ufficiale su XDA: Nuovo Link
    Post di riferimento per il download di temi personalizzati: Link
    Topic Ufficiale AOKP: Link
    Download per Nexus S della Milestone 6: Link
    Download delle GAPPS 29042012: Link
    Changelog Milestone 6:
    Removed FB sync
    Added ability to hide sender and/or message body in notifications (Mms)
    Added CM9 T-Mobile theme manager
    Added Sense 4 style Task switcher (you have the option of choosing from stock/web os/sense 4 now)
    Added ability to play boot sound (disabled by default) -- read instructions in ROM Control > General > Boot sound
    added delayed ring feature to Phone
    added Emoji to Mms (enable in Mms settings)
    added AOKP wallpapers app
    added USB tether toggle,
    added AOKP clock widgets
    added notification counters
    new boot animation
    added nav bar widgets (must add nav bar widgets button/long press button in nav bar settings and add some widgets to play with!)
    added AOKP stats (www.stats.aokp.co) -- you can opt out
    added bluewall firewall - RC > General UI > Less Notification Sounds -- limits the number of notification sounds an app can play per X seconds, so like 1 GTalk ping/30s, but notifications will still be coming in
    improved weather code
    added "copy to clipboard" option in "Share" dialogs throughout Android
    added hardware info in about screen
    added new music layout to lockscreen (you can choose between old and new)
    added nfc toggle
    added nfc polling settings (Settings > More > NFC polling mode)
    made lockscreen weather prettier
    fixed DRM issues
    Changelog b40:
    added hardware info in Settings > About
    fixed DRM issues (including Hulu)
    made lockscreen weather much prettier
    fixed tablets
    added NFC polling mode Settings > More > NFC polling mode
    added NFC toggle
    added Achromatic theme
    updated Nova
    fixed added custom WiFi SSID FC
    always moar things!
    Changelog b39:
    - added ability to change host name (settings > dev > device hostname)
    - added ad-hoc network support
    - added adb over network
    - added AOKP stats (you can opt out, Settings > About > AOKP Statistics) www.stats.aokp.co
    - added bluewall firewall - RC > General UI > Less Notification Sounds
    --- limits the number of notification sounds an app can play per X seconds
    --- so like 1 GTalk ping/30s, but notifications will still be coming in
    - added "Device options" link in Settings for devices that have an app to tweak device-specific settings
    --- right now I believe only tuna/aries/p1c have these, all credit goes to CM trees where these apps came from
    - improved weather code, shouldn't bother you everytime it updates weather now
    - added "copy to clipboard" option in "Share" dialogs throughout ANdroid
    - added ability to toggle to "new" and "original" music controls on the lockscreen
    - as always, tons of other device-specific and internal changes, find them all at http://gerrit.sudose...atus:merged,n,z
    Installazione:
    Potete seguire la Guida che ho scritto in QUESTO topic
    N.B.: Non mi assumo nessuna responsabilità su eventuali danni o esplosioni, generati al vostro terminale... Siate responsabili.
    Ciao Pako
    Ultima modifica di Pakobis; 09-07-12 alle 11:47
    Google LG Nexus 5 D821
    Nougat - 7.1.2 - Dark Rom
  2. I seguenti 3 Utenti hanno ringraziato Pakobis per il post:
    19venom89 (23-02-12),morrigan91 (06-06-12),Train (15-05-12)
    Taranto
    Immagini allegate
    Ultima modifica di Pakobis; 25-05-12 alle 18:06
  5. #3
    Androidiano VIP L'avatar di Glad
    Pescara
    Nexus 5
    Ringraziato 134 volte in 129 Posts
    Quote Originariamente inviato da Pakobis Visualizza il messaggio
    hahaha
    Nexus S, Galaxy Nexus, Nexus 5, Nexus 7 (2013)
  6. #4
    Taranto
    come si dice... prevenire è meglio che "curarsi"... no?..
  7. #5
    Senior Droid L'avatar di 19venom89
    Honor 9
    Ringraziato 22 volte in 22 Posts
    quali sono le differenze tra le 2?
  8. #6
    Taranto
    Quote Originariamente inviato da 19venom89 Visualizza il messaggio
    citazione dal topic di Haka:
    F.A.Q:
    Q. What is changed from original AOKP?
    A. Tweaks:
    ADFree Hosts
    egl.cfg tweak to disable Graphic Driver
    SD Card optimization
    Zipaligned apk's for better RAM Usage
    Batch deodexed
    Graphical Tweaks:
    Changed ROM Control icon in the Settings Menu and ROM Control Menu
    Changed Bootanimation
    Optimized PNG's using the APKTool
    New Icons in ROM Control, derived from ICS
  9. #7
    Honor 9
    quindi conviene installare quella se ha tutte queste migliorie no?
  10. #8
    Taranto
    dipende... sto leggendo in giro che ci sono persone che hanno avuto problemi sia con la v15 che con la v14...
    quello che io penso è che se uno ha tempo da perdere dovrebbe provare tutte le rom per poi decidere quale soddisfi le proprie esigenze e non seguire la massa per "moda"..
  11. #9
    Pescara
    Nexus 5
    io posso dire che dopo qualche giorno con la Kangy11 di Haka...forse a causa del tema che avevo messo...il telefono si riavviava, era laggoso, ecc...e sono tornato sulla fedele codename...
  12. #10
    Taranto
    infatti sto leggendo che qualcuno non si sta trovando bene con le rom moddate di Haka.. questa è la base su cui Haka apporta le sue modifiche...
