Pagina 35 di 129 primaprima ... 2533343536374585 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 1289
[ROM][June 12]-=MDJ's ViVO Sense v3.1.1=- [Sense 2.1|2.36.405.8][GRI40][CRT][OC/UV]
  1. #341
    Androidiano VIP L'avatar di framir
    Apr 2010
    Ringraziato 70 volte in 64 Posts
    Ragazzi sto spolpando questa fantastica ROM ed ho solo notato un bug nel meteo, praticamente non si possono aggiungere moltissime località italiane poichè non ci sono!
    Come si può ovviare?
    Ciau
    Francesco
    Smartphone: LG Nexus5 - ROM: Stock - Kernel: Stock - Boot: Sbloccato - Recovery: TWRP
    axl409
    Mi pare sotto 3g abbia consumi un pò alti. Sono sulla 2.7 con kernel di base della rom e questo è il log:
    2011/05/14 14:11:06,-189mA,99%
    2011/05/14 14:11:07,-189mA,99%
    2011/05/14 14:12:53,-1mA,99%
    2011/05/14 14:14:31,-4mA,99%
    2011/05/14 14:15:55,-4mA,99%
    2011/05/14 14:17:25,-164mA,99%
    2011/05/14 14:18:40,-160mA,99%
    2011/05/14 14:19:40,-147mA,98%
    2011/05/14 14:20:49,-4mA,98%
    2011/05/14 14:21:49,-151mA,98%
    2011/05/14 14:22:49,-155mA,98%
    2011/05/14 14:23:52,-34mA,98%
    2011/05/14 14:24:54,-45mA,98%
    2011/05/14 14:27:29,-165mA,98%
    2011/05/14 14:29:55,-164mA,98%
    2011/05/14 14:30:56,-151mA,98%
    2011/05/14 14:33:54,-82mA,98%
    2011/05/14 14:35:01,-165mA,98%
    2011/05/14 14:36:54,-4mA,98%
    2011/05/14 14:39:17,-1mA,98%
    2011/05/14 14:40:41,-165mA,98%
    2011/05/14 14:42:53,-21mA,98%
    2011/05/14 14:44:48,-165mA,97%
    2011/05/14 14:45:50,-147mA,97%
    2011/05/14 14:46:50,-4mA,97%
    2011/05/14 14:48:11,-145mA,97%
    2011/05/14 14:49:41,-1mA,97%
    2011/05/14 14:51:47,-165mA,97%
    2011/05/14 14:52:59,-165mA,97%
    2011/05/14 14:54:17,-92mA,97%
    2011/05/14 14:55:17,-138mA,97%
    2011/05/14 14:56:33,-4mA,97%
    2011/05/14 14:57:33,-157mA,97%
    2011/05/14 14:58:48,-167mA,97%
    2011/05/14 14:59:58,-5mA,97%
    2011/05/14 15:01:03,-1mA,97%
    2011/05/14 15:02:03,-54mA,97%
    2011/05/14 15:03:03,-15mA,97%
    2011/05/14 15:06:54,-2mA,96%
    2011/05/14 15:07:54,-4mA,96%
    2011/05/14 15:09:10,-1mA,96%
    2011/05/14 15:12:47,-169mA,96%
    2011/05/14 15:15:21,-9mA,96%
    2011/05/14 15:18:54,-3mA,96%
    2011/05/14 15:21:54,-1mA,96%
    2011/05/14 15:22:54,-1mA,96%
    2011/05/14 15:24:00,-3mA,96%
    2011/05/14 15:25:00,-22mA,96%
    2011/05/14 15:26:12,-159mA,96%
    2011/05/14 15:27:12,-115mA,96%
    2011/05/14 15:28:13,-12mA,96%
    2011/05/14 15:29:22,-178mA,96%
    2011/05/14 15:30:23,-155mA,95%
    2011/05/14 15:33:54,-1mA,95%
    2011/05/14 15:35:20,-1mA,95%
    A me non sembra granché. Ho anche ricalibrato. Sotto wifi è ottimo, ma sotto 3g non tanto. Che ne pensate?
