Features:
-System wide audio (no need to turn anything on, it will work already like normal sound)
-Custom compiled libasound.so library (thanks to aznrice2k4)
-Custom made asound.conf specifically for [apq8064tablasnd] soundcard
-Custom made asound.conf specifically for [msm8974taikomtpsnd] soundcard (HTC one m8)
-Custom made asound.conf specifically for [msm8994tomtommtpsnd] soundcard (HTC one m9)
-Significantly reduced distortions
-Super-high quality audio
-Oversampling to reduce noise, improve anti-aliasing and resolution
-Disabled LPA completely
-Beats Audio Tweaks (See Post 3 for more info)
-Dolby Atmos with customizable DSP options (forces 24bit playback) (See Post 3 for more info)
-Exclusive Signature presets exclusive to Dragon-Fi Audio (PsychoRealism and InfinitySound) (See Post 3 for more info)
-Intenseblast speaker boost (Another signature speaker preset made by me) (See Post 3 for more info)
-Force 192/24 audio via compression driver for M9 ONLY (EXPERIMENTAL)
Supported Devices/Chipsets:
APQ8064 (Snapdragon 600/S4 Pro):
HTC One
HTC One Dual Sim
HTC One Max
HTC Butterfly S
HTC Droid DNA
HTC Butterfly
MSM8974 (Snapdragon 801):
HTC One (M8)/(E8)
HTC Desire EYE
Code:
Dragon-Fi Audio v26:
- Fixed Volume Leveller bug in Atmos
- Added Atmos for M9
- Retuned profiles for Atmos M9 only (Different sound to previous HTCs)
- Fixed Dolby Uninstallation
- Added IntenseBLAST for Atmos, HTC BoomSound with Dolby and Atmos for M9
- Removed old Dolby Atmos presets, kept PsychoRealism and added new Speakers preset
- Slight preset name edits in AsUi
Dragon-Fi Audio v25:
M9 Specific:
-Enabled Dolby Speaker Surround in Speaker Theater Mode (M9)
-Reduced noise and distortion on PsychoRealism (My modified preset for "Others", M9 only)
-Enabled Distortion Regulator on PsychoRealism (My modified preset for "Others", M9 only)
-Good balance between treble and bass in PsychoRealism (My modified preset for "Others", M9 only)
-Added InfinitySound (modified Earbuds preset) (M9 only)
-EXPERIMENTAL (M9 ONLY): Force 24 bit 192KHz playback to all mp3/aac/flac formats via compression driver
M8 Specific:
-Disabled M8 beats port (for now, might come back to it in the future) still having problems with the one @doma999 sent me but he is working hard nonetheless
Generic:
-Updated Dolby Digital Plus to Dolby Atmos (Thanks @worstenbrood, @ahrion and @aki_007 for porting!) (M7 and M8)
-Re-enabled compression driver/audio offload (M9 and M8)
Dragon-Fi Audio v24.1:
-M9 USERS: Dolby REMOVED due to conflicting issues of insanely loud headphone audio and overprocessing
-Fixed uninstall Dolby option
Dragon-Fi Audio v24:
-Renamed Project ERA to Dragon-Fi Audio
-Renamed Generic Dolby to Dolby Audio
-Removed Huawei Dolby
-Added HTC One M9 support
-Added Sense 7.0 support
-Disabled buggy Audio Offload
-Simplified and refined AROMA installer
-Fixed M8 beats port and installation issues
-Themed Dolby Audio UI to imitate M9 BoomSound with Dolby
-More Dolby Audio UI theming including widget (Thanks to @Kansasboy001)
-Modified Dolby Audio endpoint to match m9's config
-Dolby Audio is as close to M9's Dolby as we can get (FYI: Speaker Mode replicates Music Mode on M9)
-Special version of PsychoRealism profile only for M9 BoomSound with Dolby (Choose "Others" headset profile in BoomSound settings to activate)
-Added option to uninstall Dolby Audio
-Extra: Try and kang me now you little ****s
Project ERA v23.2:
-Added proper Beats Audio port for M8 (Thanks to @doma999 for porting)
Project ERA v23.1:
-Fixed NEW (Generic) Dolby Digital Plus "Play Demo" sound (Thanks to @Kansasboy001 for alternative fix!)
Project ERA v23:
-Added a new Dolby Digital Plus, officially from Dolby (Thanks to @aki_007 for getting the port working without framework modifications, Thanks to @riyono/@ocoot for the files/tutorial)
-My custom config for Movie preset in Dolby Digital Plus, you can customize any preset, anytime
-Moved things around in AROMA Installer (More features are put into options)
-Updated names in AROMA
-Added notes page in AROMA to (hopefully) get lazy people to READ THE DAMN THING BEFORE ASKING REPEATED QUESTIONS
-ONE MAX USERS: Enabled Beats Tweaks, ONLY IF YOUR ROM HAS BEATS AUDIO, NOT FOR STOCK ROMS!
Project ERA v22:
-Added Dolby fix for AOSP ROMs
-New improved Dolby presets
-Updated Dolby Digital Plus to r7 (Thanks @worstenbrood)
-Modified preset names to differentiate between stock presets and ones edited by me (Thanks @worstenbrood for decompiling/compiling for me)
Project ERA v21:
-Added Dolby Mobile! MAJOR THANKS TO @worstenbrood!!!
