[ROM][CM11][4.4.2] GimmeABreak 1.0 - REBORN! | Beta | Initial Release 3.26.14
    Feb 2014
    Padova
    Asus Zenfone Max ZC550KL
    Ringraziato 22 volte in 13 Posts
    Ciao ragazzi girovagando per xda ho trovato questa ROM Kitkat , basata sulla Nighlties (20140326) CM 11 by Mustaavalkosta
    Io non l'ho ancora testata in quanto è ancora una beta
    Rom by caspboy
    Compatibilità : DHD ROOT / S-ON or S-OFF
    ABOUT THE PROJECT:
    GimmeABreak is a Rom I thought up originally for the DHD a while ago, but 5 months and 1 DHD later I've brung it back for another run, the correct path this time! So enjoy!
    FEATURES:
    - Based on 20140326 Nightly CM11
    - Smallest CM based Rom
    - Deodexed
    - HoloSense UI/Theme
    - Roboto Condensed fonts
    - Netflix fix
    - SuperSU
    - Enabled GPU rendering
    - Adblocking
    - Facebook Sync Hack
    - Minimal amount of ringtone/notifications/alarms
    - Fly-on Mod
    - Launcher3
    - New LiveWallpapers (removed old ones)
    - Build.prop tweaks
    - Apps2SD Support
    - Google Bootanimation
    - Viper4Android
    - Removed Bloatware and unnecessary applications from CM11
    - Latest CM Source
    WHAT YOU NEED:
    HTC Desire HD
    Custom recovery
    A brain
    KNOWN ISSUES:
    None at the moment.
    HOW TO FLASH:
    Download the latest version and place it on your SD card
    Boot your phone into recovery mode
    Do a Full Wipe (recommended)
    Browse to the location of the ROM
    Flash ROM
    Remember to reflash boot.img via fastboot if you are HTCDev unlocked.
    Flash Gapps if needed
    Reboot and enjoy!
    IMPORTANT NOTES:
    1. If you want to say "Thanks!"
    There are many ways to show your support to the developer:
    Press "Thanks" button.
    Share your opinion about my work and write some feedback in this thread.
    Rate this thread with 5 stars.
    Every way of support is highly appreciated!
    2. Support
    If you have any issues or questions, please feel free to post them in this thread.
    If you want to get the fastest and the best answer - ask the question in the thread.
    3. Disclaimer
    Me (caspboy) and Mustaavalkosta are not responsible for any possible damage done to your device as a result of flashing this ROM.
    If you are not willing to agree with these conditions,
    please do not continue the installation process.
    Anyway, this ROM was previously installed and tested by me
    without any kind of problems that may cause bricks.
    Kernel Source: https://github.com/AceEnablementProject/htc7x30-3.0
    Thanks for using my work! I hope you will enjoy it!
    Lascio link discussione xda [ROM][CM11][4.4.2] GimmeABreak 1.0 - REBORN! | Beta | Initial Release 3.26.14 - xda-developers
    Ultima modifica di geomOIC; 27-03-14 alle 15:52
    Asus Zenfone Max ZC550KL-6A011WW Dual Black
    RISOLTO problema gps http://www.androidiani.com/forum/asu...al-gps-13.html
    RISOLTO problema gps 2° Soluzione http://www.androidiani.com/forum/asu...ml#post7938912