    Sent from my Desire HD using Tapatalk
  4. #343
    Androidiano VIP L'avatar di Ganzdroid
    Aug 2009
    Ringraziato 296 volte in 259 Posts
    Salve a tutti,
    ho rootato oggi il mio DHD e mi aggiungo di fatto con questo post alla sezione modding.
    Devo dire che sono un pò spaesato. Del desire conoscevo nascita, morte, miracoli e risurrezioni di ogni sviluppatore... Qua con il DHD invece sono un niubbo Cmq ho scelto questa ROM per "incominciare".
    Mi spaventa un pò il bug del locksceen per l'usabilità, ma tanto vale provare!
    Da cupcake ad oggi:
    HTC Magic 32b (mangiato dal cane) - HTC Desire (venduto) - HTC Desire HD (venduto) - ASUS TFT 101 (venduto) - Galaxy NEXUS (reso) - Nexus 4 (rotto) - Nexus 5 (rotto) - Nexus 7 2013 (rotto) - OnePlus Two (venduto) - Galaxy S8
  5. #344
    axl409
    Quote Originariamente inviato da Ganzdroid Visualizza il messaggio
    Salve a tutti,
    Quale bug?
  6. #345
    Androidiano VIP L'avatar di ivanothai
    Feb 2011
    IPHONE 7 PLUS 32GB NERO OPACO
    Ringraziato 152 volte in 116 Posts
    Quote Originariamente inviato da ivanothai
    scarica dal market fasterfix e gps fix
    In fasterfix metti Europe e poi GO
    apri gps fix (con la connessione attiva) vai su start fix e aspetta che ti appaiano tutti i sateliti....a fix avvenuto avvertirai una vibrazione
    gpsfix dice no fix
    Tutto risolto.
    Funziona
    Inviato dal mio Desire HD usando Androidiani App
    HO VENDUTO E CONCLUSO POSITIVAMENTE A:
    fabry83 (nexus 4 16gb)
    jackevolution (htc one x 32gb)
    Xmanganato77 (umi x1)
    keyou (antenna kft umi x1)
  7. #346
    Aug 2009
    Quote Originariamente inviato da axl409 Visualizza il messaggio
    Quale bug?
    Questo.. l'unico segnalato
    Issues:
    - lockscreen: Pattern and password unlock are completely broken while receiving incoming call
    ah già.... ho fatto il root perchè sono uno smanettone e perchè il wi-fi si sconnetteva di continuo con la rom stock e non riuscivo a scaricare i dati di n.o.v.a. 2
    qua funge vero? non si stacca da solo dopo un pò per poi riattaccarsi?
    Ultima modifica di Ganzdroid; 14-05-11 alle 17:12
    Da cupcake ad oggi:
  8. #347
    Apr 2010
    Quale bug?
    Non c'è nessun bug tranne per chi usa il codice pin della sim credo e il database scarno con le località italiane per il meteo
    Francesco
  9. #348
    Feb 2011
    Scaricati l'update! Contiene solo le patch per gli sms in loockscreen e qualche altra piccola ottimizzazione!
    Io ho fatto, tutto ok!
    Io sono ancora alla 2.5. Mi conviene scaricare subito la 2.8 full piuttosto che passare per la 2.6. Vorrei sapere se ha il wipe automatico altrimenti farei un easywipe per tenermi i dati.
    HTC Desire HD
    ROM: RCMix HD KINGDOM v0.1
    RADIO: 12.54.60.25_26.09.04.11_M2
    KERNEL: Stock
    RECOVERY: CWM 3.0.2.6
  10. #349
    Aug 2009
    Quote Originariamente inviato da framir Visualizza il messaggio
    ottimo! non vedo l'ora di flashare. stò download è infinito
    Da cupcake ad oggi:
  11. #350
    scusate cm si usa lazy droid
LinkBacks (?)
  1. 22-03-12, 02:17
