Pagina 8 di 195 primaprima ... 6789101858108 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 1946
Monitorare il Consumo della Batteria
  1. #71
    Banned
    Jan 2011
    Quote Originariamente inviato da Rantolux Visualizza il messaggio
    ok grazie...........nel primo post Linux33 dice cliccare su ""backup and restore......" invece qui c'è "backup ande Remove batterystats.bin" è la stessa cosa?....
    Si è giusto;-) poi fai exit application!
    Androidiano VIP L'avatar di Rantolux
    Feb 2011
    Xiaomi Mi 8
    Ringraziato 514 volte in 446 Posts
    ok grazie ragazzi
    Premettendo che non ho ancora disinstallato la app news, con tutto attivato questo è il mio log file:
    2011/02/11 15:53:49,-378mA,53%
    2011/02/11 15:54:49,-160mA,53%
    2011/02/11 15:55:49,-302mA,53%
    2011/02/11 15:56:49,-179mA,52%
    2011/02/11 15:57:49,-262mA,52%
    2011/02/11 15:57:55,-262mA,52%
    2011/02/11 15:57:57,-262mA,52%
    2011/02/11 15:57:58,-262mA,52%
    2011/02/11 15:59:10,-269mA,51%
    2011/02/11 16:00:10,-3mA,50%
    2011/02/11 16:00:13,-3mA,50%
    2011/02/11 16:07:23,-3mA,50%
    2011/02/11 16:09:11,-5mA,50%
    2011/02/11 16:09:51,-5mA,50%
    2011/02/11 16:10:51,-188mA,50%
    2011/02/11 16:11:51,-310mA,49%
    2011/02/11 16:12:51,-272mA,49%
    2011/02/11 16:13:51,-323mA,49%
    2011/02/11 16:14:07,-323mA,49%
    2011/02/11 16:14:09,-323mA,49%
    2011/02/11 16:14:47,-380mA,48%
    2011/02/11 16:14:49,-380mA,48%
    2011/02/11 16:15:29,-356mA,48%
    2011/02/11 16:17:10,-171mA,48%
    2011/02/11 16:19:12,-5mA,48%
    2011/02/11 16:22:23,-3mA,48%
    2011/02/11 16:28:22,-3mA,47%
    2011/02/11 16:37:23,-5mA,47%
    2011/02/11 16:39:12,-5mA,47%
    2011/02/11 16:41:13,-14mA,47%
    2011/02/11 16:42:13,-14mA,47%
    2011/02/11 16:43:26,-3mA,47%
    2011/02/11 16:43:29,-3mA,47%
    2011/02/11 16:43:30,-3mA,47%
    2011/02/11 16:44:26,-225mA,47%
    2011/02/11 16:44:34,-225mA,47%
    2011/02/11 16:44:36,-225mA,47%
    2011/02/11 16:44:38,-225mA,47%
    2011/02/11 16:49:12,-7mA,47%
    2011/02/11 16:52:23,-13mA,47%
    2011/02/11 16:54:33,-5mA,47%
    2011/02/11 16:56:21,-169mA,47%
    2011/02/11 16:57:29,-206mA,46%
    2011/02/11 16:58:46,-206mA,46%
    2011/02/11 16:59:54,-196mA,46%
    2011/02/11 17:00:51,-201mA,45%
    2011/02/11 17:07:24,-7mA,45%
    2011/02/11 17:08:24,-201mA,45%
    2011/02/11 17:09:24,-176mA,45%
    2011/02/11 17:15:29,-3mA,45%
    2011/02/11 17:19:11,-3mA,45%
    2011/02/11 17:22:24,-15mA,45%
    2011/02/11 17:23:24,-204mA,45%
    2011/02/11 17:25:36,-3mA,45%
    2011/02/11 17:25:40,-3mA,45%
    2011/02/11 17:25:56,-3mA,45%
    2011/02/11 17:28:51,-10mA,45%
    2011/02/11 17:30:04,-164mA,44%
    2011/02/11 17:32:40,-3mA,44%
    2011/02/11 17:32:43,-3mA,44%
    2011/02/11 17:33:43,-158mA,44%
    2011/02/11 17:34:14,-158mA,44%
    2011/02/11 17:34:15,-158mA,44%
    2011/02/11 17:35:23,-3mA,44%
    2011/02/11 17:36:23,-3mA,43%
    2011/02/11 17:37:23,-230mA,43%
    2011/02/11 17:37:35,-230mA,43%
    2011/02/11 17:39:13,-5mA,43%
    2011/02/11 17:42:56,-3mA,43%
    2011/02/11 17:45:29,-15mA,43%
    2011/02/11 17:49:13,-3mA,43%
    2011/02/11 17:52:23,-5mA,43%
    2011/02/11 17:53:59,-3mA,43%
    2011/02/11 17:54:59,-37mA,43%
    2011/02/11 17:57:50,-3mA,43%
    2011/02/11 17:59:13,-5mA,43%
    2011/02/11 18:00:17,-5mA,43%
    2011/02/11 18:03:55,-166mA,42%
    2011/02/11 18:07:24,-5mA,42%
    2011/02/11 18:09:13,-9mA,42%
    2011/02/11 18:15:29,-5mA,42%
    2011/02/11 18:19:13,-3mA,42%
    2011/02/11 18:22:24,-5mA,42%
    2011/02/11 18:27:06,-160mA,42%
    2011/02/11 18:29:14,-3mA,42%
    2011/02/11 18:30:46,-3mA,42%
    2011/02/11 18:30:49,-3mA,42%
    2011/02/11 18:31:36,-3mA,42%
    2011/02/11 18:33:31,-5mA,42%
    SetCPU 1228-245 smartass
    Calibrazione.......?!?!?
