Rom ICS Desire S
    Androidiano VIP L'avatar di frrndr75
    Torino
    Vodafone 858/ HTC Desire s
    Ringraziato 162 volte in 147 Posts
    Rom ICS Desire S
    Ciao a tutti, vista la quantità di rom che stanno uscendo ho fatto un riassunto alcune info le ho prese da altri forum:
    Se ne sapete altre segnalate
    Roms con Android 4 + Sense 4
    Derivate da HTC One V & S
    Primo-S v4.1 [ROM] [02-06] Primo-S - v4.1 [HTC One V port] Android 4.0.3 [Kernel 3.0] - xda-developers
    Fallout v.2.0 [ROM][5 JUN 12][Fallout V2.0.0| Sense 4.0A| ICS 4.03] [Kernel Stock 3.0.16] - xda-developers
    ICS Saga Edition v.2.0 [ROM][29-5] ICS Saga Edition v2.0 [HTC One S port][4.0.3 ][Kernel 3.0.16] - xda-developers
    CoolDroid v 5.0 [ROM][7 Jun] CoolDroid v.5.0 [Sense 4][4.0.3][Kernel 3.0.16] Fast & Stable - xda-developers
    SenseMOD FlashONE v2.0.3 [ROM][2 June]SenseMOD FlashONE v2.1 //OTA//EQS//V6S//SuperStable&Fast// [F1 Kernel] - xda-developers
    Roms con Android 4 + Sense 3.6
    Derivate da HTC Desire S & EVO 3D
    Ice Eclipse V1.0 [ROM][May 26]ICE ECLIPSE V1.0 [3.04.401.1][Sense 3.6 Android 4.0.4][HTC 3 Kernel] - xda-developers
    Virtuous Saga v.1.0 [ROM][May 23]Virtuous Saga v.1.0.0 [3.04.401.1][Sense 3.6 Android 4.0.4] - xda-developers
    Ics DS v.3.0 [ROM][25 May] ICE_DS -v.3.0 ICS 4.0.4 Sense 3.6 - xda-developers
    WaterBear DSense v3.5 HTC Desire S e EVO 3D con ICS grazie alle ROM WaterBear
    Roms con Android 4 senza Sense
    Derivate da CyanogenMod & AOKP
    CyanogenMod 9 Alpha Builds CM 2.6.35.14-ICS [ROM][31 MAY 12] CyanogenMod 9 Alpha Builds [4.0.4][CM 2.6.35.14-ICS] - xda-developers
    Paranoidandroid v1.1.3 [ROM][JUNE 07] PARANOIDANDROID v1.1.3 | Tablet / Hybrid ROM | ICS 404 | PAL | PAD - xda-developers
    AOKP Desire S [ROM][270512]Unofficial AOKP for Desire S [BETA][4.0.4][Build 37][CM9 Kernel] - xda-developers
    IceColdSandwich v.8 final [ROM] | 1 JUN 12 | IceColdSandwich 8 Final Edition | ICS | CM9 Kernel - xda-developers
    Ultima modifica di frrndr75; 09-06-12 alle 16:36
    Un thanks non fa mai male
    HTC Desire S DualBoot
    Rom----Fallout Evolution V4.4 / IceColdSandwich 8.1 Perfecto-Linaro Edition ICS CM9 Kernel
    Base----2.08.401.2 One V RUU
    Android----ICS 4.03
    HTC Sense---- Sense 4.0a
    Huawei u8160
    Rom----Cyanogenmod 7.2 ac1963
    Android----2.3.7
    la migliore quale'??
    Torino
    la fallout va molto bene pochi problemi, alla fine i port arrivano dal one v, pero mi sa che ritorno alla endymion e perfetta avra android inferiore ok, pero e molto meglio. poi sono solo pareri miei pero la durata della batteria e inferiore la conessione gps con lo stesso file gps.conf sulla endy ne aggancia 9 in 10 sec. con fallout 7 in piu di 25sec. poter controllare la frequenza cpu non c'è alcune cose nel menu fallout tweaks non funziona. nel gestore attivita la ram totale e 10mb piu bassa della endy, non sono cose cosi gravi pero ancora non mi convince meglio aspettare che esca ics ufficiale e poi vedere cosa fanno quei cervelloni di xda con la rom ufficiale e tutte le cose funzionanti compreso sense 4.
    comunque voglio provare una guida che ho trovato per mettere sense 4.0 su android della endymion se funziona sono contento.
    Android----ICS 4.03
    Huawei u8160
    Android----2.3.7
    endymion lo provata mi sn trovato bn,mi sa che la rimetto ;P
    Filadelfia (VV)
    Samsung Galaxy S4
    e tra la fallout e la primo-s, qual'è che ha meno problemi? Qualcuno le ha provate entrambe?
    Torino
    praticamente leggendo su xda si sono aiutati entrambi a riparare i bug, quindi suppongo che come bug sono uguali io ho provato la fallout e sono ritornato alla endymion.
    Android----ICS 4.03
    Huawei u8160
    Android----2.3.7
    Jan 2011
    Correggetemi se sbaglio ma la Virtuous Saga non dovrebbe essere praticamente l'aggiornamento ufficiale HTC?
    Inviato dal mio HTC Desire S usando Androidiani App
  9. #8
    Senior Droid L'avatar di NeTvAmPiRe70
    Dec 2009
    Farigliano (CN)
    LG Nexus 4
    Ringraziato 186 volte in 175 Posts
    ...dovrebbe assomigliare molto all'aggiornamento ufficiale
    DAMMI UN THANKS SE TI HO AIUTATO
