Pagina 1 di 31 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 308
Andromadus audacity
    Androidiano L'avatar di Zendarino
    Huawei P9 Lite
    [ROM] Andromadus Audacity BETA5
    ANDROMADUS AUDACITY BETA 5 [30-06-12]
    Rom basata su CyanogenMod 9 con ICS per HTC Desire Z!!
    THREAD ORIGINALE: http://forum.xda-developers.com/show....php?t=1349864
    THREAD OTTIMIZZAZIONI PER LA ROM: Consiglio vivamente di leggerlo http://forum.xda-developers.com/show....php?t=1532742
    Cosa funziona?
    Radio ( Telefonate, Internet Mobile, SMS/MMS )
    Touchscreen
    Wifi
    Bluetooth
    Tastiera Fisica
    Audio
    Real Full HW Accel
    Screen Orientation
    GPS
    USB - UMS
    Camera
    Altre cose
    Cosa non funziona?
    Radio (non presente)
    Altri me li direte voi!
    CHANGELOG
    Beta 5: Prossimamente (aspettiamo dal thread ufficiale)
    Beta 4:
    Keyboard mapping fixes for various languages
    Merged in CM custom lockscreen fixes
    Merged in CM render modes
    Merged in CM theme engine
    Replaced Stock Music player with CM's Apollo
    Merged in RIL changes to improve mobile connectivity and signal strength
    Various improvements and speed increases added to the kernel
    Added Brightness toggleslider to Notification drawer (activate in Andromadus Settings)
    Made higher frequencies available in the kernel
    Various QCOM merges to improve performance
    Text Corruption reduced (but still present*), will most likely occur immediately following a reboot or wipe. To temporarily fix: Kill app or restart launcher, no need to reboot) *Please help us squash this longstanding bug! Provide logcats when at all possible!
    Obligatory Tweaks!
    Other bug fixes and patches not mentioned here.
    Beta 3:
    Merged in changes for webkit and updated to newest CM repos.
    Fixed issue where power saving does not work on certain APs under certain conditions causing wifi to drop during sleep without notice. (credit to nyt)
    Fixed Keyboard brightness backlight for hidden keyboard
    Fixed Camera focus button
    Added Statusbar IME Switcher toggle
    Fixed speakerphone/on hold/mute issues
    Optimized compiler CFLAGS
    Fixed bootanimation resolution
    Added camera button play/pause for music when screen is off
    Merged in a whole bunch of camera HAL / qcom changes
    Added expanded volume overlay
    Fixed delay for incoming call screen draw
    Merged in upstream patches adding customize lockscreen actions with custom icons
    Merged in upstream patches for in-call vibration options
    Merged in changes that reduce system wakelock.
    Re-enabled hardware accelerated webkit browsing
    So many kernel changes we would need a 2nd post to list them all (look at the repo if you really want to know)
    Beta 2:
    Re-based on CM's framework_base with a load of patches merged back in, 6bar,trackpad wake etc, hopefully I didn't miss anything important when re-creating the framework_base, many hours of work went into it.
    With the above change we are much closer to the CM source base but with a few additions of our own and a few copied from elsewhere
    Camera should work with no corruption in the stock app, no guarantees when it comes to anything else right now!
    Camcorder works as it did in B1.
    Trackpad unlock
    New option to increase the timeout for long press to kill on back button. (adjust to reduce unintentional kills)
    All changeable/toggleable in Andromadus settings.
    Fix for Touchscreen in some games. (Temple Run etc)
    Fix for keyboard brightness when auto brightness is turned off
    Bluetooth AVRCP 1.3 support.
    USB Tether (yes it works and has been tested this time)
    ECHO ECHo ECho Echo echo ech ec e should be fixed (and there is probably a marked improvement to voice call quality at the same time)
    Electron Beam Animation - on and off work as they should now (along with blk_jack's autobrightness fix).
    Seperate speaker and headset volumes.
    Additional options in profiles.
    Lots of work has also been done on the kernel by Fyodor, updated kgsl, BFQ 3.0, PPTP VPN, SHA256 support added.
    Everything is just MUCH MUCH faster and smoother.
    Many Many bugs fixed...
    I as always would suggest a wipe, but you should know by now the consequences of not going so
    Lastly if you were having problems previously with anything and I have not mentioned it being fixed, please try it again anyway!
    DOWNLOADS
    BETA5: http://goo.im/devs/andromadus/audacityb5.zip
    BETA4: http://goo.im/devs/andromadus/audacityb4.zip
    BETA3: http://goo.im/devs/andromadus/audacityb3.zip
    BETA2: http://downloads.andromadus.com/files/audacityb2.zip
    GAPPS: http://android.mimic.ca/static/andro...317-signed.zip
    Ragazzi questa rom sembra davvero promettente!! Non ho trovato nessun bug pesante e la uso tranquillamente da un po di giorni!! Mai avuti freeze o problemi simili! Per essere una beta è davvero straordinaria!!!