    Sicuramente una grossa mano me la darebbe anche aggiornare la ROM alla 2.0.11 con relativo kernel.....giusto?
    Xiaomi Mi 9
  4. #73
    Androidiani Power User
    Dec 2009
    Rimini
    ok grazie ragazzi
    scusa ma a che serve?
    se hai appena usato battery calibrator prima devi caricare bene la batteria
    anche ammesso che tu lo abbia gia fatto, quello che serve è il dato in stand by di almeno 2 ore....se non vai per gradi non serve a molto.....
  5. #74
    Feb 2011
    Xiaomi Mi 8
    Hai ragione non mi sono spiegato bene, io ho usato currenwidget e mi ha fornito il risultato di cui sopra poi dopo averli letti e paragonati agli altri mi chiedevo e vi chiedevo se fosse necessario calibrare la batteria, secondo me lo è e chiedevo chiarimenti riguardo l'app battery calibrator, che ancora non ho usato...ho sbagliato vista ancora la mia poca esperienza?......dai con un pò di tempo imparerò te lo assicuro
    Xiaomi Mi 9
  6. #75
    Dec 2009
    Rimini
    Hai ragione non mi sono spiegato bene, io ho usato currenwidget e mi ha fornito il risultato di cui sopra poi dopo averli letti e paragonati agli altri mi chiedevo e vi chiedevo se fosse necessario calibrare la batteria, secondo me lo è e chiedevo chiarimenti riguardo l'app battery calibrator...ho sbagliato vista ancora la mia poca esperienza?......dai con un pò di tempo imparerò te lo assicuro
    come ho detto non serve a niente se non segui cronologicamente le indicazioni del primo post
  7. #76
    Banned
    Jan 2011
    Allora..fai cosi...segui il primo post come dice linux..poi controlla in standby come sei messo..se il tel consuma piu dell'1% ora allora qualcosa da migliorare c'è..altrimenti sei a posto..le rom revo fanno già il wipe della batteria durante l'installazione (il che rende inutile l'uso di battery calibrator) per. Urremt widget invece fai test accurati e ripetili almeno tre volte prima di muoverti di conseguenza..va bene;-)?? se vuoi chiedere altro sono qua;-)
    P.S. sbagliando si impara;-)
    Sent from my Desire HD using Tapatalk
  8. Il seguente Utente ha ringraziato memnoch per il post:
    Rantolux (11-02-11)
  9. #77
    Feb 2011
    Xiaomi Mi 8
    Quote Originariamente inviato da memnoch Visualizza il messaggio
    ok
    ora l'ho messo in carica e come scritto nel primo post aspetto che si carica completamente poi attivo currentwidget tutta la notte e vediamo come và......devo lasciarlo in standby o attivare tutto (3g, gps, sync,ect.) durante il test questa notte?
