[ROM] -=BlackICE=- [CM7.2]
Cosa è BlackICE?
►BlackICE è una derivazione dalla CyanogenMod; modulare, estensibile e oscura... molto oscura
►Molto ottimizzata per migliorare la vita della batterie e le performance
►Tutte le grandi caratteristiche del kernel LordModUE
►Questo è un progetto aperto, si accettano cooperazioni e patch
►Puoi crearti una BlackICE personale
Consigli da amico:
►Se flashi la BlackICE su una rom non BlackICE, è richiesto un full wipe/factory reset
►Ricordate consiglio della mamma: lavarsi i denti tutti i giorni e prendere i 5 minuti per eseguire il backup prima di flashare
Basic features
►CyanogenMod v7.2 (Release Candidate) built from source with custom patches (DHD's description, base was latest stable CM7.2 build from DZ)
►LordModUE latest CFS - tuned up OnDemand governor by default ►►using EliteKernel
► Source modifications from original CyanogenMod - it may include home made patches still not released for general public.
► SysTune free -
►►See discussion thread. You should consider buying full version from market
► gapps-20110930 base including gtalk with camera support ►►please flash Gapps after flashing this ROM.
► Market app downgraded to v2.3.6 by default ►► Believe, you want this. Faster and cleaner.
► Nice looking! - default 200 lcd density, that means more space for you apps and widgets. ►►240... answer the poll and i may make it 200.
► Zeam Launcher by default
► Auto zipaligner script from boot - thx LeeDroid
► Tweaks and customizations and extensions via ICETool v1.00
► Lots of small tweaks from boot
► Torch camera from lock screen - MIUI style - long press home to turn on / off the light
► BlackICE Original feature- BLN!!! (Black Light Notifications)
► Autorun.txt file for customization from flash
download here: (mirrors are welcome)
extra apps (usually bloat): Download
STABLE2: Download
PLEASE NOTE: per i link dropbox, per favore premere il pulsante "add this to my dropbox", in modo che il traffico non uccide il mio account, e tu potrai creare un semplice mirror.
NOTE: flash delle Gapps dopo la rom
Screenshot:
http://blackice.omca.co.uk/download/...8332903371.png
http://blackice.omca.co.uk/download/...8286039332.png
http://blackice.omca.co.uk/download/...8338482431.png