    P.S: Mi spiace ma il mio inglese è un po scarsino xD Per questo non ho tradotto il changelog!!
    BUGS TROVATI BETA2
    -La fotocamera di instagram non funziona.
    -Le immagini dei contatti di Facebook non vengono sincronizzati in rubrica. Si può risolvere installando HaxSync dal market a 0,99 cents oppure da altri market alternativi..
    -Con swiftkey a volte la tastiera fisica dai i numeri (non funziona, premendo le lettere partono applicazioni etc) mi è successo un paio di volte. Si risolve riavviando il cell.
    -Con Multiling Keyboard, premendo il tasto FN per inserire le seconde funzioni della tastiera fisica, questa si 'incanta'. Quindi premendo le lettere sulla tastiera fisica verranno fuori solo le seconde funzioni.
    -Spirit FM free funziona, ma bisogna attivare prima il bluetooth.
    -Go Launcher Ex si riavvia quando la ram è insufficiente, costringendo a reimpostarlo ogni volta come predefinito. Per risolvere basta congelare il launcher di default con titanium backup (grazie xmax :thumbup: )
    -Friendcaster pro e lite non caricano le foto su Facebook, mentre l'app ufficiale si. Se non volete usare l'app ufficiale scaricate MyAlbum e avete risolto https://play.google.com/store/apps/d...anapps.myalbum
    Ultima modifica di Zendarino; 01-07-12 alle 11:25
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    E' la rom che ho montata da circa 4 5 giorni, davvero una potenza, funziona egregiamente ogni cosa, anche le foto a 5mpx!
    Chiaramente essendo una beta non si può pretendere già la perfezione, ma gli sviluppatori stanno facendo grandi cose secondo me.
    Alcuni problemi riscontrati sono i soliti difetti grafici del launcher (circa uno al giorno, si risolve riavviando), e qualche chiusura improvvisa delle app, per il resto tutto ok, uso quotidianamente senza problemi wifi, bluetooth e gps
    Questo è il link al thread di xda da dove scaricare la rom: link
    cosi rendiamo questo topic quello di riferimento per questa rom
    Ultima modifica di iLuke; 08-04-12 alle 22:44
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
    Zof
    Zof non è in linea
    Androidiani Power User L'avatar di Zof
    Parma
    One Plus 3
    Ringraziato 891 volte in 595 Posts
    Dato che zeldarino lo ha iniziato ti chiedo gentilmente di cambiare il titolo del thread con il taglio [ROM] e di tradurre gentilmente le caratteristiche riportando il changelog e i link per il download grazie
    P. S. Non per fare il pignolo, ma solo per una questione di ordine
    inviato dal mio desire z. by zofox/zabak
    Senior Editor @ Androidiani.com -> Stefano
    Follow me on Twitter-> Stefano
    Follow me on Instagram-> Stefano
    Follow me on Spotify-> Stefano
    Huawei P9 Lite
    Quote Originariamente inviato da zofox Visualizza il messaggio
    Provvedo immediatamente!! ^^
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    Quote Originariamente inviato da Zendarino Visualizza il messaggio
    Inviato dal mio HTC Desire Z usando Tapatalk
    Tranquillo va benissimo grazie
    Huawei P9 Lite
    Propongo di scrivere qui i bug trovati! ^^
    Ad esempio, la Tastiera Multiling (installata dal Play Store) sembra dare problemi quando si scrive con la tastiera fisica. Ovvero quando tengo premuto il tasto FN per inserire punti esclamativi, parentesi etc.. Infatti rimane "bloccato" e quando si continua a scrivere vengono fuori i caratteri secondari...Ho risolto installato la swiftkey (con cui mi trovo benissimo ^^)
    Jan 2011
    Anche io uso la Swiftkey X, tutto tranquillo, l'unica cosa che ho notato è che con la tastiera fisica il comando fn+? non visualizza le doppie apici ma la parentesi chiusa.
    Inoltre installando la tastiera originale htc da apk (htc_ime) non va molto bene con questa rom, penso con nessuna su base ics
    Ultima modifica di iLuke; 09-04-12 alle 11:04
    Huawei P9 Lite
    Quote Originariamente inviato da LukeSGS Visualizza il messaggio
    Purtroppo installando la tastiera originale htc da apk (htc_ime) non va molto bene con questa rom, penso con nessuna su base ics
    Questo non l'avevo notato, comunque l'importante è poter usare la tastiera fisica..Altrimenti questo smartphone perde (almeno per me) l'80% del suo fascino :P. Infatti stavo quasi per toglierla, poi ho provato swiftkey per fortuna :P
  10. #9
    Zof
    Zof non è in linea
    Parma
    One Plus 3
    Anche io uso swiftkey x ;D
  11. #10
    Huawei P9 Lite
    Voi come siete messi a batteria? Sembra avere una buona autonomia... Forse in 3G consuma un pochino di più, ma magari dipende dal mio operatore (wind) e dalla bassa copertura in questa zona...
