Installata ieri... Ho aggiornato all'ultima recovery ed è andato tutto ok.
Purtroppo non è il mio telefono primario quindi non riesco a dare impressioni approfondite.. Stasera lo uso un pò e vi dico :)
grazie Luke, beh avendo il N5 immagino :)
rimango in attesa del giudizio prima di procedere al flash.
v1.3.0 is out !
Features and Changes :
- Update to Android 4.4.2_r2 (KVT49L)
- Multi-user support for phones and tablets
- Sound: Volume panel timeout
- Sound: Live Volume Steps
- Sound: Add battery level around unlock ring
- Sound: add support for translucent volume panel
- RecentApp: force clear caches on longclick
- RecentApp: Improve UI Rotation and animation
- NavBar: Handle navbar heights correct on dpi changes
- NavBar: Fix landscape mode on tablet flo/grouper
- NavBar: add landscape height options for tablets
- Port: Omni New Battery Saver mode included what user do to saving the battery life
- SystemUI: time-context headers to the notification header
- time-context evening time
- SystemUI: Fix Quick pull
- SystemUI: Fix notification header disappearing on tablets
- SystemUI: fix volume panel more button transparency
- SystemUI: Make text color orange if BatteryMeter <15%
- SystemUI: improve DessertCaseDream immersive mode exit
- SystemUI: Fix Screenshot rotation
- SystemUI: Fix led pulse for samsung devices
- Fix Xposed Backup Folder Location on dirty flash
- Expanded Desktop : Fix Left handed navbar during landscape mode
- LS Notifications: enable pocket mode and show always if activated
- Browser: Implement client-side incognito mode
- Settings: Fix disable option for low battery indicator in settings
- Settings: Multi-user support toggle in settings -> security
- Settings: ProgressBar Accelerate and Interpolator
- Settings: ProgressBar enable MirrorMode and Reversed if activated
- Settings: ProgressBar Add reset default option
- Settings: Wakelock Blocker
- Settings: add CPU info overlay
- Settings: AOSB Full Simplified Chinese translations
- Settings: Build.prop Mods: Do some prereq's before showing options
- Settings: Automatically switch mobile network into what user choice and also disable mobile data IF wifi connected to an AP
- Settings: Automatically switch mobile network and disable mobile data IF battery low (battery level can configure)
- Settings: Support For Both GSM and CDMA devices
- Screen Recorder: check for supported video encoder resolutions.
- Screen Recorder: Fix lag !
- Update to SuperSU v1.93
- Add ContentLoadingProgressBar support from AOSP
- Contacts: Add support for import contacts to local phone storage
- QS: Fix up Wifi Display tile for screencasting and reenable it
- Dialer: Fix back (clear) icon colors on dark UI
- Sensor: Enable the motion accelerometer for screen orientation change
- Settings: statusbar reflect am/pm and clock color
- Base: large fixes Zygote descriptor leakage problem
- Camera2: tweak volume key zoom and cleanup
- Camera2: Fix Power Shutter Exception
- Camera2: add option to prevend autofocus cancel if preview stopped
- Camera2: actually fix ArrayAdapter on MoreSettingsPopup
- Camera2: AOSB Updated Simplified Chinese translations
- Mms: Fix timestamps layout_width
- Mms: Shrink the minimum bubble size
- Mms: Locate the timestamps outside of bubbles
- Mms: Remove send message gravity for RtL
- Mms: Allow text input field to expand up to 9 lines
- Mms: Fix received thumbnail size
- Mms: improved mms bubbles
- TRDS: Dark Mms again
- OmniSwitch: Update Chinese translations and other Languages by aosb team
- InCallUI: add decline and answer incoming call action on notifications
- PhoneWindowManager: add ability to use EdgeGestureService for system gestures.
- Move lockscreen buttons options to one place
- Move all battery saver options in one place
- Add more new APNs
- Offical support for d2lte unified device
- Offical support for jflte unified device
- Offical support for hlte unified device
- Official support for vision device
Download HERE!!
Download MIRROR!!
Non ti ho più fatto sapere nulla perché il mio desire z ultimamente mi sta dando problemi con il touchscreen che perde colpi, sinceramente non ho capito da cosa dipende e se il problema è software (ho provato varie rom ma il problema c'è sempre anche se in modo diverso...) o hardware (molto probabile, ma perché varia a seconda della rom? ) ... Appena ho un po di tempo vedo meglio
Per questo ho preferito non dare una valutazione sulla rom.. Comunque l'ho tenuta due giorni e non mi ha dato problemi, ho installato circa 15 app..
perfetto grazie! Allora appena mi è possibile la provo anche io :-)
Semplicemente ho scaricato l'ultima CWM e l'ho installata con
:)codice:fastboot flash recovery cwmr_6045_vision.img
è ok , ma io ho provato sia a scaricare il file recovery.img ( rinominandolo )e installandolo da recovery e non va e dal bootloader non ho l'opzione " flash recovery " ma solo : fastboot ( e dopo questo ho solo bootloader , reboot e rebootbootloadere power down ) ,recovery,factory reset, simlock, system info e image crc.
dal pc in che senso ? da ABD ? perchè dopo aver fatto il procedimento di root io non l'ho più toccato il telefono dal pc :-[
perchè se è cosi ci rinuncio , odio profondamente abd e il fatto che servono 178 programmini per gestire un telefono , piuttosto provo a riflashare la vecchia rom e ad aggiornare la clockworkmod tramite rom manager .