-Heavily Tweaked default and rock presets on Music Mode Dolby
-Music Mode Default Dolby enabled Matrix Decoder + Mobile Surround Upmixing
-Enabled hidden configuration options in dolby_config
-Forced Native 24Bit Audio playback for M7 Sense/GPE, NOT WORKING ON AOSP (FINALLY!)
-Dolby Mobile Sample Rate Multiplier x4
-Removed V4A profiles from the soundmod (Will still be in your storage if previously installed though)
-Tweaked presets: Music: Default/Rock, Movie: Default/News
-Moved project era installation conformation to /system/
-Removed my SRS tweaks - obsolete now
Project ERA v20:
-Fixed updater script
-Added SRS Headphone 360 Profile
-Added SRS CircleSurround II Profile
-Added SRS TruSurroundXT Profile
-Added new DTS Headphone-X (11.1ch) Profile (Redone IRS from 11 channels provided by Vinardo_ZzZ 2000)
-Added new DTS Headphone-X 9.1ch variant profile
-Added new DTS Headphone-X 7.1ch variant profile
-Added new DTS Headphone-X 5.1ch variant profile
-New speaker profile (Using TruSurroundXT) available on all profiles (except CircleSurround II)
-Removed 97era init.d script to fix microphone bug (IT SHOULD FINALLY FIX FOR EVERYONE)
Project ERA v19.1:
-FIXED MICROPHONE BUG ONCE AND FOR ALL
Project ERA v19:
-Added back IntenseBLAST options for HTC Droid DNA and Butterfly
-Removed options for Beats Audio/IntenseBLAST tweaks for HTC One Max users (incompatible)
-Added new MatrixWideSurround profile (Wide soundstage and larger room size) thanks to @vinardo_ZzZ 2000 for the custom IRS
-Added surround-sound ambiophonics for stereo speakers (Available on all profiles) thanks to @BSDgeek_Jake for IRS
-Added 7.1ch Surround Sound simulation profile (Thanks to @jmxc23 for the Surround Sound 7.1 IRS)
-Hopefully fixed microphone issues again
-Fixed updater-script
-Added compatibility for HTC One (M8) GPE ROM users
-Added compatibility for Android 4.4.4 GPE users
Project ERA v18.1:
-Fixed Status 7 errors (Thanks @FISHa21)
-Added Project_ERA_Version.txt in /sdcard/ to confirm installation/version number
-Fixed no sound on AOSP M8 users
Project ERA v18.0:
-Added support for ALL AOSP ROMs
-Added support for all variants for HTC One Max
-Refined AROMA Installer
-Hopefully fixed microphone bug
-Updated soundfx libraries from Nexus 7 Android L preview firmware
-Improved V4A DTS Headphone-X profile:
-Playback AGC set to 4x with output gain at 2.3dB
-62Hz and 125Hz Bass region is now +6dB
-Field Surround set to extreme with mid image at slight
-Changed clarity mode to XHiFi now - should be MUCH better than before
-Increased 8kHz for more exciting sound
-Decreased 2KHz for more clarity by getting rid of some high-mids
-Disabled Cross-channel for better surround sound simulation
-Larger reverberation room size (wider sound-space)
-SoundField decreased to 5m for less echoes
-Wet Signal set to 10
Project ERA v17.1:
-Fixed Visualizer for HTC One M8
-Fixed power button end calling audio bug for HTC One M8
-Fixed H/K Audio
-Added .nomedia file in Viper4Android kernel folder to prevent detection of WAV files in other music players
Project ERA v17:
-Added my personal Viper4Android audio profile (Featuring DTS Headphone:X 11.1ch rough simulation IRS thanks to @vinardo_ZzZ 2000 for making my request IRS!) (You must install V4A from the official thread in order to use this profile: http://forum.xda-developers.com/show....php?t=2191223)
-Added compatibility to GPE Android 4.4.3 ROMs
-Cleanup from some old files
-Updated soundfx libraries from Nexus 4 Android 4.4.3 firmware
-Fixed video recording in GPE ROMs
-Re-done audio_effects.conf (Might fix visualizer problem)
Project ERA v16.3:
-Removed new sense 6 audio libraries (Most ROMs will have it by now)
-Reverted AROMA Installer changes from v16.1 (Should fix all bugs present in v16.2 for all users)
Project ERA v16.2:
-Fixed compatibility issues with Google Play Edition ROMs
Project ERA v16.1:
-Fixed compatibility issues with Harman/Kardon audio port (M8 ONLY)
Project ERA v16:
-Slightly modified 5.1/movie/music/voice SRS TruMedia presets
-Cleaned-up build.prop script
-Cleaned-up audio_effects.conf and audio_policy.conf
-Enabled Audio Offload to DSP via HiFi Tunneling(Decreased battery drain)
-Enabled Audio Offload streaming
-Enabled Audio Offload Gapless playback
-Set audio offload buffer size to 32kb (Low Latency playback)
-Fixed audio seeking issue for some people
-New Sense 6.0 Audio libraries update from Sense 6 OTA (M7 ONLY)
-Compatible with Harman/Kardon audio port (M8 ONLY)
