[ROM][21.1.2014] coolOS ICS 1.4.0 - (MIUIv4) [MULTILANG][ODEX][FAST][AROMA]
Ciao,
Questa ROM MIUI v4 3.2.2 (ICS 4.0.4) è basata sulla miuiandroid.com rom per HTC Desire S (basasta sulla stock SENSE rom). ROM veloce, bella e stabile.
Orginal thread on Polish forum.
Informazioni:
codice:
- Aroma installer,
- based on miuiandroid.com rom,
- languages: English, Polish, Chinese
- rom is odexed,
- choose one from 4 best kernels for DZ,
- choose cache SWAP size (96, 128, 160 MB),
- added MiuiControl panel,
- statusbar JB or ICS
- APM,
- EXT4 file system,
- better memory managment and remove cache from memory every hour,
- background process limited to 6 (for random apps) + 2 (to Messages and Contacts),
- SQLite optimization,
- tweeked build.prop (better data transfers) and others,
- 7 steps of volume when we speak on the phone,
- better scrolling,
- added working WIFI HOTSPOT,
- added Viper4androidFX for best sound quality on headphones (Grant root privileges), :E
- changed hosts file to block adds,
- changed gps configs,
- zipalign, sqlite, cleaning cache and dalvik scripts (working out once a week - after reboot),
- updated busybox,
- added new google play and flash palyer,
- removed bloatware,
- more in changelog.
Raccomandazioni
- Fare un full wipe, è suggerito il full wipe + ext4 format,
Informazioni importanti
- Al primo avvio il cellulare si riavvierà
- Il tempo di installazione è di circa 5 minuti
- Desire Z HBOOT richiesto
- version 1.4.0
- version 1.3.3
- version 1.3.2
- version 1.3.1
- version 1.3
- version 1.2.1
- version 1.2
- version 1.1.4
Changelog:
codice:
- 1.3.3 - tunned ext4 file system (faster write and read from eMMC), added trimming option (no lag after some time of using), background process increased to 7 + messages, dialer and contacts, some small changes.
1.3.2 - changed installer to do automatic full wipe and fixed some problems caused by clockworkmod recovery (bootloop after install and other issues), updated SuperSu app, more agressive low memory killer.
1.3.1 - default CPU frequency changed to 1024MHz (before 1113MHz - can cause instability for some devices), some small changes.
1.3 - Added Multilanguage, added kernel 3.0.72 (+ 31MB of free ram), revert back to stock adreno drivers, some small changes.
Screenshots:
