Method of installation:
We Wipe total (third option)
V2 SuperOSR install and reboot the system stop.
You can configure the rom to your liking
ATTENTION!
This rom installs itself alone, that is totally reconfigured.
I recommend that you setup salteis account giving to omit google and once in the launcher now you can configure the rom to your liking. This is because the phone but the market is autologin and automatically begin downloading all the applications you had installed and it saturates the terminal because it does hit, plus it puts the background image that you had prior to the rom and then you ask me than it is possible that if I install the rom wipe me see the bottom it had before. Thus will you do a clean install. Then you enter the market and a free instalais anyone to cool that you have installed on the terminal.
Very attentive to you to do restorations of any kind or program against rom that you can have problems. (I mean backups, including their own SupSetup least in the section on applications), special attention to restoration of configuration data of any kind. Under certainly better not to.
New SupSetup V20 in all roms, not serve any previous SupSetup for this rom
The new integrated SupSetup activation brings on-demand applications in the applications section extras, you can enable applications that interest you and the rom is in "Lite" (without extra applications installed) for each to choose your best settings.
It is important before you set up Google account to be activated from the applications before SupSetup so that when you connect to the servers to configure your Google account, they enter the download.
After entering the market and to display applications install any application downloads for cool downloads.
General
- Rom in "LITE"
- New graphical look different from SuperGinger's
Added
- Wake & Unlock
- Bluetooth always visible from Settings (tolemaC)
- Hide clock
- Percentage of battery
- It's part of Cyanogen CyanogenModsettings
- Etc ...
Applications
- You can install more applications from SupSetup extras
- Google Apps
- Flash Player 10.3
Reordering of wireless
Update all external apks
Current owners of Samsung
Lower consumption of wifi
Softer Launcher
New recovery recommended but not installed
Ciao raga l'ho installata ieri la v2, devo dire kche va veramente da dio! Poi veloce della v1 e la batteria dura di più! Cmq il tema preferivo quello della v1.. c'è modo di estrarre i file della v1 e quindi avere lo stesso tema sulla v2?
Anch'io ho installato ieri la superosr 2 ma ho un sacco di radio dump e di force close. Ho appena abilitato le 2 opzioni "optimize the system" e "may the force be with you" nel sotto menu del supsetup, vediamo come si comporta. Secondo voi può essere la radio KD1 o è proprio la rom?
