Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 55
rom - kernels - tools - guide - f.a.q and more!
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    ecco qua una rqaccolta di tuti i thread importanti nella sezione DHD.
    GUIDE:
    - Root, s-off, eng bootloader: https://www.androidiani.com/forum/mo...ggiornata.html
    - flash recovery via fastboot: https://www.androidiani.com/forum/mo...ry-su-dhd.html
    -monitorare consumo batteria: https://www.androidiani.com/forum/mo...-batteria.html
    -downgrade da 1.72.xx a 1.32.xx: https://www.androidiani.com/forum/mo...72-1-32-a.html
    - guida adb e fastboot: https://www.androidiani.com/forum/mo...-fastboot.html
    F.A.Q:
    - quello che bisogna sapere sul DHD libero: https://www.androidiani.com/forum/mo...hd-libero.html
    -chiarimenti sui firmware radio: https://www.androidiani.com/forum/mo...lle-radio.html
    Froyo SENSE HD ROMS:
    - Core Droid HD: https://www.androidiani.com/forum/mo...htc-sense.html
    - Android Revolution HD: https://www.androidiani.com/forum/mo...2-v-3-x-x.html
    - RCMixHD 3.4: https://www.androidiani.com/forum/mo...oc-kernel.html
    - LeeDroidHD: https://www.androidiani.com/forum/mo...droid_hd_.html
    Froyo AOSP ROMS:
    - miui: https://www.androidiani.com/forum/mo...-italiano.html
    GingerBread SENSE HD ROMS:
    - LeeDroidHD: https://www.androidiani.com/forum/mo...ngerbread.html
    - VillainRomHD: https://www.androidiani.com/forum/mo...as-landed.html
    - RCMixHD: https://www.androidiani.com/forum/mo...ngerbread.html
    - Android RevolutionHD :https://www.androidiani.com/forum/mo...-hd-4-0-a.html
    AOSP Gingerbread ROMS:
    - cyanogenmod 7: https://www.androidiani.com/forum/mo...desire-hd.html
    KERNELS FOR DHD:
    -thay's thread: https://www.androidiani.com/forum/mo...rnels-dhd.html
    RADIO THREAD:
    - radio thread by thay: https://www.androidiani.com/forum/mo...ews-tools.html
    TOOLS:
    -Fastboot Commander: https://www.androidiani.com/forum/mo...commander.html
    - Splash Screen creator: [APP] Splash Screen Creator (it Flashes Too) v0.02 Beta - xda-developers
    - button remapper: https://www.androidiani.com/forum/mo...i-del-dhd.html
    -recovery tool, full wipe: [TOOL][APP][RECOVERY-APP] EASY FULL WIPE - CWM 2 & 3 - WIPE.zip - UPDATED 23/01/2011- - xda-developers
    DHD THEMES:
    - themes by adonis: https://www.androidiani.com/forum/mo..._per_dhd_.html
    -skins for sense 2.0: https://www.androidiani.com/forum/mo...work-mods.html
    GAMES and APPS by adonis:
    - thread: https://www.androidiani.com/forum/mo...s_-_apps_.html
    RUU (by shipped roms):
    HTC ACE WWE 1.15.405.1
    HTC ACE WWE 1.28.405.1
    HTC ACE WWE 1.24.405.1
    HTC ACE WWE 1.32.405.3
    HTC ACE WWE 1.32.405.6
    HTC ACE WWE 1.72.405.3
    Ultima modifica di linux33it; 24-05-11 alle 20:47
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
  2. I seguenti 6 Utenti hanno ringraziato cesco per il post:
    angiotell (03-04-11),Berto392 (22-04-11),leogalaxys (08-05-11),savioonline (14-04-11),tammazz (09-03-11),TheAztek (10-10-12)
    Sep 2010
    Bg
    reserved 1
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
  5. #3
    Sep 2010
    Bg
    reserved 2
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
  6. #4
    Sep 2010
    Bg
    reserved 3
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
  7. #5
    Sep 2010
    Bg
    reserved 4
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
  8. #6
    Androidiano VIP L'avatar di Orco
    Aug 2010
    Crema
    Ringraziato 183 volte in 170 Posts
    Bella Cesco, così è tutto raggruppato. Nella sezione Tools aggiungerei il link a xda per il ROM Cleaner, inoltre, quando Thay sarà pronto, ci sarà da aggiungere la sezione di Modding. Così è tutto chiaro e limpido!!
    [SIZE=1]HTC Desire HD Rooted & ENG S-OFF
    ROM: SP33_ITALIA_1.0.0_AROMAfull
    RADIO: 26.09.04.11_M2
    KERNEL: 3.0.93-ucdx
    RECOVERY: 4EXTRecovery Touch 1.0.0.5 RC9
  9. #7
    Sep 2010
    Bg
    Quote Originariamente inviato da Orco Visualizza il messaggio
    si intanto l'ho imbastita!! devo ancora aggiungere un botto di roba che puo' servire soprattutto ai nuovi arrivati!...tools radio guide varie ecc ecc
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
  10. #8
    Apr 2010
    Droidland
    meglio di xda
    Ultima modifica di thay; 09-03-11 alle 14:25
  11. #9
    Banned
    Jan 2011
    meglio di xda
    Bella;-)
    Sent from my Desire HD using Tapatalk
  12. #10
    Sep 2010
    Bg
    ragazzi segnalatemi qualsiasi tool o thread utile in modo da avere una lista piu' completa possibile!! (datemi anche i link magari, semplificherebbe il tutto)
    Follow me on:
    (function() {
    </script>
    <br>
    Androidiani app
