Pagina 1 di 10 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 98
[ROM][GRI40] DoubleShot Porting v.1.0.1RC|GingerBread 2.3.3 with Sense 3.0 [30 APRIL]
    Senior Droid L'avatar di rs125
    Aug 2010
    • Base: Official GingerBread 2.3.3 Leaked HTC 2.36.405.5
    • Kernel: Stock Kernel
    • GingerBread and Sense 2.1
    • Added OC Kernel
    • ROOT (SU + SuperUser Permissions)
    • Unsecured boot.img
    • Busybox 1.19
    • RAM optimization
    • Speed optimization
    • Fast & Stable
    • Multilanguage (All language)
    • Zipaligned
    • Deodexed
    • Nano text editor and sysro/sysrw support
    • Moduli aggiuntivi attivi
    • Bash support
    • init.d scripts (busybox run-parts) support
    • Improved battery life.
    • ROM Ad-Free
    • Updated Hosts
    To install this ROM you need:
    • Root S-Off - [TOOL]
    • Recovery 3.0.0.6 - Download it to Rom Manager
    • Radio S-OFF to flash the radio - [TOOL][VIDEO]
    Changelog 1.0.1
    New Rs DoubleShot v 1.0.1 RC 1
    Fixed Wifi.
    Installare lo zip come SOLO aggiornamento sulla ROM precedente!!
    ----------Rs DoubleShot v 1.0 RC 1-------------------
    New Rs DoubleShot v 1.0 RC 1
    Mix from base 2.36.405.5 DHD and DoubleShot 1.01.531.1
    Updated build.prop
    Updated Updater-script
    Added new MDJ Kernel Up to 1.9 Ghz
    Fix SetupWizard
    Fix APN
    Added all language
    Fix Album problem
    Removed stock apk
    Bug:
    Camera
    Camcorder
    Wifi...............FIXED
    Ultima modifica di rs125; 01-05-11 alle 11:16
    Rs GingerX HD e PureGoogle for HTC ACE
    GingerX & PureGoogle
    Rs Xtreme Series ITA for Blackstone and Topaz
    Rs Xtreme 1.9 ITA MaxSense 1.05
    Rs Xtreme 2.1 ITA Sense 2017
    Rs Xtopaz 1.1 ITA
    Aug 2010
    Screen:
    Ultima modifica di rs125; 01-05-11 alle 11:26
    Rs Xtopaz 1.1 ITA
    Aug 2010
    Reserved 1
    Rs Xtopaz 1.1 ITA
    Aug 2010
    Per chi ha installata la clockworkmod Recovery 3.0.0.6 o successive
    Procedura per il flash:
    • Scaricate la ROM.
    • Copiatela nella root della SD.
    • Scaricate l'allegato.
    • Copiatelo nella root della SD senza estrarlo. Serve così com'è!
    • Andate in Menu> Impostazioni> Applicazioni e andate sull'ultima voce.
    • Disabilitate il fastboot
    • Riavviate il terminale tenendo premuto il tasto volume giù.
    • Una volta entrati in recovery scegliete "Install zip from sdcard".
    • Scegliete il file che avete precedentemente copiato nella sd "Full-wipe-1.3.zip e cliccate sulla voce "Yes - Install..........."
    • Finito il processo vi ritroverete nella schermata di prima.
    • Riclicchiamo su "Install zip from sdcard".
    • Scegliete questa volta la rom che avete precedentemente scaricato e copiato.
    • Cliccate sulla voce "Yes - Install..........."
    • Finito il processo dovrete cliccare su "+++++Go Back+++++"
    • Ed infine cliccate sulla prima voce "reboot system now"
    FLASH CONCLUSO CON SUCCESSO
    File allegati
    Ultima modifica di rs125; 01-05-11 alle 10:59
    Rs Xtopaz 1.1 ITA
    Aug 2010
    Before downloading I suggest installing the radio Radio_12.28e.60.140f_26.04.02.17_M2. To install the radio you need the eng s-off that are here.
    Installing the radio have better performance!!
    DOWNLOAD 2.36.405.5 ROM Based:
    Rs Doubleshot 1.0 GRI40
    Rs Doubleshot 1.0.1 GRI40
    Ultima modifica di rs125; 01-05-11 alle 11:01
    Rs Xtopaz 1.1 ITA
    Aug 2010
    Mod Grafiche e Restore
    Rs Xtopaz 1.1 ITA
    Androidiano VIP L'avatar di lorefly
    Nov 2010
    livorno
    samsung galaxy s2
    Ringraziato 26 volte in 23 Posts
    Ciao rs mi spieghi che rom e'????
    Sent from my Desire HD using Tapatalk
    Samsung Galaxy Note 2
    Codice Modello: GT-7100
    Gestore Telefonico: H3g
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
    Versione Android: JB 4.1.2
  9. #8
    Aug 2010
    Quote Originariamente inviato da lorefly Visualizza il messaggio
    Fra poco arrivano gli screen. In pratica ho fatto un mix tra la 2.36 del DHD e 1.01 del Doubleshot da cui ho preso il sense 3.0.
    La rom ha qualche bug come ho scritto ma è nettamente superiore agli altri porting
    Rs Xtopaz 1.1 ITA
  10. #9
    Nov 2010
    livorno
    samsung galaxy s2
    Quote Originariamente inviato da rs125 Visualizza il messaggio
    Ok ora la installo e la testo un Po' poi ti dico
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
  11. #10
    Androidiano VIP L'avatar di alvarotodini
    Mar 2010
    corchiano vt
    Ringraziato 108 volte in 97 Posts
    Aspetto le tue considerazioni ;-)
    Attenzione a Manule Tibaldi di ivrea (TO),è un truffatore