    Grazie mille
    Xiaomi Mi 9
  10. #78
    Banned
    Jan 2011
    ok
    Grazie mille
    Attiva tutti! Wifi o 3g, gps,syncro,dati in background..vediamo cosa sa fare;-)
  11. #79
    Feb 2011
    Xiaomi Mi 8
    ok sta ancora in carica...88%
    Xiaomi Mi 9
  12. #80
    Feb 2011
    Xiaomi Mi 8
    Ciao questa notte ho fatto il test con tutto attivo :
    2011/02/12 03:08:39,-344mA,100%
    2011/02/12 03:09:39,-295mA,100%
    2011/02/12 03:12:38,-160mA,99%
    2011/02/12 03:14:08,-159mA,99%
    2011/02/12 03:15:37,-5mA,99%
    2011/02/12 03:19:28,-3mA,99%
    2011/02/12 03:22:23,-3mA,99%
    2011/02/12 03:23:23,-159mA,99%
    2011/02/12 03:29:28,-5mA,99%
    2011/02/12 03:37:24,-5mA,99%
    2011/02/12 03:38:38,-174mA,99%
    2011/02/12 03:45:37,-5mA,99%
    2011/02/12 03:49:28,-3mA,99%
    2011/02/12 03:52:24,-3mA,99%
    2011/02/12 03:53:37,-174mA,99%
    2011/02/12 03:59:29,-3mA,99%
    2011/02/12 04:05:48,-3mA,99%
    2011/02/12 04:06:48,-3mA,99%
    2011/02/12 04:08:08,-20mA,99%
    2011/02/12 04:09:29,-36mA,99%
    2011/02/12 04:15:38,-3mA,99%
    2011/02/12 04:19:29,-3mA,99%
    2011/02/12 04:22:23,-3mA,99%
    2011/02/12 04:23:38,-171mA,99%
    2011/02/12 04:29:29,-5mA,98%
    2011/02/12 04:33:53,-5mA,98%
    2011/02/12 04:34:53,-5mA,98%
    2011/02/12 04:37:23,-3mA,98%
    2011/02/12 04:38:38,-171mA,98%
    2011/02/12 04:45:38,-5mA,98%
    2011/02/12 04:49:29,-4mA,98%
    2011/02/12 04:52:23,-3mA,98%
    2011/02/12 04:53:38,-174mA,98%
    2011/02/12 04:57:29,-5mA,98%
    2011/02/12 04:59:28,-7mA,98%
    2011/02/12 05:01:56,-5mA,98%
    2011/02/12 05:02:56,-3mA,98%
    2011/02/12 05:07:24,-3mA,98%
    2011/02/12 05:08:33,-178mA,98%
    2011/02/12 05:09:33,-3mA,98%
    2011/02/12 05:15:38,-5mA,98%
    2011/02/12 05:19:30,-3mA,98%
    2011/02/12 05:22:23,-5mA,98%
    2011/02/12 05:23:38,-188mA,98%
    2011/02/12 05:29:30,-5mA,98%
    2011/02/12 05:30:58,-3mA,98%
    2011/02/12 05:37:25,-3mA,98%
    2011/02/12 05:38:38,-179mA,98%
    2011/02/12 05:45:38,-3mA,98%
    2011/02/12 05:45:38,-3mA,97%
    2011/02/12 05:49:30,-5mA,97%
    2011/02/12 05:52:24,-5mA,97%
    2011/02/12 05:53:38,-174mA,97%
    2011/02/12 05:58:02,-3mA,97%
    2011/02/12 05:59:02,-3mA,97%
    2011/02/12 06:07:23,-3mA,97%
    2011/02/12 06:08:38,-173mA,97%
    2011/02/12 06:09:41,-5mA,97%
    2011/02/12 06:15:39,-5mA,97%
    2011/02/12 06:19:29,-3mA,97%
    2011/02/12 06:22:24,-3mA,97%
    2011/02/12 06:23:37,-172mA,97%
    2011/02/12 06:26:06,-5mA,97%
    2011/02/12 06:27:06,-5mA,97%
    2011/02/12 06:29:30,-3mA,97%
    2011/02/12 06:37:23,-5mA,97%
    2011/02/12 06:38:38,-175mA,97%
    2011/02/12 06:45:39,-5mA,97%
    2011/02/12 06:49:29,-3mA,97%
    2011/02/12 06:52:25,-5mA,97%
    2011/02/12 06:53:39,-173mA,97%
    2011/02/12 06:55:09,-3mA,97%
    2011/02/12 06:59:30,-3mA,97%
    2011/02/12 07:07:23,-3mA,97%
    2011/02/12 07:08:38,-171mA,97%
    2011/02/12 07:09:45,-4mA,96%
    2011/02/12 07:15:39,-3mA,96%
    2011/02/12 07:19:30,-5mA,96%
    2011/02/12 07:22:12,-3mA,96%
    2011/02/12 07:23:12,-5mA,96%
    2011/02/12 07:29:31,-3mA,96%
    2011/02/12 07:37:23,-5mA,96%
    2011/02/12 07:38:38,-181mA,96%
    2011/02/12 07:45:40,-3mA,96%
    2011/02/12 07:49:30,-3mA,96%
    2011/02/12 07:51:15,-3mA,96%
    2011/02/12 07:52:24,-3mA,96%
    2011/02/12 07:53:38,-178mA,96%
    2011/02/12 07:59:31,-3mA,96%
    2011/02/12 08:07:24,-5mA,96%
    2011/02/12 08:08:42,-90mA,96%
    2011/02/12 08:15:39,-5mA,96%
    2011/02/12 08:18:18,-5mA,96%
    2011/02/12 08:19:18,-5mA,96%
    2011/02/12 08:22:24,-3mA,95%
    2011/02/12 08:23:38,-174mA,95%
    2011/02/12 08:29:30,-14mA,95%
    2011/02/12 08:31:59,-3mA,95%
    2011/02/12 08:34:59,-3mA,95%
    2011/02/12 08:35:34,-3mA,95%
    2011/02/12 08:35:37,-3mA,95%
    Che ve ne pare a me sembra che non sia necessario calibrare la batteria aspetto vostre impressioni e consigli.
